Question about Dryers
Creda tumble dryer
My tumble dryer intermittently turns off whilst operating. it will turn back on after approx 10mins then turn off again whilst operating for a further few minutes
  • 209 Answers
SOURCE: Tumble Dryer won't start
assuming what you say you checked is correct and working then the next place to look is the start relay, located behind the front timer control panel, this sis more often than not a cubed shape box made of clear plastic with about 6 spade connectors on it, look for burn marks inside it, replace if looks damaged, do not attempt to bypass or short out to test, as you will blow the timer or and control circuit board and cause extensive damage
Posted on Sep 26, 2007
SOURCE: tumble dryer Creda Smplicity T320VW
I am an authorized servicer for Creda and I can explain how to remove the front panel to change the belt. Email me at starztruck4u@aol.com if you still need help.
Posted on May 19, 2008
  • 1462 Answers
SOURCE: creda tumble dryer repair
with great difficulty - these belts are so tight!there is a special tool for doing it but there are other ways
one way i have used is to make a spanish windlass from belt to bottom of machine. when belt is level with motor spindle, push belt on and release spanish windlass. could also try levering belt on with a screwdriver
another method is to get a short piece of tubing that will fit over motor spindle. put belt over tube, lever down and slip belt on. this is the best way
Posted on Jul 20, 2008
AlmostBob
  • 550 Answers
SOURCE: how to fit a belt
open case
loop belt around bits
close case
more particularly
Unplug dryer
pull dryer away from wall
remove 1 screw each side at back of top plate
slide top plate backwards and lift off
undo 1 screw each side of front kickplate
tlit front panel up
unplug door switch
set front panel aside
careful of control panel its V.fragile
(I lay the dryer on its back)
pull out old belt and bits of belt
loop new belt round drum at wear marks
pull tensioner to end of travel against spring
loop belt round motor pulley & both tensioner wheels(most creda) 1 wheel (old)
relax tensioner
rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
creda uses hotpoint parts
Posted on Oct 31, 2008
SOURCE: drum wont turn on my creda t622cw tumble dryer
my tumble dryer drum wont go round
Posted on Mar 11, 2009
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
Creda T622CW condenser tumble dryer drum wont turn
You need to check if the belt is o/k.
Remove top cover, and grasp belt, it should be firmly wrapped around drum.
If o/k, then could be a motor problem, or programmer fault
Once you have got the drum turning again, it is possible the filter light will go off,if not, then you have another fault
Hope this helps.
Dec 16, 2009 | Dryers
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
CREDA TCR2 TUMBLE DRYER
put it in the bin
Sep 12, 2008 | Dryers
Drum wont turn on my creda t622cw tumble dryer
Nov 15, 2007 | Dryers
Dryers Logo
24 people viewed this question
Top Dryers Experts
