Error message 83C00009 on HP L7680 I have the same problem. I get the message 83C00009 on my HP OfficeJet L7780 when I attempt to power it on. I tried the suggested solution. It does not reset. It just gives the same error message.
SOURCE: Error message 83C00009 on HP
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
The printer will turn off or shows Semi Full reset message.
Posted on Sep 11, 2008
websnail
  • 419 Answers
SOURCE: hp officejet l7780 rear access panel
The L7780 usually has a duplexer which has a rear access panel on it but this is NOT the panel that the printer detects as open.
In the L7780 anything that is connected/slotted into the rear slot/hole is considered to be the rear access panel. This means the duplexer (which is standard on the L7780) is seen as the "rear access panel".
Stand looking at the back of the printer
Inside the slot on the right side you will see a green circuit board with four metal contacts on it. Check that these are not soiled or damaged in any way. Clean if necessary.
On the right side of the dupler you will see only TWO metal pins that spring out and should make contact with two of the contact points. It's possible that these are damaged and/or broken. You may need to free, re-bend, etc... these CAREFULLY so that they stick out properly. Ultimately the goal is to ensure that the metal pins touch the appropriate contacts on the circuit board.
If all else fails, check your warranty and contact HP to see if they can provide a replacement duplexer. If the circuit board itself (in the printer) is damaged though you may need to return the printer itself.
Hope that helps.
Posted on Jan 24, 2009
  • 685 Answers
SOURCE: Paper Jam error message
Here's a video that should help...
http://h30460.www3.hp.com/?fr_story=2304f3aa563aa6dbf7a24b8a764d74f1b43314d2&rf=bm&fr_operatingMode=OneSpecificStory
Posted on Aug 03, 2009
SOURCE: I got the message that the Printheads required
hi
thank for using Fixya
go to folowing link you will have your solution
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01446637&cc=in&lc=en&dlc=en&product=2512010
Posted on May 17, 2010
I had the same error and I just did the following and it reset the printer back to defaults and things are working once again.
1) Turn printer off (pull power cord)
2) Press Cancel button on top of printer
3) Turn power back on (plug in power connector)
4) Keep pressing Cancel button untill it looks like it reset
Posted on Jun 28, 2010
Error Code 83C00009
I had bought a HP Photosmart B110 wireless printer that worked perfectly well until just it was a couple of months out of warranty. For those whose don't own an HP printer, then don't buy one because HP are not interested when it is out of warranty. That is not interested in anything other than selling you repairs or or new printer. It looks from a simple Google search that these things are designed to fail very soon after warranty. All I did was unplug the printer and then plug it back in. Search for the magic error code 83C00009 which appears on the screen and you can't make the printer do anything else. I will never buy another HP printer or laptop.
Jul 28, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Can't get printer to function
First do the cut circuit: Unplug your power supply from your printer wait 10 sec. plug it back and try again.
Jul 05, 2009 | HP Officejet Pro L7680 All-In-One Printer
Which HP printer can copy or scan legal size (81/2 X 14) documents?
You will likely need an Officejet model such as this one:
Officejet L7780
Here is another, but more expensive:
Officejet 8500 Premier
And...this one looked pretty reasonable:
Officejet L7680
These were the only ones I found with legal size flatbed scanning/copying.
Thanks for using Fixya.
Jul 02, 2009 | HP Office Equipment & Supplies
HP officeJet Pro L7680 will print in color but without any black.
I have the same problem with my Officejet Pro L7780, so you are not alone. Have you found any solutions?
Jun 03, 2009 | HP Officejet Pro L7680 All-In-One Printer
My HP Officejet 7410 All-in-One keeps giving me the error message - Scanner failure - Turn power off then on. Turning power off then on, even disconnecting power cord, repeatedly does not solve problem.
Our HP Officejet L7780 displays the "Align Printer" message and then does it automatically wasting several sheets of paper aligning, then the next time we print a page the same message comes back. Is there a way to turn off the "align Printer" message. It is printing ok otherwise.
Jul 31, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Jul 30, 2008 | Office Equipment & Supplies
232 people viewed this question
k24674
jasbo
jasbo
