Question about Bosch 24 in. SHU43 Built-in Dishwasher
My bosch dishwasher handle is loose
How do I tighten it?
  • 171 Answers
Hi rsouthwick,
I'm Harvey the Master Plumber.
You want to know how to tighten a bosh d/w handle?
Easy! open the door and look around the perimiter. You'll see screws on the right and left, they hold the front panel on. Simply remove them. The front panel is off and you can tighten away!
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
Bosch refrigerator door handle is loose
there is only one screw on the handles from what i found out from fixing my loose handle. the bottom of the door handle has one screw. once you loosen that one up then you lift it and it comes out at the top enough to slide the handle out and tighten it.
Aug 03, 2014 | Bosch Evolution 800 B20CS80SNS Stainless...
Loose door handle
Here is the link to the installation manual; pages 14 and 9 of the manual (16 and 11 of the pdf) describe how to remove the toe panel, and the door facia panel. You should then be able to access where the handle is attached. Hope this helps :)
Jul 15, 2007 | Bosch SHV46C03 Built-in Dishwasher
My bosch dishwasher (SHX46A05UC) has 2 problems:
there is not a manual for that kind of troubles,,,about the propeller is atached to the upper rack wout tools,,remove the plastic frame is in the lower of the upper rack and assembled backusing only your hands...theouter handle ...inside around the door have scrws remove thoes,you can see the loose srews of the handle,,
Feb 06, 2013 | Bosch 24 in. SHX36L05UC Stainless Steel...
Door handle loose
Problem fixed, finally figured out that there are allen wrench tightened connectors on the sides of the door.
Feb 06, 2010 | Bosch SHU9915UC Dishwasher
Front handle is loose on my bosch dishwasher.., how do I tighten it?
remove srews that hold inside panel should give you acsess to handke tighten and replace screws
Dec 06, 2009 | Bosch SHX43M05UC Built-in Dishwasher
Loose door handle on bosch integra ltd. dishwasher
you can loosen the inside of the door with a small torx screwdriver and lift it up far enough to get to the screw that holds the handle from the inside. I did this with mine about 1 year ago.
Aug 30, 2009 | Bosch Integra® 500 SHX46L Built-in...
Hi,I have a Bosch dishwasher SHY 66C02 UC and the handle is loose. What do I need to remove to get access to the front panel? Thanks, Will
u have to remove the torx screws on lhs and rhs of the door and a also at the top of the door.once u remove them the front panel will come out and u can tighten the handle screws.good luck.
Aug 18, 2009 | Bosch Dishwashers
Bosch Door Handle: Loose
I had the same problem with my Bosch dishwasher.I came to this web site to find out how to get the door off.I took the experts advice,placed 4 pillows on the floor in fromt,opened the door,took out the screws and the front panel dropped down.It was so easy,the plastic spacers stayed in place.I put a little J B weld on the handle screws and tighted the handle and put everything back together,12 minutes tops.Thanks for the help,thankful in Georgia
Jun 09, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Handle coming loose
If you only remove the 4(T20 torx) along the flat edge this will only remove the outer door panel. Start from the top and work down. Also if yours has 2 blocks that fall out, they go on the hinge only 1 way.
May 10, 2008 | Bosch 24 in. SHX36L05UC Stainless Steel...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
365 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
