Driver door lock switch
Front passenger door lock switch
Door lock actuators in each of the doors
Door lock system fuse into the BCM (BCM D 25A fuse)
Door Lock Operation
When the BCM detects a transition of either of the door lock switches to the LOCK position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the Lock position.
Driver Door Unlock Operation
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the LF door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked seperate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed). This video on testing computer controlled door locks on a Subaru , doesn't matter . test yours same way > The BCM controls your door locks .
Are all of the power door locks inoperative from both door lock switches?
Passenger front door lock switch
LH rear door lock switch
RH rear door lock switch
LH middle door lock switch (w/ V4U)
RH middle door lock switch (w/ V4U)
Driver door switch assembly (DDSA)
Driver door module (DDM)
Passenger front door module (PDM)
LH rear door module (LRDM)
RH rear door module (RRDM)
Left middle door module (LMDM) (w/ V4U)
Right middle door module (RMDM) (w/ V4U)
Driver door lock actuator
Passenger front door lock actuator
LH rear door lock actuator
RH rear door lock actuator
LH middle door lock actuator (w/V4U)
RH middle door lock actuator (w/ V4U)
Driver door cylinder unlock switch
Rear integration module (RIM)
DRVMDL fuse (10-amp)
PASS MDL fuse (10-amp)
RRDR MDL fuse (10-amp)
Class 2 serial data link
All power door locks not working on Honda
Accord?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
