Question about LG Washing Machines
My LG front load washing machine WD-1016 is stuck shut what can I do
    Genius:
  • 1,239 Answers
Hi There is one r motor problem you can repair yourself. Washer motors usually have an overload protector clipped to the motor. When this component fails, the motor won't work. Before you take the motor in for service, test the protector with a VOM set to the RX1 scale. Disconnect one electrical lead wire to the protector and clip one probe of the VOM to each protector terminal. The meter should read zero. If the needle jumps higher, the protector is faulty and should be replaced. Pry up the protector with a screwdriver and replace it with a new one made specifically for the motor or washer. Connect the new protector the same way the old one was connected .
Posted on Sep 12, 2008
Washing machine
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
LG wd 1460FD is not loading water
Try this.
reset machine. start a quick cycle. Once the pump starts, open door and add 2-4 cups of water. close door.
If machine starts to work the the water inlet valve needs to be replace.
Jan 06, 2014 | LG WD-1280FHD Front Load Washer
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
LG WD-1049C Front Load Washing Machine Pump impeller sloppy
probably better change the pump if you feel any up and down slack in the impellor. you may have an ingress of water through the seal.
Mar 13, 2009 | LG WD-1045FH Front Load Washer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
LG FRONT LOAD WASHER ERROR CODE IE
LG has general error codes for all there appliances and the "ie" error code is for the water supply. You either have a kink in your hose, water vavle shut off, or the bad problem your pump is bad.
Jul 30, 2008 | LG WD-1045FH Front Load Washer
LG Tromm 8/4 WD R8012
The manual suggests to shut the water off ,
remove the inlet hose and check the screen for blockage.
The ie message is the inlet water is insufficient.
May 22, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WD-8074fhb
Your problem is either in the control board or the water level switch.  The computer can't tell if the water has drained or the control board is stuck in the 8 minute drain cycle.  Recommend pulling the plug and wait 5 minutes to reset the computer.  If the problem persists, it will require an LG experienced tech to see what's going on.
Mar 14, 2008 | LG WM1814CW Front Load Washer
Door shut sensor
You may have a problem with the door latch assembly and needs to replaced.
Nov 24, 2007 | LG WD-16110FD Front Load Washer
Washing Machines Logo
91 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
