Question about RCA Televison & Video
R C A 52" Rear Proj. TV
RCA Proj. TV Model MM-52100
Problem: After being on and working normally for a while, it snaps 'out of convergance'. Need to know if there is a seperate -convergance- panel or board I can replace (It's part/module number),or not? Or if the whole 'motherboard' must be replaced? {I've a # of yrs. experience on Color & Big screen TV service} Thanks kindly, Jim {Service dept.] in Minn. @ 507-433-4316 or E-mail: jimbtvradio@aol.com
  • 1 more comment
  • JayM2 Sep 19, 2008
    ~ Added comment- would definetly need the :Convergance- board (or panel) part number, if it's avaliable. 'JayM2'
    Master:
  • 726 Answers
Hi there i hope this helps alot for you That set is a pain to work on. There is most likely a module you can change to fix the set the suppler has a pn listed for the convergence board as 248553. They may or may not be the board you need, there may be a convergence power board causing your problem if this is the case then the board listed above will not help you. I cannot pull an rca manual here so i cannot be certain. I will look this weekend and find out if thats the correct board or not.
Posted on Sep 19, 2008
    Novelist:
    Champion:
  • 203 Answers
That set is a pain to work on. There is most likly a module you can change to fix the set. my supplyer has a pn listed for the convergance board as 248553. They may or may not be the board you need, there may be a convergence power board causing your problem if this is the case then the board listed above will not help you. I cannot pull an rca manal here so i cannot be certain. I will look this weekend and find out if thats the correct board or not.
Tim Nolan
Posted on Sep 12, 2008
  • 4,472 Answers
Https://www.manualsparadise.com/MainSearch.do?brand=429&model=MM-52100&elementChanged=Find
You can find the service manual to answer all your questions usually for around 25$
If you need any other assistance please let me know.
Thanks,
Lee
I need a convergence kit for a rca 52 inch rear projection tv
what type of problem with convergence? no convergence at all? pitcure bowing? this in the setup menu do you have the convergence option? a convergence ki in a standad porojection has stk ic/s this model does not .you might have the fl231 fuse problem.. generally its board replacement. then the problem becomes alighnment.
Aug 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52 inch RCA model # R52WH73. The picture is blurry and double. What do I need to do to fix it?
Ur convergence is dead,need a convergence kit,know how to solder right?Tries these websites.Tv Repair World.com,Ebay.com.
Oct 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need to find out where the convergance box is located or what it looks like.
Your model doesnt have the normal Convergence ICs that are associated with most other rear projection TVs. www.tvrepairworld.com can assist you with waht you need for your RCA
Oct 11, 2009 | RCA D52W23 52" HDTV CRT TV
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
RCA REAR PROJ. SCREEN BOWS AT TOP AND COLORS DOUBLED
Hi, thank you for visit fix ya.
Resolder all connections around fly back ( check for open pico fuse).
if still problem, replace convergence board.
Thank you
Jul 27, 2009 | RCA HD52W58 52" TV
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Converges problem for my RCA 52
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
