Question about Sony KV-VF14M40 14 in. TV/VCR Combo
Tv wont turn on ???
Hi , the standby light is blinking 4 times continuously .cannot turn on manually .the remote tries to turn on but goes back to flashing light ??? thanks for any replies Biffo
  • Paul griffiths May 15, 2006
    Thanks you for your time Cheers Biffo
    President:
  • 3,130 Answers
Sounds like a power regulator problem, a horizontal drive problem,or the horizontal output is shorted because of a bad flyback transformer. If your not a technician there are no user serviceable parts inside these sets and i would advise you to take the set to a pro and have it diagnosed as you could get seriously killed fooling around inside of a tv set. God Luck
Posted on May 15, 2006
Standby light flashes 4 times
One option to try is to try to factory reset the tv, to do this turn the tv on hold the Down Arrow on the remote and while doing this press the power button then release the down arrow button.
Bit of info on your issue
* Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Trend to find everything
Oct 04, 2014 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tele turned itself off, red light blinks 4 times then pauses and blinks 4 times again.
You can try unplugging it for a while and then plugging it back in, but according to the manual, the standby LED:
Lights up red when your TV is in PC power saving mode. If the LED blinks in red continuously, this may indicate the TV needs servicing.
(Operating Instructions, Page 22)
Mar 05, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
While setting up the Crest Universal remote control RCP1F for my sharp TV, I've managed to turn the TV off, but now I can't turn it back on. The TV remains on Standby and turning off the power doesn't do...
OKAY TRY THIS..
DO STEPS 1-3 AGAIN AND ONCE IT TURNS OFF KEEP CLICKING THE CURSOR UP A COUPLE TIMES.
THEN START CLICKING THE CURSOR DOWN SLOWLY TELL THE TV TURNS BACK ON AND ONCE IT CLICKS BACK ON HIT THE TV BUTTON ON THE TOP OF THE REMOTE ..
IF THE LIGHT BLINKS TWO OR THREE TIMES MORE THEN LIKELY YOU'VE PROGRAMED IT =)
AND NOW KICK BACK RELAX AND ENJOY A COLD BEER FOR THE BOTH OF US =)
Nov 18, 2010 | Televison & Video
The tv turns off automatically & standby light blinks 4 times
4 blinks is bad backlight inverter. Download the service manual here:
http://rapidshare.com/files/208591107/KDL40S2000_L5_sm.pdf
Aug 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Standby LED blinks 4 times
4 blinks on a Sony Bravia indicates a backlight/inverter (aka ballast) problem. These ballasts are regrettably only available with an entire LCD panel. :( You may perchance be able to find a parts outfitter online that scraps out TVs and have a used ballast.
Typical backlight problem on an LCD shows up as the screen lighting up for a second or two and going back off. The 4 blinks just confirms your problem.
May 14, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Television will not come on after low voltage surge
Good day.
Check on the horizontal output transistor, vertical transistor, and loose contacts along MICOM and system ICs.
chris
Feb 09, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-VF14M40 14 in. TV/VCR Combo Logo
255 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
