Question about Maytag MMV5165 Microwave Oven
Maytag Microwave MMV5207AAQ control problem.
Just looking for a little advice. I have a Maytag Microwave MMV5207AAQ and the control panel doesn't function properly. I know the 2, 3 and STOP/CLEAR buttons don't work when depressed. When first plugged in the microwave asks for the time of day to be set. When the time of day is put in and enter pushed, the microwave starts cooking. The Sears parts page list the front control board for $51.99 while the other two circuit boards are $189.49 each. I'd like to fix the problem on the first try, hopefully the $51.99 control panel will do the trick. I would appreciate any ideas as to what is causing the problem. Hopefully someone has seen this problem already. The microwave is about 1 1/2 years old. Nuke.
    President:
  • 878 Answers
Nuke, Sounds like your touch pad is going south. Why dont you kill the power, drop the control assy. and unplug the ribbon of the control panel to the board. Take an eraser and clean the ends of the ribbon where it connects to the board. Put it back in and see if that made a difference. If not I would suspect it's the touch panel. The part number I have for this is 53001508. Good luck.
Posted on May 15, 2006
The bulb that shines on the stovetop keeps blowing in my microwave
Depending on model, it may be a shorting bulb socket.
For free DIY and other help & advice, feel free to contact me via my site below.
Please include FULL model number*, FCC ID number*, and detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 14, 2017 | In Microwave Ovens
its common to all ovens! causes are food spills and oil spills left uncleaned! painting only might fix the problem for a while, but it won't give you a lasting service!!
! you should buy a new rack for much safer use!
keep in mind also to clean the oven after every use! (let it cool first of course!)
Dec 09, 2007 | Microwave Ovens
Maytag Over the Oven Microwave Model MMV5100AA display shows "SE". All touch pads are inoperable. There IS power to the unit.
"SE" means you have a shorted membrane keypad.
You did not give us the full model number. It will be one of these:
MMV5100AAB
MMV5100AAQ
MMV5100AAS
MMV5100AAW
On these models, you would need to order a control panel frame which comes with a new keypad already installed. It's a simple do it yourself fix.
You can look up and order that part from the Pros here, our favorite supplier. If it's not in stock immediately, they will have it to you in a few days.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
Aug 17, 2011 | Maytag MMV6186W Microwave Oven
MICROWAVE DOESN'T GO ROUND HEAT UP OR MAKE ANY NOISE LETTING ME KNOW IT;S WORKING
I'm assuming it's JVM2070SKC02?
No matter, because sadly on the 2070-series ovens, GE does not make repair documents or separate controller parts available.
So you would have to order a whole new control panel assembly at a cost of several hundred dollars.
It looks like yours is a Canadian model, and if so I would have no idea where to get the parts.
Maybe GE Customer Support can help you if it's under warranty or close. Consult your owner's manual.
May 23, 2011 | Sharp R-1510 Microwave Oven
Maytag UMC5200AAW SS # 51285923 Never had any problem until, today it sparked and a small fire out of the top of the cover on the inside top of the right wall panel. We have it built in to a cabnet...
That sounds like a wave guide cover that protects food splatter from getting into wave guide. will need to replace that cover and thoroughly clean inside of unit ans around cover. Those covers must be kept clean and dry!!!
Sep 10, 2017 | Maytag MMV5100A Microwave Oven
I have a Maytag OTR Microwave oven that doesn't work. After I close the door and set the time and start, I see the time countdown, but I don't see the microwave starting. I can get the microwave to start,...
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
See our file on door switches here.
Sep 30, 2010 | Maytag Appliances Over-the-Range Microwave...
Maytag microwave mmv5207
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 23, 2008 | Maytag MMV5165 Microwave Oven
Microwave not heating
It probably has a shorted high voltage diode, a relatively cheap fix.
Here is a link you or someone you know can use for test help, but read the safety warnings first: http://www.gallawa.com/microtech/diode.html
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
Also, you can download Maytag owner's manuals and installation instructions here.
You can find your nearest Maytag-authorized servicer here.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 07, 2008 | Maytag MMV5156AAS Microwave Oven
Matag Microwave MMV5100AAB
There is a short either in the keypad or the power board.  Unfortunately parts for this one are not available anymore.  If you could get the parts it would cost you well over $100 and would be a better idea to replace the microwave.  If this only happens when you add time then I would just use the microwave without using that option.  Would appreciate a solved rating for expert advice.
Oct 26, 2007 | Maytag MMV5207A Microwave Oven
Maytag microwave overheated.
There is a fuse that should be easy to get to behind the control panel.  Will need to take the grill off first to get control panel off.  Make sure unit is unplugged first.  There are high voltage parts in a microwave so you should have a professional do the work if you are not comfortable with it.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Maytag MMV4205 Microwave Oven
Maytag MMV5165 Microwave Oven Logo
250 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
