Question about Black & Decker BL675 ProBlend Work Top Blender
My blender doesnt lock
The black thing that connects the jar to the base of the blender is broken. It doesnt get locked.
  • 22 Answers
Try going to MarBeck.com they are a great source for small appliace parts.
http://www.marbeck.com
Posted on Dec 22, 2008
Why does my blender leak?
hi,
sounds like the bearing assembly went, right where the motor connects to the blade, you can get a replacement base from them, have to find the model number and go to their website. doubt you burnt it up. cuisinarts supposedly are commercial quality.
jm
Jul 20, 2017 | Cuisinart SPB-7CH SmartPower 40-Ounce...
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
My Cuisinart blender start leaking after a few months of use.
Here is a list of things to check for:
1. Make sure the blender base (black plastic) is tight to the jar.
2. Make sure you have installed the rubber washer between the blender blade assembly and the jar.
3. Make sure your rubber washer is free from any crud that may have accumulated and dried on. You may have to soak the washer and gently scrub with a scrubber sponge. If it's really cruddy you may have to repeat as necessary.
4. Make sure you have not caught any water (or other liquid) when filling it between the base and the jar. When you pour out the contents it will appear as if it is leaking.
Mar 22, 2010 | Cuisinart BFP-703 SmartPower Work Top...
My jar base has broken, where can I find a replacement for model BL600?
Look in the owner's manual for the manufacturer. Call them to ask for replacement parts. Usually they do have a website these days.
Oct 18, 2009 | Black & Decker BL600 ProBlend Work Top...
The plastic threaded base for the jar on this blender haier 2 speed / glass jar is cracked - is part available ? thanks
The base ring part probably is available, however, you MIGHT want to try gluing it with the BLACK ABS plumbing glue. It is surprizingly strong if you have clean break
Sep 16, 2009 | Haier HB500 2-Speed Blender
GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Apr 04, 2009 | Blenders
Locking the jar on the base Oster Fusion 600W Blender
Here is the user manual for the Oster Fusion:
http://www.osterfusion.com/Manuals/MANUALS/BRLY07-Z00-000_43_29190737.PDF
It looks like you line up the threads, place the base on, and twist to tighten.
-Tha Mp3 Doctor
Mar 19, 2009 | Oster Blenders
Need replacement jar for Black & Decker BL550 blender
there do not appear to be any replacements for this model out there...i need a jar base, and you need the jar...contact me at julms57@aol.com
Jan 08, 2009 | Black & Decker BL550 ProBlend Work Top...
Power flashes but doesnt start
Yes, I know what it is. On the base of the blender jar (the plastic base) there are some "fingers" that must contact the base to allow operation to take place. Turn it upside down and look at the little plastic "fingers" around the outside periphery of the plastic base.
These fingers tend to break over time... mine only has two left right now, and it only works in one particular position as a result.
Rotate the blender jar one spot at a time until you are able to operate it "normally". I use it for margaritas, and it won't allow me to push the button for Frozen Drink unless the jar is in the right position.
I am going to try and find a replacement base (or entire blender jar) somewhere... or else I will finally have to retire my favorite blender of all time!
Dec 20, 2008 | Oster 6700 Work Top Blender
VILLA WARE 5767
my blender jar is broken. I need to replace it
Aug 05, 2007 | VillaWare 5787 Double Smoothee Work Top...
Black & Decker BL675 ProBlend Work Top Blender Logo
135 people viewed this question
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
