Question about Dell Dimension 3000 PC Desktop
Lost password for Dell Dimension 3000.
Moved and am now setting up my Dell computer. I can't remember my password for my dell dimension 3000. What to do?
  • harleybabe12 Jan 28, 2009
    I forget my password on my Dell Dimension 3000 desktop due to inactivity.
    How can I reset it or remove it?
    Problem Solver:
  • 5 Answers
If you have all of your important documents on a separate hard drive then you can reset the computer main frame and then you can recreate a new password! and if that doesn't work then you can always have a computer tech. take a look at it! Infact i'll give you the number to a guy who live's in S.C. His name is Dwight Welsh but you can just call him mister Welsh. So any ways his cellphone number is (910) 494-7467.
Posted on Sep 14, 2008
How do I run a set up program
Generally, one enters the BIOS Setup screen by pressing either F2 or Del. There is usually a message on the bottom of the first boot screen that indicates what button is correct for that model.
Looking further into the details that you have given, it seems that your CMOS battery has died, so you will need to replace that. (This is what is causing the "Time of Day Not Set" message most likely.) You can get the appropriate battery at Radio Shack (if nowhere else) for about $5 or $6.
Oct 17, 2014 | Dell Dimension 3000 PC Desktop
I have a dell 3000 dimension desk top computer. The message I get after tapping the F12 key is as follows. Key board failure. Type password and press enter to leave password security enabled next line
The motherboard BIOS is activated when you press the F12 Key and can be locked via a password that is different from your pc user account. There is only one way to reset this because the BIOS is a chip on the motherboard. You have to reset the password using a jumper on the motherboard that is marked with PSWD. This will also clear the CMOS which is Computer Memory on Startup which tells the computer the different changes from the original bios chip. so you may have to go in and set some settings in the bios to have everything back to operational.
Turn off and unplug the tower before opening it.
The password jumper's location on a Dell Dimension motherboard can be found by reviewing the Dimension User Guides.
For most Dell Dimension desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Now replace the panel and plug unit back in. You should be able to enter the bios without a password.
Oct 01, 2014 | Computers & Internet
What do I set my CD-Rom Jumpers to in a Dimension 1100
Which is it a Dell 3000 or Dell 1100 ?
The jumper settings on the rear of the DVD drive; set the jumpers to "cable select" mode (if you are uncertain how to set the jumpers, check the documentation that came with your drive or look for a diagram printed on the drive itself). Insert your DVD drive into the selected drive bay and connect the IDE and power cables. Use the screws that came packaged with the drive to secure the component to the drive bay.
Dell Dimension 3000 Service Manual
http://support.dell.com/support/edocs/systems/dim3000/en/SM/sm.EXE Dell Dimension 3000 Users Guide http://support.dell.com/support/edocs/systems/dim3000/en/OM/j6758A04.pdf
Mar 02, 2013 | Dell Dimension 3000 PC Desktop
Forgotten pasword for dell dimension 3000
If you want the quickest way, then I think you can take a try this password recovery software, a program which helps to reset Windows Administrator login password easily. Fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit. Your DELL Dimemsion is supported. Good luck!
Jul 27, 2010 | Dell Dimension 3000 PC Desktop
Forgot my password to my dell dimension 3000, how can I reset?
It's a large file, but you can download and burn a copy of:
http://www.ubcd4win.com/
It's a bootable cd that has a password recovery tool plus a lot of other stuff.
Feb 13, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
288 people viewed this question
Alun Cox
