Question about Kenmore Kitchen Ranges
Kenmore double over
My oven is flashing the letters FO and beeping all the time. The oven will not work either.
    Sergeant:
  • 409 Answers
F0 or F1 usually means you lost power and may not even realize it. even if you don't loose power, you may still get a brown out, which is direct in the eletrical current.
have a technician come in for this one and check the clock.
Posted on Sep 13, 2008
I have a Kenmore double oven model #911.41185992 and it is reading a code of "fo". There are times that it beeps when trying to set the temp in the oven. If I turn off the power from the electrical panel...
The "F0" fault code is indicating a shorted OFF key pad. A technician would determine if the problem is the Key panel or the Control board by disconnecting the ribbon connector and measuring the flat cable pins 13-14. It should be open and should measure between 100-150 ohms while pressing OFF key.
He would disconnect power to range before testing the key panel.
I recommend calling a service technician to diagnose and repair your range
Mar 05, 2018 | Kenmore Ovens
I have a Kenmore 30" double wall oven model no. 911-41185. It will not let me do anything and keeps displaying FO and beeping. Can you tell me what is wrong?
F0 means no error. press cancel to clear display.
If you cannot then that key might be stuck, just a guess. I have your tech repair manual with failure codes and troubleshooting on page 43. This NOT a user guide. It is meant for qualified peeps. So be careful. Late model double oven tech repair manual HERE
Feb 06, 2010 | Ovens
Kenmore double oven keeps beeping and shows error code FO
Hello there:
F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Dec 31, 2009 | Ovens
I HAVE A KENMORE DOUBLE WITH FO AND BEEPS HOW DO I
Try this first! The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Oct 13, 2009 | Kenmore Ovens
The upper and lower oven will not turn on there is power to it and clock and oven lights work there is an FO red light that comes on and beeps and flashes
Built In Oven Fault Codes
F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Sep 21, 2009 | GE Profile JTP56 Electric Double Oven
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
My oven wont quit beeping!
if it is an E0-F2 error code then i believe it is for a bad control or keypad.. i would replace both.
Feb 13, 2009 | Ovens
JTP56 Double Oven Beeping and Display FO Code
http://www.fixya.com/howto/h155060-dreaded_f7_error
May 18, 2008 | GE Profile JTP56 Electric Double Oven
Kitchen Ranges Logo
106 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
