Question about Mitsubishi WS-65809 65" Rear Projection Television
WS-65809 HELLO, WOULD LIKE TO BUY PARTS FOR MY TV. HAVE HAD TV FOR ABOUT 5 YEARS. IN THE LAST YEAR IT WILL TURN WHITE WHEN WATCHING. YOU CAN GO UP AND HIT THE SIDE OF THE TV, AND THEN IT WILL WORK FINE. I TOOK THE BACK OFF, AND IF YOU PUSH ON THE GREEN BOARD. IT WILL WORK FINE. IN THE PROCESS OF DOING THIS, I HAVE LOST THE RED, BLUE AND GREEN WORK FINE. THERE ARE 3 LITTLE SQUARE DIEODS? I THINK ONE OF THEM IS THE PROBLEM. WOULD LIKE TO BUY THOSE, OR THE WHOLE GREEN BOARD. THANKS VERY MUCH RICHARD
GO TO WEBSITE OF MITSIBUSHI
Posted on Sep 13, 2008
  • TRAVLINMAN80 Sep 16, 2008
    HI BROWN Q- I HAVE THE SAME TV I CAN EVEN GET A PICTURE I PUT A NEW HIGHVOLTAGE BLOCK INTO IT AND STILL NO PICTURE???ANY IDEAS WHAT MIGHT BE WRONG?????OK HAVE U LOOKED IN THE SCHEMATICS OF THE TV???U WILL NEED THOSE LOOK UP THE CAPACITY OF THE DIODE AND U PROBABLY CAN ORDER FROM MITSIBUSHI ,THATS WHERE I GOT MY PART.???LET ME KNOW IF U NEED NUMBER??/THANKS GLENN
Mitsubishi WS 65809 65" Rear Projection TV. Turns
Hello There, Its seems that the circuit board has problems. You'll have to get it replaced ASAP before the board is ruined completely.
The same thing also happened to me 2-3 weeks ago. the techs came in and had to replace the board since 1 circuit was damaged.
It will cost around $100
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial}
Thank you for using FixYa!
I hope that I helped you & that this post is helpful to you at most!
Don't forget to rate! :)
Jan 16, 2011 | Mitsubishi WS-65809 65" Rear Projection...
SCREEN HAS VARIES RED -BLUE-WHITE- LINE SHOWING, I TRIED USE THE
It needs to be repaired by having the convergence ICs replaced or resoldered (if intermittent).
Parts are STK 392-570. Be sure to use thermal paste on the ICs.
Jul 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Where do I buy these little green 125Vac 5amp fuses for a Mitsubishi Ws-65809 tv set?
they are called "picofuses" you may find them at some on line electronics stores like partstore.com or you can call your local electronic supply store.
Jan 12, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Turns of after being watched for several hours.
Do you have the tools required to solder electronics? Do you know how to solder electronics? Have you been trained in CRT safty ? Do you know about High Voltage safty? Is the tv Model number WS-65809? Do you know how to perform static geometry adjustement on a WS65809 if needed? Do you know how to perform static convergence alignment on a WS-65809? Do you know how to perform fine convergence adjustement to a WS-65809?
IF
The answer is :yes yes yes yes yes yes yes yes
AND
You can retreive an error code of 23 or 24 right after the tv shuts
itself off .
THEN
There is a 95% chance that I could tell you what to solder , no parts need to be replaced in your television and you would not have to pay someone to repair it.
Oct 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
What year is the mitsubishi ws-65809?
My model is the same and on the sticker at the rear of the TV w/ valuable info. states 2001 as the year of manufacturing.
Feb 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Flashing power light no picture
We would need to know the model number. you have indicated that it is ws-65809 but i don think this is your model because what you are describing is a bad dm module and the ws-65809 doesn't have one in it. Let me know and I can help your further!
Tim Nolan
Sep 21, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Convergence issues
Drifty convergence IC's need replacing..located on center PC board......STK392-570...change them both for reliability...T.
Feb 28, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Component input makes all pictures black and white?
You can also check to make sure you're on the correct TV input. I've seen this happen if you use S-Video for example, and the TV is set to a composite input by mistake. If you're using S-Video make sure the yellow composite cable is unplugged.
Jan 09, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Convergence ics
www.matelectronics.com Check resisters (low ohmage) in front of IC's, usually discolor or change value.
May 25, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
