Question about Sony VAIO PCV-V200G PC Desktop
Computer not booting to Windows and sometimes freezes
Starts the computer but won't boot to Windows. Sometimes it starts for few seconds and shuts itself off otherwise the cursor just stays on a blank screen (You may say freeze)
  • Anonymous Mar 01, 2009
    Unit will power up for a few seconds then shuts itself off. If you pull out on the power button it may stay on a little longer, but when you let go it turns itself off.
  • andy kissan May 11, 2010
    hi any beeps or dispaly with writing on it
    or any other info
  • 77 Answers
Hiya
this cud be many causes, a corrupt driver or overheating
try booting into safe mode to find out if it is a driver or software issue, if it does not then i wud suggest checking your cpu fan is working as you say it shuts itself off.....as new cpu's have a thermal protection built into them to stop the from cooking.....
let me know if you have any joy
Posted on Feb 26, 2009
Pleas help me
You may have a damaging or incompatible program.
Jun 29, 2015 | Computers & Internet
Shuts down after start up
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Jan 14, 2013 | Computers & Internet
My Dell Dimension begins to boot then sits there as if asleep
It sounds like it's probably the power supply. Computers require more power to boot up than they do to keep running, so if it's fine once it gets going, the power supply may just be dying. If you have a multimeter and know what you're doing, you can test the power supply connectors to see if any of them (especially the ones leading to the motherboard) are not giving the proper voltages.
How old is the computer?
May 27, 2010 | Dell Dimension 9200 PC Desktop
Acer travelmate 4050 will not boot properly
Hi. I am a computer expert, and i will help you.
What you kight want to do is take your computer back to the store that you bought it from. If you still have the warranty, then they should be able to send it to a repair company and you will have it back in at lease 2 weeks.
I hope I helped.
Dec 28, 2009 | Acer Computers & Internet
I cant boot to my windows 7 desktop without installation cd Problem, does anyone have this same problem or know how to fix it?
You problem is caused by the computer wanting to boot up from the CD drive.
When the computer starts up, immediatly start pressing F-8 (or what ever will take you into the Bios sometimes F-2) this will take you into the Bios of the computer.
Once you are into the Bios, this is where you will change how the computer boots up.
Right now it is booting up from the CD , so you will want to change it to boot up from the Hard drive,then click keep changes. Shut down, and restart back up again, you should be ok then
Good luck,
Hope this helps
Nov 06, 2009 | Audio Players & Recorders
HP dv9000 screen shutdown
Power controller circuit on the motherboard needs repair by pro.
Oct 08, 2009 | HP Pavilion dv9000z Notebook
My computer starts to boot up, then freezes on an opening page
hi
i think that you need to go ahead and boot the computer by a help of operating system cd ,and once it boots up try to repair it .it will give you an option for the same ,
if you get any problem u can get back to me and i will assist you on the same ,
Jul 22, 2009 | Computers & Internet
Acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Jan 31, 2009 | Acer Aspire 7720 Notebook PC
Stripy Boot Up
is it a new graphic card? Sometimes that happens when the graphic card gets overheated and fries up some chips. and sometimes those lines appear when the graphic card has fault in Direct Draw. Try setting your BIOS settings to default. if it doesn't work, i recommend you to take the graphic card to the nearest hardware tech ;)
Oct 16, 2007 | SPARKLE Computer GeForce 6600GT, (128 MB)...
Need help think i may need a motherboard
If the the laptop is failing to boot very early in the4 boot sequence, then this usually points to a failure somewhere on the motherboard. There are a few test you can run to try. 1) Try downloading the following Diagnostic program and running it on your computer. The download makes a bootable CD, and you can try running a bunch of diagnostics on your computer with out having to boot into Windows. You can test memory, the hard drive, and other things. http://www.ultimatebootcd.com/ 2) Try replacing the memory. Sometimes bad memory can cause a device not to boot. 3) If neither of the above suggestions work, then I'm afraid you will need a new motherboard.
Oct 01, 2006 | Toshiba Satellite A25-S207 Notebook
Sony VAIO PCV-V200G PC Desktop Logo
133 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
