Question about Sub-Zero Refrigerators
MY SUBZERO 532 REFRIGERATOR SIDE EVAPORATOR ICES UP. AFTER A MANUAL DEFROST IT WORKS FINE FOR FIVE OR SIX DAYS, THEN I BEGIN TO NOTICE A LITE FROST STARTING ON THE BACK WALL. A TECH THOUGHT IT MIGHT BE A FREON LEAK (I FREAKED OUT AT THE ESTIMATE) NOW IT IS ALMOST ONE YEAR LATER. THE REFRIGERATOR STILL COOLS EVENLY UNTIL THE EVAPORATOR GETS FROZEN UP. CAN A LEAK BE THAT SLOW BECAUSE AFTER A YEAR AS IT SEEMS THERE STILL IS COOLANT IN THE SYSTEM? ? ? I THOUGHT IT MIGHT BE A FAN (THE ONE AT THE TOP OF THE REFRIGERATOR BEHIND THE LIGHTS) OR THERMOSTAT PROBLEM AND GOT THOSE REPLACED. IS THERE ANY KIND OF DEFROST CYCLE IN THE 532???
  • sharon764 Sep 15, 2008
    Dear Doc John
    A manual switching off for an hour got rid of frost. The refrigerator doesn't seem to cycle off even tho a new sensor has been put in place. This am the temp was 29 degrees (no freezing, thankfully) even tho my temp dial was set at ONE. I appreciate your suggestion about the defrost timer. I did locate it, as you said, on top near the compressor. The wiring schematic was also up there and I checked that out.
    The defrost timer according to the specs for the 532 is connected only on the freezer side and its freezer compressor via the purple wire. I'm no electrician, am not educated in such things. The schematic show a "refrigerator control" (would that be the temp sensor assembly?) which is wired to the fan switch and fan motor and to the refrigerator compressor via the compressor starting relay. Could a relay defect keep the compressor running and not shutting or cycling off? Is that possibly another place to consider? Just asking. I don't know much 'bout nuthin'.
  • 943 Answers
Hi thanks for the question you do have a no defrost problem The defrost timer is not advancing to the defrost cycle The timer is located on the top where the compressor is located do ypu have an owners manual if you do you should have a bresk down of that fridge So replace the timer thanks The appliance doc
Posted on Sep 12, 2008
My ice maker not making enough ice . I have already check the water. thank you
When an icemaker slows production, the problem is not the icemaker at all but the temps in the freezer warming up because of an airflow problem either in the freezer compartment evaporator coils or underneath the unit that being the condenser coils. (Fan not working or lint blockage)
Airflow problems in the freezer compartment are caused by the fan or the automatic defrost system not functioning properly so yu end up with an ice block / lots of frost in the freezer compartment on the back wall of the compartment.
Check for ice or large amounts of frost in the freezer compartment. If you note ice / excessive frost, unplug the unit, empty the freezer compartment and do a manual defrost by directing an external fan into the compartment for just over 2 hours. This will ensure the evaporator coils and the freezer compartment drain have thawed. While the manual defrost is in progress remove the rear fiberboard cover from the compressor access and check / clean the condensor coils and fan area.
After 2 hours clean up the excess water.. reassemble the rear cover and return the unit to NORMAL service. It should start making lots of ice in 4 to 6 hours. Here is the kicker... if there is an auomatic defrosting problem your icemaker will after 2 - 3 days again slow ice producion and ice will build up in the evaporator area. You will have to keep repeating the manual defrosting process every 3 to 4 days until the automatic defrost system is repaired.
There are 3 main components of the Automatic defrost system:
1. Defrost control
2. Defrost heater
3. Defrost thermostat or depending on type thermistor
Most of the time the problem is either the defrost control or the heater that fails and the unit stops defrosting.
Your parts can be found here:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LSC26905TT/3204/0165000
Thanks for choosing FixYa,
Kelly
Jun 23, 2011 | LG LSC26905TT Side by Side Refrigerator
I have a maytag MSD2456DEB...the freezer keeps icing over and stop cooling about every five days..any ideas
if it's ice check the drain if it's frost you have a defrost problem which is three things to check, defrost control, defrost t-stat and defrost heater
Nov 17, 2010 | Maytag MSD2456G Side by Side Refrigerator
Sub-Zero 590
Ignore the fan operation... That is perfect.
You are likely experiencing a DEFROST failure
(most commonly a defrost timer failure)...
part number 3081180 item 69 on your exploded
top view (top right side as viewed from the front).
There are typically only three (3) elements to a DEFROST
circuit:
- Defrost Timer (as noted above)
- Heater element to WARM the EVAPORATOR
- DEFROST thermostat... inhibit excess heat
(closed circuit at freezing - Opens at room temperature)
Check your defrost pan...
there should be water there DAILY...
IF not: you are assured that your DEFROST fails.
Per YOUR DESCRIPTION...
You need to look for a SUDDEN REASON (huge air leak)
why FROST would form so quickly...
USUALLY a big pizza box... BUT ANYTHING blocking a
TIGHT DOOR SEAL will cause massive frosting.
It is taking moisture from the WARM ROOM AIR and blocking your evaporator...
Yes ... all INTERIOR panels must be in place for the refrigerator to function properly.
guaranteedparts.com http://www.guaranteedparts.com/picture_library/Subzero/Subzero-500%20Series/590.pdf
Sears
http://www.searspartsdirect.com/refrigerator-repair/symptom/REF0003.html
Carnac the Magnificent
Apr 06, 2017 | Sub-Zero 690 Side by Side Refrigerator
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Subzero 532 fridge is warm/ice on inside back
the stop leak works if its a very small leak only. partial charge is just topping off the freon. would give the stop leak a shot first. about $70 bucks a can.
Jun 08, 2009 | Refrigerators
GE g2220iephww Refrigerator too warm at top, too cold at bottom.
If you are manually defrosting by turning the refrigerator off or unplugging to defrost, then you've got one of the following -
1) Defrost heater has failed
2) Defrost sensor has failed
3) Defrost timer/refrigerator control has failed.
As ice builds on the evaporator, if not defrosted properly, the accumulated ice restricts airflow through the evaporator, which reduces air flow and air velocities through the box. Lower velocity allows the cold air to fall to the bottom of the box, warmer air to the top of the box.
Dec 26, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
GE side By Side GSS22JEMDWW
Maybe but there is also a thermister in the defrost system that might be bad. The thermister is a small, white, barrell shape and is as big around as a pencil, It has 2 wires going in it and is attached to the top of the coils in the freezer.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
960 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
