Question about Nokia 6015i
Cannot turn phone on
Phone will turn itself of it carried in a pocket, jacket, shirt, jeans,etc. even with key lock engaged. eventually phone became difficult to turn back on and now can not be turned on. Checked battery voltage with multi meter; reads 3.74v. This phone as recently been repaired so module is new. I use Virgin Mobile. Whats wrong????
  • Anonymous May 25, 2008
    lost on button.how else can i turn it on
Check the battery terminals in the 'phone and make sure they are not 'pushed in' thus breaking contact with the battery and therefore swithching the phone off. You could try prising them out gently but be very carefull!
Posted on May 14, 2006
  • Steve Evans
    Steve Evans Jun 20, 2014
    no the terminals are fine... Anything else?
How can I disable the car alarm on the 2007 Jeep commander. It seems to go off for no reason.
The panic button can be touchy - Maybe use your keys only and keep the fob away from the car in a drawer and see what happens. Ive carried mine in my jeans and the lights come on and unlocks - I now keep it in a loose jacket pocket .
Dec 22, 2014 | Jeep 2007 Commander Limited 4WD
Tip
How to lock or unlock a Samsung Intensity
Many people like the Samsung Intensity because of its slide-out QWERTY keyboard. However, one drawback to the phone for some users is that, unlike a flip phone, the numeric keypad is always exposed. When the Intensity is kept in a pocket or purse, this can result in accidental phone calls, multiple all-black pictures, and sudden activation of the voice command feature.
Luckily, you can lock the phone's keypad to keep it from engaging any functions when you're not using it. Locking the keypad is easy. Just hold down the 0 (zero) button for about two seconds, and a message will pop up telling you that the keypad has been locked. While it's locked, you won't be able to use the numeric keypad.
The standard way to unlock the phone is to press the upper right options button (the one that you would typically press to bring up your Contacts list) and then press the center OK button. (You will see prompts for both of these buttons when the phone is locked.)
However, there is also a quicker way to unlock the phone -- just slide the keyboard open. Sliding the keyboard open will unlock your numeric keypad immediately, and even when you close the keyboard the phone will remain unlocked. If you want to lock it again, you'll have to hold down the zero button to re-lock it.
You can also enable Auto Key Lock mode, in case you think you'll forget to lock your phone. With Auto Key Lock mode turned on, your phone will automatically lock itself when it's not in use and the backlight goes off. You can turn Auto Key Lock mode on or off from the Phone Settings menu.
on Jun 28, 2010 | Cell Phones
A serial number ?
http://torrentz.eu/1187c04a861b58f659dd5dbbd6d60608d51dcde7
download from here
Sep 23, 2011 | Adobe Photoshop CS2 for PC
All of a sudden my keys on blackberry curve will not work, side buttons (camera, etc) ) WILL NOT RESPOND, all it will do is boot up, i can scroll up and down but cant click on anything....i didnt get it...
Hi
sinc your side key also not working seems like your phone is moisture damge from track ball area.
IF your keypad lights up that means the keypad is not loose.If not then your keypad connections are loose.
you may have use the track ball with your hand wet that cause this problem.
basically you need to clean your phone from inside.
thank you.
Sep 22, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
How can I remove 24"
for most towel bar and bath accessories there is a very small screw or allan bolt, located on the underside of the post, which holds the post to the mounting hardware and you can simply unscrew it to remove the post and then remove the hardware w/a screwdriver (usually phillips) saying that...i just looked up the installation instructions for moen towel bars and it says very specifically that the posts snap or click into place on the mounting hardware...it also refers to a square hole located on the underside of the post. perhaps we are meant to put a small flat head screw driver in there to release the "clip" and post. here are the installation instructions: http://www.faucetdirect.com/mediabase/specifications/yb2218_5624sp.pdf
hope this helps:)
Jul 29, 2011 | Moen 24 In. Towel Bar...
Help about my nokia 2700 classic restriction code
Nokia Restriction Codes are used to remove restrictions added to a Nokia phone by your original carrier so it will only work with their network. It is also known as an unlock code or an unlock password.
You can get the unlock code through online..........i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Jul 25, 2011 | Nokia Classic 2700 Cell Phone
All 3 lights on the settings dial are flashing red at the same time and shutter button cannot be pressed. Why is this?
Welcome to ----------------http://www.clothes6.us/ ========= We are specialized in offering all kinds of top brand shoes, jeans, t-shirts, bikini, swimwear, jacket, jerseys, watches, purses, handbags, belts, wallets , sunglasses and hats etc. we are serious and professional jersey supplier,we can offer NFL,NHL,MLB,NBA jerser,the NFL jersey 18usd each,the NHL jersey 38USD each.MLB jersey 18usd each,NAB jersey 18usd each.we have many jerseys of other players, $30 nike shoes,air jordan shoes,nike shox shoes,gucci shoes $33 true religion jeans, ed hardy jeans,coogi jeans,affliction jeans, Laguna Beach Jeans $16 ed hardy T-shirts,Coogi T-shirts,Christian Audigier T-shirts,Gucci T-shirts,Polo T-shirts. $30 coach handbag,gucci handbag,prada handbag,chanel handbag, $15sunglasses,$9 caps. accept paypal free shipping
Mar 04, 2011 | FUJIFILM instax mini 7 Digital Camera
Ihave acanon cool pix 5700 hen ishake it alittel the picture start to flicker and when i take a picture all these line and fuzz apear. what can it be?
Mar 04, 2011 | Cameras
Hello. I am unable to hear any sound when I record a video on my kodak m381. I'm not sure whether it is because it is not recording any sound or whether it is just not playing back properly. I have tried...
Ok, Transfer the video to the computer and see if you have audio. If you still do not have audio, install this codec pack and try again
http://www.free-codecs.com/download/k_lite_mega_codec_pack.htm
It will help us rule out the possibility of the camera's speakers being faulty.
Mar 04, 2011 | Kodak Easyshare M381 Digital Camera
Nokia 6015i Logo
117 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
