FixYa.com
Tags:
Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2400xtpt3 (by 8 users)
posted by pseid on May 14, 2006
Green light flashes, doesn't run, how can I repair this myself?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
7 Other Users Have The Same Problem
Comment by 4tony, posted on Jun 28, 2008
connected to electric supply
Comment by tbum, posted on May 14, 2008
flashing green light not running.
Comment by robrobee_89, posted on Feb 04, 2008
hi i have a whirlpool dwf-415 (854541515760) and it will not take water i know the water is getting to the pipe but it will not go any further can any one suggest anything
i have a problem
Comment by Pakkab, posted on Dec 22, 2007
This solution worked for me as well. And I found this paged while I was on hold waiting to schedule a service visit, THANK YOU!
Best Solution
posted on May 07, 2007
FixYa! (100)
goby
Rank:Apprentice Apprentice
Rating: 100%, 16 votes
I was haveing a problem with my Whirlpool dishwasher. The clean light kept blinking. The control panel was unresponsive save for the drain button. After reading this posting I tried the suggestion on my dishwasher. After pushing the high temp and the dry buttons nothing happened. I kept trying switching from different cycles trying to remember what action I was trying to do the last time I used the dishwasher. Finally on rinse only, high temp, and dry it spun to life. The dishwasher cycled through nearly all the options on the display console for about 5-10 minutes. It looked like a blinking christmas tree alternating through the cycles. But so far so good it seems to be back to normal operations. Thank-you
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 25, 2007
FixYa! (100)
Guest
Guest
Rating: 0%, 0 votes
I didn't find an "AIR DRY", so I pressed high temp & heated dry twice as suggested by catriver...and it cleared after going thru the cycle. Thanks a lot.
Solution #3
posted on May 14, 2006
FixYa! (100)
catriver
Rank:Guru Guru
Rating: 94%, 2548 votes
There was a heater quality rework on this model and depending on your serial number, yours could be included. The flashing clean light is because the thermistor did not detect 2 to 4 temp increase in the water during the first 8 minutes of the wash cycle. I believe you can clear the error by pressing high temp then air dry then high temp and air dry again. This will put it into the service mode. Just let it do it's thing. If you had the rework done on the heater, other possibilities would be door latch not closing proper. The nuetral side of the heater runs through the door switch. Make sure to let the tap water run hot before you start the dishwasher. The heater itself will ohm out at 10 to 35 ohms. Hope the information helps out..
Solution #4
posted on May 15, 2006
FixYa! (100)
dovi
Rank:Guru Guru
Rating: 88%, 2217 votes
One more option (over "catriver" solution) is to check if you have water in the machine. In case there is no water in the machine, let me know and I will instruct you how to go on with problem's solution.
Good luck !
Solution #5
posted on Jul 09, 2008
Not Rated (0)
fireators
Rating: 0%, 0 votes
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
Comment by fireators, posted on Jul 09, 2008
Forgot to mention that this fixed the Dishwasher and it is working now.
This Problem Also Relates To: Whirlpool 24 in. DU1055XTP Built-in Dishwasher Whirlpool 24 in. ADP5966 Free-standing Dishwasher Whirlpool 24 in. DU850SW - Multiple Color Free-standing Dishwasher Whirlpool 24 in. DU900PCD Built-in Dishwasher Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher Whirlpool 24 in. DU950PWKQ - Multiple Color Built-in Dishwasher Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
Can you Help with these Dishwashers problems?
Whirlpool Quiet Partner II...
The locked light remains on. I... Answer This...
Whirlpool Dishwasher
had to replace the discharge... Answer This...
Whirlpool Quiet Partner Doesn't...
My machine GU2455GTSQ0 doesnt... Answer This...
Whirlpool Gold Quiet Wash Plus...
After 3 days without power due... Answer This...
Dishwasher problem
Hi My dishwasher will fill with... Answer This...
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 09, 2007
I had the same problem... clean light is flashing and the washer will not start. Catriver's advice was right on; press high temp, heat dry, high temp, heat dry. All the lights lit up for a few seconds and the dishwasher then operated correctly. Thanks catriver!!!!
Comment by FREAK1, posted on Nov 20, 2007
Ihave a whirlpool model DU1145 - the clean light is flashing . The washer won't start.
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
