Question about Creative Labs Nomad MuVo TX MP3 Player
Will not turn on.
It will not turn on even with a brand new batterie, how do i fix it?
  • 513 Answers
I read of the following fix for the nomad II, you could try and see if it works for you: 1. Turn unit to "locked" position. 2. Hold down the "stop" button. 3. Continue to hold the "stop" button, take the battery out of the unit. 4. Still holding down the "stop" button, put the battery back in. 5. Continue holding down the "stop" button until a screen comes up with "backup code", wait a few minutes and then switch unit to unlock and take out a battery. 6. Put the battery back in and you should have a working unit. There have also been reports of loose terminals within the unit causing the batteries to not make good contact. Be sure the batteries are in tight. Does it turn on when connected to PC? if so you could try updating the firmware. Good luck
Posted on May 16, 2006
Change spark plugs on 2003 mitsubishi eclipse
My 2001 mitsubishi eclipse spyder will not turn over it cranks but wont turnover i have spent nearly 1000 trying to get it fix the started battery alternator is brand new even the battery is brand new fuel pump is new i just order a pcm for it cause a giy said that the diag read poor circulation to battery back up so i dont know what could be the problem any one with advice pls email me jamesknight618@gmail
Apr 16, 2012 | Cars & Trucks
My Fuji Finepix S5800 tells me my brand new batteries are flat.
It sounds like you have bad batteries. I have had rechargeables that have suddenly done the same thing. I have learned that buying really cheap ones doesn't work out. If you buy a good branded set, I think you will find that they are much better. :)
Jul 17, 2010 | Fuji Finepix S5800 Digital Camera
New battery is considered Empty
Some cameras, even the expensive Nikon professional cameras have the same problem. Sometimes turning it on and off fixes it, sometimes removing and reinserting the battery works. Sometimes, going into the menu and finding "reset" works.
Feb 11, 2010 | Olympus SP-310 Digital Camera
IT WONT WORK !
This is the support site:http://www.magicsing.com.ph/faq.html#5 Have you tried resetting to the default settings?
Aug 09, 2009 | Magic Sing Along Consumer Microphone
Camera immediate shuts off after turning it on
try using lithium or nimh rechargeable batteries. I had the same problem and switched out the batteries and put in eveready nimh batteries and it works fine now. Guess the old cheap ones weren't doing the job. And they were brand new batteries.
Oct 12, 2008 | Nikon Coolpix L11 Digital Camera
WONT TURN ON
Digital cameras really are battery hogs (especially cameras that use only 2 AA's). Some brands of batteries will have problems just starting up the camera. This may be true even if they're alkaline, brand new, and just out of the package.
Recommend rechargeable NiMH batteries only for your camera. Believe Canon even states this in their user manual. Walmart sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
If the above doesn't work, here's some other things to try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 09, 2008 | Canon PowerShot A520 Digital Camera
LG KG800 charging problem.
Hi Robert, actually its LG and the batteries are the worst - i did the same thing with my brand new shine! You need to be careful when you start a new battery - make sure you drain it 100%, then charge for 6-8hrs, then drain 100% then recharge - after that you are good.
a new chocolate battery goes for $25-40
thanks
Jan 21, 2008 | LG KG800 Cellular Phone
Camera won't turn on.
Mine had the same problem.  I consulted http://camerarepair.blogspot.com/ and it said to use rechargeable batteries only.  The entry claimed that alkaline batteries, even if they're brand new, don't have sufficient power for more than a few pictures and may not even be powerful enough to turn the camera on.  I was dubious, but I tried putting in a pair of fully charged rechargeables and, by Gum, the camera was suddenly working again.  So before junking the camera, try investing 20 bucks in a battery charger and a pair of AA rechargeables and see if that fixes it.
Oct 28, 2007 | Fuji FinePix A350 Digital Camera
Creative Labs Nomad MuVo TX MP3 Player Logo
121 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
