Question about Airnet AER114 Router
Airnet wireless router model #AWR114G
Laptop computer has high download speeds plugged directly into router but when using wirelessly, it is extremely slow. Slower than dial up. Other laptop in house has good speed using wireless or plugged directly in. What might be the problem
4 Suggested Answers
SOURCE: laptop with wireless router connection runs slower than PC wired direct same source
PARAMETROS ESTANDAR DE CONFIGURACION
Posted on Oct 14, 2008
  • 35 Answers
SOURCE: Linksys WRT54GS router is slower than dial up
Initially make a note of the router settings you have configured.
Try restoring the router to factory defaults.
A firmware update may also be worth performing but suspect not unless your ISP has changed the service.
If you update firmware make sure you use the correct version for the hardware you have. The hardware version can be found on serial no. label.
Posted on Mar 18, 2009
Jma11
  • 140 Answers
SOURCE: I put in a high speed motom and now my router has a weak signal. other devices in the same room can only get a weak signal or no signal.
1-Is it a cable modem? The new ones Cox has out are DOCSIS-3 and if your router is several years old you may want to replace it with a router that is designed for DOCSIS-3. I kept my DICSIS-2 router (3 yrs old).
2-You should do a few speed tests to confirm performance then talk to your internet provider about your connection. I had to have Cox come out to check things and they replaced a component on their side.
3-Do have a friend or a neighbor going through the same thing? I did, we compared notes and got to the bottom of it.
Good Luck
Posted on Nov 10, 2013
Good Luck
Nov 09, 2013 | Airnet AWR014G8 Wireless Router
Why does the "7" inch netbook have problem,slow
spyware or a virus check is needed also open the browser goto internet options, conections, near the bottom will be lan settings make sure the box ( automaticly detect settings ) is ticked.
Mar 15, 2011 | Sylvania G-Netbook
I have a D-Link wireless router DIR-655 with 4 computers on a home-based network. Everything worked fine for 9 months at good speed. All of a sudden the internet is extremely slow. My test between my cable...
Get your router a security key(password) just in case your neighbors are use it.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 11, 2011 | D-Link Xtreme N DIR-655 Wireless Router
WRT160N Wireless Router : i just bought a new laptop and a lynsis wrt160n......
The wired and wireless speed will always be different.
The maximum wired speed will be 100 Mbps. That means the wired connection is working properly.
Wireless connection speed will depend on the router and the wireless adapter on your computer.
If you are using B-Adapter then max speed will be 11 MBPS. IF it is G-Adapter then max speed will be 54 Mbps.
The N-adapter will give you more speed.
Check in the Device manager which adapter you are using on your wireless computer.
One more thing you can try changing the wireless channel on the router.
You will need to access the router settings page.
Update the drivers of your wireless adapter on the computer.
You have WRT160N router.
This router has issues with the Firmware.
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. select proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
Click Here for more information about router and networking
May 07, 2010 | Linksys WRT160N Wireless Router
Im only recieving 1020 speed download, when should be atlwast 8
First, if you are connecting to the router with wireless, there are a couple of possible problems. If you are using Wireless B, you'll probably only get around 4 or 5 mbps at best, and even with wireless G, if you happen to have your router set to the same channel as your neighbor or several of your neighbors, it will slow down a LOT and could even have trouble staying connected. To check this, try plugging directly into your router and disabling the wireless on your computer temporarily and run this test again. If it is much better, try changing your wireless channel.
Second, I'm not familiar with this particular model of router, but I've found that many of the cheaper and/or older routers cannot handle the current speeds we see on cable and DSL connections. This could also be a problem with your cable or DSL connection. To check this, you can temporarily bypass your router and plug your modem directly into your computer. Remember this exposes your computer directly to the internet, so it's probably not a good idea to leave it that way. You may also have to reboot your modem and even reconfigure it and your computer to do this depending on your ISP. If it is still slow, you will need to contact your ISP and complain!
Mar 09, 2010 | Belkin (F5D7231-4) Wireless Router
Wireless router type needed for 5.0M internet download speed
Netgear Wireless Router Model WGR614 is a "G"standard Router
It is capable of supporting 5.0M download internet speed
Dec 29, 2009 | NetGear WGR614 Wireless Router
D-link wireless wont work after high speed disconnect.
it's pretty easy to remedy...
1. turn off all computers including wi fi laptops... turn off routers, modem, wifi router as well.
Here's the trick:
Turn on your main router... the one that is plugged direct to your modem.
turn this on before anything else... once it's booted up, turn on your modem... it will cycle up and find the first ip address which will be your router that was turned on previously...
Then turn on all the other routers, wifi computers.... the main router should give all the other equipment their addresses automatically and you should have wireless working at that point...
Good luck... let me know if it gets you up and running.
May 27, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Router connections
Is your speedstream router also your high speed modem? If so, you will have to go into the settings on the Linksys and change its IP Address subnet from 192.168.1.1 to 192.168.2.1 (or you can use a different number than 2) You will then need to reboot both routers (and possibly the computers) and try again. The easiest way to get into the Linksys settings is to connect it directly to the laptop via network cable, then type in 192.168.1.1 in the web browser. No user name and admin is default password. (Make sure you change that, and the name of the wireless, and the security settings)
Good Luck!
Dec 08, 2008 | Computers & Internet
Airnet router
power failure had to change internet password with verizon have to rest my airnet router awro14g/a
May 13, 2008 | Airnet Wireless Broadband Router 108Mbps...
Can it be done?
All of the ps3 models support wired and wireless internet. All you need is high speed internet service, and a router (wireless router if you want wireless internet o.~) you plug the router into your high speed modem via ethernet cable. then you plug your computer and ps3 into the router with ethernet cables. your good to go! if you want wireless for your ps3 you need to use the wireless setup on the ps3. your done :)
Hope this helps.
Apr 06, 2008 | Sony Playstation 3 (PS3) Console
Airnet AER114 Router Logo
221 people viewed this question
Top Airnet Computers & Internet Experts
JP Services
JP Services
Prashant M
Prashant M
Are you an Airnet Computer and Internet Expert? Answer questions, earn points and help others
