Question about Hoover Vacuums
Brush not working when the handle is reclined
My vacuum is just a few months old. The belt is good and the brush rotates when upright. As soon as I recline the handle, the brush does not spin anymore. The only way I can get it too vacuum is to extend the handle all the way to the floor, wrap the cord down the back, under the head so it is coming up at the front of the vacuum. I then have to pull on the cord and lift the head about an 1/8 of an inch off the floor to get the brush to spin.
Cannot find anything wrong with it myself and do not want to send it out for repair...how hard can it be to fix a basic vacuum? It was a fantastic vacuum at first and really pulled the nap up and cleaned well...help!!!!
  • 706 Answers
Sonds like you have a problem with the self propel switch in the handle. Since you didn't provide a specific model number, I can only give you generic information on what might be the problem.. Here is a link for a hoover upright model ( may or may not be yours) but it does show the switch in the handle that does sound like your problem... http://www.hoover.com/pdfs/manuals/U6634900.pdf If you can provide a specific model, perhaps I can provide specific details on the repair.. Good Luck !
Posted on Sep 13, 2008
Brush bar stops rotating when I recline the upright part beyond 45 degrees. Brush bar rotates but if I move the machine too far away, increasing the angle it stops. All cleaned out etc
There is a switch in the ball which is activated as you pull the handle back from the upright position. The lever that activates the switch pivots as the handle rotates backwards. Try to determine if this lever could be broken or mislocated somehow..
May 02, 2016 | Dyson DC40 Multi floor Upright Vacuum...
Brush is not rotating
Hi Barbara, it's Jack at Dyson.
DC33's brush bar will only rotate when the vacuum cleaner is turned on and reclined into the normal vacuuming position, and the brush control is set to 'Carpets':
If the vacuum cleaner is standing upright, or set to 'hard floors', the brush bar will not rotate.
If you're confident the brush control is set correctly, but the brush bar won't rotate when the machine is turned on and reclined, please contact our experts directly so we can talk you through some further troubleshooting checks. If a repair is needed, we can also confirm if this is covered under your Dyson warranty.
You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 08, 2014 | Dyson DC33 Multi-Floor Upright Bagless...
Brushbar not turning
Hi there, it's Jack at Dyson.
DC03 doesn't use a traditional user-replaceable belt. Instead it has a brush control clutch mechanism which allows you to turn off the brush bar when cleaning hard floors and delicate rugs.
If the brush bar doesn't seem to be rotating, it's worth double-checking you have the brush control set correctly. When the machine is reclined into the normal vacuuming position, the brush control should move to the Drive/On position:
Please note, as a safety feature the brush bar will never rotate when the vacuum is standing upright.
If you're confident the brush control is in the correct position, but the brush bar still won't rotate, please give our freephone UK Helpline a call on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
Sep 16, 2014 | Dyson DC03 Bagless Upright Cyclonic Vacuum
All belts are good but brush will not turn
Hi Nabil, it's Jack at Dyson.
If you have a DC14 and the brush bar isn't rotating, it's worth checking to make sure the brush control on the cleaner head is set to 'Carpets', and not 'Hard floors'.
http://www.dyson.co.uk/support/dc14/dc14-all-floors/my-machine-is-not-working/i-can-see-something-wrong-visual/i-can-see-something-wrong-visual/my-brushbar-is-not-rotating2/does-the-brushbar-turn-with-the-power-on
Tip: The brush bar will never rotate when the machine is standing upright, so make sure you recline it down into the normal vacuuming position before testing it.
If you're confident the brush control is set correctly, but the brush bar still won't rotate when the vacuum is reclined, please get in touch directly so we can help further. You can reach our experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 19, 2013 | Dyson DC14 All floors Bagless Upright...
Brush roller will not rotate on Dyson dc04 absolute
The brush will not rotate when the machine is upright. The brush only rotates when it is reclined; in use.
On the side of the housing where you place your foot to recline it is a round knob. Turn it one click clockwise if you can; to the "auto" position.
If the brush doesn't turn then when the machine is reclined, it needs attention to the belt and/or clutch mechanism.
Jan 13, 2011 | Dyson DC04 HEPA Bagless Upright Cyclonic...
I think it is missing the belt. How do I put one on it. It has no suction power.
Remove the three screws on the top of the vacuum base. You may need to recline the handle to the lowest setting as if you are going to vacuum under a bed. Turn the height selector to the side (either right or left), lift off cover of base. Your belt area should be to the right side. Hook new belt on the motor shaft at the back...it kind of looks like a nail sticking out. Pull the brush roll out, clean off any thread, hair, etc. Place grooved end of brushroll in loop of belt, replace brush roll, stretching belt into place. Rotate by hand a few times to make sure belt stays straight.
Sep 12, 2010 | Eureka 5856BVZ Boss Bagless Upright...
Dyson DC25 rotating brush doesnt work
There is a reset button on the side of the brush bar head. Press it.
Jul 11, 2010 | Dyson DC25 All Floors Bagless Upright...
My boss model 5892 brush will not roll
This unit has a reset button on the side of the hood. Recline handle, turn power switch on, pressing down in carpet mode, press reset buttonon the side of the hood, the brush should turn on.
May 01, 2010 | Eureka 5856BVZ Boss Bagless Upright...
Bosch vacuum
check the belt, it might be stretched or broken
or carpet fibers and hairs may have clogged up the brushes to keep them from rotating
let me know if this isn't the problem
Mar 22, 2008 | Bosch Turbo Jet Bagged Upright Vacuum
Brush stops
This really sounds like a belt problem. Even if it looks OK, it may have stretched. New belts are cheap, and you'll need a new one eventually - if the old one turns out to be fine, you can always keep it as a spare. A second possibility is this: Many cleaners have a control which allows you to switch off the brush/beater bar so you can clean wooden floors without damaging them (for instance, mine has a pedal-operated bar which shunts the belt between two adjacent pulleys on the brush roller, one of which is properly keyed on, and the other of which is a loose fit allowing the roller to idle. If you have something like this on your cleaner, check you have the brushes switched on, and that the mechanism is working properly. A.
Apr 13, 2007 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Vacuums Logo
61 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
