Question about RCA DRC8030N
RCA DRC8030N My unit only recognizes 5 channels when I do an automated channel search. My cable is connected to the ant "in" and the ant "out" is connected to the monitor. The recorder is set to "ant cable". Any suggestions?
  • 981 Answers
That sounds about right if you have cable instead of an antenna cable. If it can't tune anything but 5 channels in, that's all it claims; set it to CABLE IN instead and try that so the tuner can get along with your cable box. If you really do have an antenna hooked up, get it away from whatever's reflecting signal and screwing up reception.
Posted on Sep 30, 2008
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
How do we hook up VCR to TV
  1. 1
    Turn off all of your components. This will help prevent any accidental damage while connecting.
  2. 2
    Connect the RF/COAX Out port on the VCR to the RF/COAX/ANT In port on your TV. Use a coaxial cable.
  3. 3
    Connect your antenna to the the RF/ANT In port on the back of your VCR (optional). This will allow you to watch over-the-air broadcasts through the VCR.
  4. 4
    Turn on the VCR.
    • Make sure that the VCR is plugged into the power outlet.
  5. 5
    Set the VCR channel to Channel 3 or 4.
  6. 6
    Turn on your television to the same channel that your VCR is set to.
  7. 7
    Start playing your tape.
or check this site:
How to Hook Up VCR to TV
May 19, 2016 | Televison & Video
Hi, my problem is only the front 2 speakers work i have tried all the speakers in the front 2 connections of the unit & all speakers are working but none when in the rear, center, & sub woofer unit...
Without knowing which receiver etc you have... make sure your "mode" is set to 5 channel, Dolby Pro or similar. And even then, make sure your source is 5 channel. What are you using for an input cable? It needs to be able to provide 5 channel. Standard RCA stereo type cords do not. You need either optical, "coax" or hdmi. Lastly do you actually have a 5 channel program? Many older movies, and standard cable boxes only output stereo, not 5 channel.
May 31, 2011 | Audio Players & Recorders
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How to program with cable using remote
Hello
1 Find and disconnect the cable that is connected to the
ANT IN terminal on your cable box.
? This terminal might be labeled "ANT IN", "VHF IN" or
simply, "IN".
2 Connect this cable to a two-way splitter.
3 Connect an Antenna cable between an OUT terminal on
the splitter and the IN terminal on the cable box.
4 Connect an Antenna cable between the ANT OUT terminal
on the cable box and the B-IN terminal on the RF(A/B)
switch.
5 Connect another cable between the other OUT terminal on
the splitter and the A-IN terminal on the RF (A/B) switch.
6 Connect the last Antenna cable between the OUT terminal
on the RF (A/B) switch and the ANT IN (AIR/CABLE)
terminal on the back of the TV.
After you have made this connection, set the A/B switch to the
"A" position for normal viewing. Set the A/B switch to the "B"
position to view scrambled channels. (When you set the A/B
switch to "B", you will need to tune your TV to the cable box's
output channel, which is usually channel 3 or 4.)
OK
Jan 01, 2011 | Samsung SlimFit TX-T2782 HDTV
RCA DRC8030N No output
Connect the unit as you normally would using the composite cables. Once you turn the unit on and the RCA logo flashes and then the video *poof*, dissappears, press the Video Out button on the remote control so that the PS OFF (progressive output for S-Video) is shown on the LCD, this should get the video back to normal.
Nov 09, 2008 | RCA DRC8030N
Tv/vdr/cable box
Your hookup is correct- Your VCR needs to be tuned to channel 3 or 4, to match the cable box.
Also, the VCR channel output needs to be matched to the TV. If VCR menu options are displayed on the TV then this part is right. If not, then set either the VCR or TV to the correct channel.
May 11, 2008 | Sharp VC-A420U VHS VCR
RCA television suddenly has problems with cable reception
You have a bad ground connection somewhere. Either the cable has a break in the ground side or there is a connection problem elsewhere. Try with another cable if possible.
Dan
May 02, 2008 | Televison & Video
Using a VCR with it.
Hi, Based on your post/description, a common installation/connection would be: 1. Ant/Cable in to the RF INput of the VCR (this is assuming that your cable TV is cable/F output and not the audio/video RCA output); 2. A short RG59 cable with F connectors at both ends should connect RF OUT of VCR to ANT/CABLE IN of TV. 3. With the VCR off, the cable would connect automatically to the TV and channel selection is thru your TV. 4. With the VCR on, The TV must be set to either 3 or 4, channel selection may be done on the VCR, TV programs can be recorded, video tapes can be played. A variation: Another would be to use the Audio/Video OUTput of the VCR to the Audio/Video INput of the TV (assuming it's got one). The TV must be set to Video to watch cable, VCR. Channel selection would be thru the VCR. Hope this be of some idea/help. Post back should you need additional information. Good luck and kind regards.
Sep 09, 2007 | RCA F25216BC 25" TV
RCA DRC8030N Logo
121 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
