Question about SanDisk Sansa e260 MP3 Player
EQUALIZER My music sounds like it is far away. how do i set the equalizer? I have the Sandisk 4GB.
  • 8,596 Answers
Main Menu --> Music --> Music Options --> Music EQ
Have fun!
-Tha Mp3 Doctor
Posted on Sep 13, 2008
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
May 09, 2016 | Pioneer Audio Players & Recorders
42" LED42C45RQ need volume configuration
Hi Jennifer,
Settings of bass, treble and equalizer is a matter of personal choice. You can set them to your liking. Alternatively you can choose the sound mode ( like music, movie and theater ) of your choice. The balance setting off course must be in the middle or zero position so that both the speakers give equal amount of sound. In equalizer the extreme left column represents the low frequency sounds like the sound of drums. As you move rightwards the sounds go on becoming finer and finer and the extreme left column represents the fine sounds of the instruments like violin and sitar. Somewhere in the middle is there is human voice also. Play some music, try varying each column and see the effect. Good luck.
Jan 19, 2014 | RCA 42" LED42C45RQ Class LED 1080p 60Hz...
The volume on my sony nwz~e453 is too low
Go to your menu, go to settings, then common settings, then look for AVLS, this is ( Volume Limit) turn it off. Then you can go to music settings and equalizer then go to custom and set the sliders as far up as they will go. Save that an use it. Now your ear buds have a lot to do with how loud your music sounds, the better the ear phones the louder the music sounds. Hope this helps Fix Ya up.
May 26, 2011 | Sony NWZ-E436F MP3 Player
No audible voices
The problem sounds like a setting miss match , with music it is not so noticeable as it is louder and has higher spectrum of sounds , but with monoliphic voices you pick out the disinction more check your sound utilities program particuarly the graphic equalizer if it has one windows does in sound properties and advanced setings if you have a seprate sound utility ie: hd sound etc check that your effects settings havent been changed ...Regards Vortash
Jan 27, 2009 | Pioneer CDJ-800 Turntable
No word just music when i listen to my itouch through my headphones---music sound real far away, like it is echoing in a long hall.
Wacky.  What headphones are they and what player are you using?  If you somehow were gifted with grados, you might need a headphone amp; but as it is, it sounds like the settings on it are messed up; reset the equalizer and headphone-bass-expansion, maybe flash the unit's firmware, and see if things change.
Jun 27, 2008 | Audio Players & Recorders
Helo i have got a nokia 5300 black express music phone and i brought these mobile phone twin music speakers for them but i dont know how to set them up so please can u help me thnks
Equalizer
You can control the sound quality when
or diminishing frequency bands.
Select Menu > Fun & Apps> Media > Equalizer.
To activate a set, scroll to one of the equalizer
To view, edit, or rename a selected set, select
Not all sets can be edited or renamed.
Stereo widening
Stereo widening enhances the audio output of the phone by enabling a wider
stereo sound effect. To change the setting, select Menu > Fun & Apps>
Media > Stereo widening.
Mar 25, 2008 | Lands Phones
Can't hear vocals
If you have a equalizer setting then you need to access it and increasy the middle sliders. It could be you accidentally altered the equalizer setting/mode.
Dec 22, 2007 | Memorex MMP8565 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
55 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
SmartAviator
SmartAviator
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
