Question about Evesham Axis PC Desktop
Conflicting information about maximum memory allowed
Please can you help me; I want to increase the RAM on my Evesham Axis 64 MKR but on this site it says the maximum RAM is 8 GB, on the MSI (motherboard) site it states I can install 2 GB of DDR400 or 3GB of DDR333. Can you tell me which is correct?
Will any generic memory be compatible with this computer (something I can pick up from PC world like PNY) or should I stick to a brand like Kingston, Elixir or Crucial?
Thanks in advance for any help.
Regards
Jim
  • 115 Answers
Your problem is not so clear. I guess you are having a P-4 with MSI Mother board. Almost all motherboards that support DDR 333/400 can support up to 2 GB of memory.
It is always better to buy brands like kingston.
Posted on Dec 17, 2008
Vram
You maybe able to increase the video RAM in the BIOS setting.
The on-board video card uses shared RAM, if you allocate more video RAM then the memory available to the computer/laptop will be reduced by the same amount of RAM, unless you install more RAM.
Jul 01, 2012 | HP Computers & Internet
My notebook is a HP G42-372LA, and I need to know which is the maximum frequency in the ram that I can put?
Maximum RAM supportedUse the table below to determine the amount of RAM memory that is supported on your HP notebook PC. Operating System Amount of RAM memory supported Windows XP 1-2 GB Windows 7 and Windows Vista 32-bit 2-4 GB (Only about 3 GB will be used by the operating system) Windows 7 and Windows Vista 64-bit Any amount of RAM is supported by the operating system.Ordering replacement RAM memory
Please let me know if this washelpful and if it solved the problem! Also if the information provided washelpful, please click on the appropriate thumbs to make us aware that theproblem has been corrected or that the information provided helped you with theproblem.. Thank you and Good Luck.
Sep 11, 2011 | Computers & Internet
Can it support expanded ram - what is the upper limit on ram capacity
below are the specs for your laptop,
Standard Memory 64 MB (non-removable) Maximum Memory 192 MB Memory Expansion 1 socket Memory Comments PC100 SDRAM SODIMMs CPU Type 650MHz Intel Mobile Pentium III Model Comments 100MHZ FSB
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
buy more ram here: http://www.memorystock.com/orderitem.asp?it=330ms-069&MnfId=&MdlId=22646
May 20, 2010 | Toshiba Satellite 2775XDVD Notebook
I wanted to upgrade the memory from 1Gb(in two 500mb slots) to 2Gb so purchased 1Gb Crucial memory. If I put the additional memory in one of the two purple slots computer will not work. If I replace one of...
how may slots do you have??
if @ slots are there then convert your ram or replace it with 2 Gb and the 1 Gb othr......or make the 500 Mb convert it by ur dealer to 1 Gb whole...
Feb 15, 2010 | Evesham Axis 64 3200+ Choice...
I need to replace the small motherboard fan. Any
Hi friend,
Yes this is easy task,if you wand to change the motherboard fan than firstly remove the power cord in CPU,pull out the side cover of CPU and than you see the motherboard fan in front of you,Two fans available in system one is CPU FAN and another is motherboard FAN,you need to change motherboard fan,this is attached in motherboard with two iron stick,press the both stick through thumb and press the upper,now you remove the older motherboard fan and fix the new one.after fix the new fan press both iron stick and fix it.
plug the power cable and switch on the system.
Thanks,
Jan 16, 2010 | Evesham Axis 64 FX (AXIS64FXMAR04) PC...
New graphic card for Evesham Axis 64 3200
Are you asking about upgrading your graphics card?
Aslong as you get a graphics card that is AGP connection you will be fine.
They dont make AGP graphics cards anymore, but one of the last ones made (and most powerful is the Nvidia 7950 AGP) can be found all over ebay.
Its not a cheap card though, and a later edition nvidia 6 card would be just as good for you, such as an Nvidia 6800 AGP graphics card
Jan 02, 2010 | Evesham Axis 64 3200+ Choice...
I want to upgrade my Evesham Axis 2600 with new motherboard & processor to speed things up? Any suggestions please?
Selecting your Motherboard is the most critical. CPU is Last except for Dual Core. If you are on a Budget, I have a rule of thumb: $100 for Motherboard, $100 for CPU, $75 for Hard Drive and $75 for Memory. Reccomend: NewEgg.com - Asus MB, Min 2.8mhz CPU, Ram over 4 can be a waste unless you are a power user. RAM wont help speed too much more, and a Seagate HD SATA 3.0 a Gig is plenty. Dont use your old hard drive except for the backup. Always be able to go back to your old system until you are done. Hansel and Gretel Rule !
Dec 31, 2009 | Evesham Computers & Internet
Its a NVIDIA nForce2 with dual channel DDR & USB 2.0 It has two slots one purple one green. I have replaced the 2gb sticks and it no longer beebs but won't boot and monitor says "no input" replaced the...
From the information you sent, I can't figure out the exact make & model of your motherboard, but I would guess that it supports a maximum of 2 GB of RAM. So, I would suggst you try to install 2 RAM modules, each of them 1 GB in capacity & see if this works.
From my previous experience, most motherboards with only 2 slots for RAM modules support only a maximum of 2 GB RAM total.
Nov 04, 2009 | Kingston 1GB PC2700 DDR DIMM Memory
My 5 year old Axis 64 Dominator (AMD 64 3500+ is getting very slow. Is it worth tackling this by a software clean-up & what would you recommend. Should I upgrade hardware, so far only RAM has been...
If it is getting very slow at booting up and doing everything it is well worth wiping the hard drive and reinstalling the operating system. Your performance should then be the same as it was when new.
If it is only slow at running the latest graphic-intensive games you should upgrade hardware. Processor, video card, and faster ram will give you the best improvements there.
Jul 18, 2009 | Evesham Axis 64 3200+ Choice...
Cannot locate access to memory slots in order to upgrade RAM on Evesham Voyager 64 laptop.
The Voyager would have been even faster with more than the supplied 512MB of memory - you can't upgrade this yourself, but Evesham will supply 1GB as standard for an extra £89.
http://www.evesham.com with the limmitted memory capacity, i would definitely turn off all unused open programs and services you dont need in windows. you may do this and realize you don't need more memory.
Oct 23, 2008 | Evesham Computers & Internet
Evesham Axis PC Desktop Logo
107 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
