The detergent dispenser does not release/open for our Chef Select dishwasher, so the dishes do not get properly cleaned. Any ideas on why or if it can be easily fixed?
Comments:
May 15, 2006
- Thanks so much catriver. Any hints on where the wax motor is located?
The detergent door on this model is operated by a wax motor. It can be tested by using a power cord across the two terminals of the wax motor and plugging it into a 120v outlet. The plunger of the motor should push out in approx 45-60 seconds, opening the lid. Use extreme care if testing it this way. The part number for the wax motor is 902899. You also need to look at the linkage where the motor connects to, making sure everything is intact. If you would rather not fool with the thing, you can always pick up detergent tabs that are just added to the bottom of the tub. Hope this puts you on track.
my dishes are dirty and the glasess have ground up food all over the out side and the bottom that is...
(More)
my dishes are dirty and the glasess have ground up food all over the out side and the bottom that is standing up...I have used the cleaning stuff twice and it is still not cleaning. This Magic Chef came with my double wide in 87. I cannot find the manual....
Did not finish the cycle last night but continued to make the sound as if the pump was still...
(More)
Did not finish the cycle last night but continued to make the sound as if the pump was still going.Ther was no water in the machine and the motor noise kept going even when the dishwasher was turned off on the appliance. I have cleaned the inlet filter but did not fix the problem
Hello Mr Fixit, When I turn the dishwasher to the normal clean cycle, I can hear it very quietly...
(More)
Hello Mr Fixit, When I turn the dishwasher to the normal clean cycle, I can hear it very quietly moving around, but nothing sees to happen. There is water pooling at the bottom of the dishwasher at a level which is not normal. I have cleaned out the filter and fished around a little. Nothing really obvious, although I am not a Top Dishwasher Expert! Hope you can help Vincent
I had my kitchen drain snaked. When I tried to start the dishwasher, the water entered, but it...
(More)
I had my kitchen drain snaked. When I tried to start the dishwasher, the water entered, but it didn't start the washing cycle. The water did not drain either...
