Home | Olympus | Camedia C-50 Zoom Digital Camera | C-50 will not turn on ...
Olympus Camedia C-50 Zoom Digital Camera
Problem for Olympus Camedia C-50 Zoom Digital Camera
C-50 will not turn on (shooting mode)
By car man on May 14, 2006
Camera will not turn on and extend lense when cover is slid open. The moniter works fine and you can view all previous pictures. Problem was occuring occasionaly and camera still worked. Now it will not work at all. I have removed and recharged battery two times.
The camera was purchased from Staples 12/2003. Any help would be appreciated!
Thank you!
Frank Draskovic
Best Solution
posted on May 16, 2006
Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3605 votes
If it tries to move and fails, then you have a lens problem.
Likely a crack (invisible to the naked eye) in the outer barrel.
Usually lets the ball bearing fall out of it's groove between the
two barrels. Rattles a little if you gently shake the camera. Almost certainly needs the lens assembly replaced.
If it doesn't even try, but the rest of the camera operates normally, then I'd guess you're looking at the interconnection(s) between the mainboard and the lens motor(s). Connector pulled apart, cracked mainboard, or something.
you say that "Now it will not work at all" If it doesn't even try and the rest of the camera is dead as a doornail, then perhaps the battery connections? Power board?
It would help to know the history of the camera. Was it dropped, sat on, or at the beach? Was it working then suddenly stopped?
I've worked on a lot of digital cameras. To determine the problem with the zoom, disassemble the camera down to the lens module. Try to isolate the extension-retraction circuit and drive the motor from an external source. Usually you'll find the lens has broken tracking tabs on the main group barrel or retrofocus converter group or the ways or guides have cracked. I recently repaired a Nikon 4100 that responded nicely because the guide elements just snapped back into place. Usually they snap and break off or are already broken off because most are plastic. Some older ones are aluminum and can be bent back into shape but that takes quite a lot of experience. Sometimes there's just a piece of grit in the ways and you can revive it by complete disassembly and cleaning. Otherwise you might be looking on eBay for a parts camera with a good lens or mainboard.
Good luck
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Nov 06, 2007
Not Rated)
jarg
Rank: Apprentice
Rating: 0%, 0 votes
Plastic lower door track is broken allowing the door to lift disengaging the toggle under the door this toggle is what controls the lens opening.. Impossible to fix but I have designed a replacement piece of hardware that will fix it,I have started to maching a few and I intend to sell them on ebay my email is jarg1@verizon.net.....J
Was this helpful?
Yes
No
Popular Solutions for Olympus Camedia C-50 Zoom
Questions and Unsolved Problems for Olympus Camedia C-50 Zoom
Do you recommend Olympus Camedia C-50 Zoom Digital Camera?
Answer
Answer
lens will not come out, shutter open, fully charged battery
Answer
Hi replacing LCD screen.any instructions or guidance on lcd screen replacement? Undo screws holding... (More)
Answer
Slide malfunctions. Will not open and close easily. Seems to be off track slightly
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Olympus Camedia C-50 Zoom...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 721
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
