Question about Maytag Washing Machines
My Maytag performa keeps going off balance and moving forward. How do I fix this problem
    Genius:
  • 1,028 Answers
If you're sure floor is ok replacing base usually the most likely fix ..the snubber that the unit sits on becomes worn and there have been issues with base from time to time causing it wear
Posted on Sep 13, 2008
I need to know how a maytag performa pavt-1 washer drains. does it drain beneath the agitator or through the holes in the basket?
It drains through the holes in the plastic tub. You may hear a sloshing sound when you move the tub and this is normal. There is a solution sealed inside the tub on this unit to balance out the spin cycle.
Sep 01, 2011 | Maytag Performa PAV2200
Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Feb 15, 2010 | Maytag Performa PAV2200
Inside tub seems out of balance
Item #
1055142 Price
$5.25 In Stock?
Yes Snubber ring, Washing Machine
Brake/bearing removal tool kit: 997909 For extreme unbalance problem this may be needed:
if this part is bad you can order from repairclinic.com
Jan 17, 2010 | Maytag Performa PAV2200
I have a Maytag Performa top loader that won't stay in balance
make sure you locking the legs,
put it in spot tilt it forward so the rear legs are off the ground about 3'' the drop it,, this should lock your back legs and take care that
Oct 06, 2009 | Maytag Performa PAV3200
Becomes unbalanced easily....rocks violently when this occurs
I've been researching this problem with my own performa. So far the only solution I've found that keeps coming up is replacing a part called a snubber. Not sure where that fits in but I'll give it a shot. I've see it go for about $4 - $10 so why not?
Aug 10, 2009 | Maytag Performa PAV2200
Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Jul 05, 2009 | Maytag Performa PAV2200
PAV3300 ( Australia )
there is a plastic piece between the base and the gearbox assembly. it needs replacing as do the springs that go from the base to the washing drum. also make sure the floor is level
Feb 15, 2009 | Maytag Performa PAV3200
Performa spinning banging problem
I assume it is not balanced. Try putting sponges under the feet of the washer.
Jan 06, 2009 | Washing Machines
Maytag performa off balance
Check the vibration dampers and the plastic mounts for wear. They should be solid to the machine.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 05, 2009 | Washing Machines
Washing Machines Logo
199 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
