Question about NetGear DG834G Router
Connecting a PC with trendnet wireless AP to DG834G
I have a 834g wireless router which has my XBOX 360 connected to one of the ethernet ports, I have my main PC which connects via a usb wireless adapter, all work fine (except my pc wont see my xbox and wont even ping it, although both on same subnet and network range, and both connect to internet with no problems - but no streaming from PC to 360 using WMP 11 - ideas?). I have a Trendnet 410APB wireless access point which I have connected to another PC in the same room, but cant get it set up so the attached PC can get onto the wireless network through the 834G.
  • 60ssoulboy Sep 15, 2008
    Thanks for that, will try SP3. The download for streaming PC to xbox 360 link you provided is Windows Media Player 11, already have it, sharing turned on in options etc. - it worked fine when I had PC and 360 connected via ethernet through a 4 port switch, but just can't get anything since I put in the wireless router.
    As for the trendnet, its just plugged into an old PC that has no wireless adapter of any kind, So I thought I could use the AP in either bridging or repeater mode (there are options for both in the advance setup screens of the 410APB, and I just upgraded the Netgear DG834Gv3 to the newest firware which adds options for repeater and bridged modes) , but I dont know which is the correct mode and am totally lost! I was a PC engineer for many years, have looked after large wired networks, VPN, remote access etc, and can normally work most things out, but just really seem to have hit a blind spot with wireless APs, repeaters. bridging stations etc!
    President:
  • 2,961 Answers
You need service pack 3 as this sees any connected media that can be accessed from the programmes menu>accesories>system tools or download programme from here to set up xbox/pc streaming.
As for the Trendnet ensure that the pc it fitted to is not set to dial a connection, open IE and then tools>internet options>connections tab and select never dial a connection or it's greyed out.
Then in the properties of your wireless adapter select the TCP/IP line>properties and tick 'obtain an ip address automatically'.
Posted on Sep 15, 2008
Do u need a wireless adaptor to set up xbox live??
No, a Xbox 360 Wireless Adapter is not required to access, and set up Xbox Live, but you will need an internet connection. If you are close enough to a modem or router, you can buy an Ethernet cord, and plug it in to both the modem/router, and firmly into your Xbox 360 console. You will either need the Xbox 360 Wireless Adapter, or the Ethernet cord. Ethernet cords are very cheaper, much cheaper than a Wireless Adapter, but the Wireless Adapters are much or easier to reason with. So choose wisely with money.
Jul 06, 2011 | Microsoft Xbox 360 Console
At work we have a LAN connection, can a Netgear 834g router be used as a wireless access point by plugging the LAN into one of the ports, (using it as a port switch?)
yes you can use as a wireless access point by plugging lan cable in to the yellow coloured port on your netgear not any of ports, have a good day....
Feb 01, 2011 | NetGear DG834G Router
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jun 07, 2010 | Video Game Consoles & Games
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
I have a wireless router hooked to my computer & my son recently got a wireless-G USB adapter so that he can play his xbox 360 online. Will this work, or will we have to put the router on the xbox...
XBOX 360 will only work properly with a 'genuine' USB WIFI adapter designed specifically for it (and at an over inflated price IMO!).
One popular way to play 'network' via the internet is to connect the XBOX 360 to your PC via Ethernet cable and have the PC connecting to the internet either via another ethernet connection or more likely via a Wifi connection which could be via your USB adapter connected to your PC and talking to your Wifi Router)
Dec 26, 2009 | Computers & Internet
Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Mar 02, 2009 | NetGear DG834G Router
Have lost/can't remember the security code to wirelessly connect to my netgear DG 834G
Paul.
Can you connect to the router via ethernet?
If so assuming you havent changed the routers address connecting to 192.168.0.1 from your web browser should get you into your routers admin page.
Once you have entered the user name and password click the Wireless link from teh main menu where you will be able to see the relevent key and or change it if required.
If you need the manuals you can download from here.
http://kbserver.netgear.com/products/DG834G.asp
Regards
Nick
Oct 28, 2008 | NetGear DG834G Router
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles & Games
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Connecting two laptops using Netgear 834G
If its just a router and not a modem router, go into the routers settings and make sure DHCP is enabled to give each pc an automatic IP address and ensure wireless is enabled if using wireless adapters. Next go to the properties of your network card and on the TCP/IP select properties and ensure obtain IP address automatically is ticked. You must also set up using the XP network wizard and ensure file and printer sharing is set up through both pc's.
Feb 07, 2007 | NetGear DG834G Router
NetGear DG834G Router Logo
247 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
