Question about Brother ML-100 Typewriter
"7" Key The "7" key prints two lines rather than a 7. It works fine for the "&" sign. Any suggestions?
  • Brother Master
  • 3,594 Answers
You probably have the "7" spoke broken off the P/W. Replace it.
DickyO
Posted on Sep 13, 2008
How to program bottle deposit on xe-a507
PartsandTheirFunctions Printer cover Operator display Keyboard Drawer Check slot Drawer lock SD card slot (Refer to the "SD CARD Mode" section.) Printer The printer is a thermal printer, and therefore it does not require any type of ink ribbon or cartridge. The average life of the printer is approximately 6 million lines. When removing the printer cover, lift up its rear. When installing the printer cover, hook it on the pawls on the cabinet and shut it. CAUTION:Thepapercutterismountedontheprintercover.Becarefulnottocutyourself. Keyboard ? Keyboardlayout ? Functionkeylist { Receipt paper feed key PLU/sub-department/UPC key } Journal paper feed key Department code entry key Function menu key Department shift key a Auto key CLK# Clerk code entry key w Tax1 shift key Department 1-40 key 0 Percent 1 key FI Cursor (up/down arrow) key - Discount key m Mode key t Void key Escape/Cancel key H Help key X Charge 1 key f Refund key R Receipt print key @ Multiplication key Y Charge 2 key P Decimal point key u PLU/UPC inquiry key l Clear key x Check key 0 9 : Numeric key ; Non-add code/Time display/Subtotal key A Cash/Amount tender/No sale key Displays ? Operatordisplay •Screenexample1(REGmode) Salesinformationarea: When a transaction information occupies more than 2 lines, you can scroll to the direction by using the F I keys. Sales information you have just entered such as items and prices will appear between 1st line and 2nd line. Total is always appear at 3rd line. NumericEntryArea: Statusarea: Mode name Status information Clerk code Receipt ON/OFF status indicator (R) : Appears when the receipt ON-OFF function signs OFF. Sentinel mark (X) : Appears when the cash in drawer exceeds a programmed sentinel amount. The sentinel check is performed for the total cash in drawer.
Sep 28, 2016 | Sharp ELECTRONICS CORP. Xe a203 cash...
Can't reinstall Windows 7 Professional 64-bit because it says key is not valid
You can contact microsoft and they will be able to validate this for you with a new key.
May 15, 2015 | Computers & Internet
Print skips lines when printing email
Try another browser such as firefox, chrome or IE?
Mar 18, 2014 | Computers & Internet
I just want to be able to enlarge my print size
  • Simply press and hold down the "control" key, while pressing the "plus sign" key. Be sure to keep the "control key" depressed while you press the "plus sign" key. Each repetition will enlarge the text. This can make reading small text SO much easier!
  • To return the text back to its original size (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key. Each repetition will decrease the text size
  • Log on to your computer and open the document you want to print. Click on the "Print Preview" button on the toolbar.
  • 2 Click on the "File" menu and choose "Print Preview" from the drop-down list if the "Print Preview" button is not available. The "Print Preview" function will show you exactly what the finished print will look like.
  • 3 Click the "Close" button to close the Print Preview window, then highlight the entire document and click on the "Format" menu. Choose "Font" from the drop-down list and change the font.
  • 4 Click the "Print Preview" button again to see the finished print. Continue to adjust the font size until the print looks good
  • Jun 12, 2011 | Microsoft Windows 7 Professional Upgrade...
    I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
    for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
    Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
    Typewrite keys
    Above the top row of keys are written things, one of them should be KBII Hold the Code key and press that key, now the other symbol will print
    DickyO
    May 20, 2010 | Nakajima AE-830 Typewriter
    Sharp al-1631 copier. drum error code
    You can reset this indicator by pressing these keys in sequence:
    Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
    Note that the Exposure Mode key is the far left key on the panel.
    One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
    Then key in 7 as if to make 7 copies.
    Press print again. You should now get flashing 000.
    Turn machine off then back on and the light should be gone.
    Here it is in a short version:
    C, far left, C, far left, 24, print, 7, print,
    then power off and back on.
    Nov 16, 2009 | Sharp AL 1631 Copier
    Sharp al1631 copier doesn't work after replacing new drum
    Press the following keys in sequence and as fast as possible. Clear, exposure mode (far left key), clear, exposure mode. In other words...clear, far left, clear, far left. The display should go blank if this is done properly. If so then enter 24 as if you were going to make 24 copies, then press print. You should get flashing 000. then enter 7 as if you were making 7 copies, then press print. Should get flashing zero's.
    Hit clear a few times and there you go!
    Here it is in a line:
    "C",far left, "C", far left, 24,print,7,print, CCC or turn machine off then on.
    Good Luck
    Oct 21, 2009 | Sharp AL 1631 Copier
    Sharp copier AL1655CS will not let us copy until a new drum is installed. There is a code to get it going anyway. It limits you to a set number of copies even if it is working fine.
    c photo c photo then prss 24 machine copy quantity key up and down arrow key then press print key press 7 press print key then solve your problem no show any code print fine thanks
    Apr 13, 2009 | Sharp SHP AL1655CS Printer, Scanner,...
    Brother ML-100 Typewriter Logo
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
