Question about RCA P60921 60" Rear Projection Television
Chassis no PTK195MT
I need the pc board that has transformers ect,, Broke mine changing flyback transformer . Board melted and has hole in circuit. I need a part number and will I need to purchase any components or does the board come complete? Thanks for any help you can give
  • 10,594 Answers
I couldn't understand why you closed chat session as I said Hello and got no response.
Your tv requires RCA Part Number: 242676 Board and its available in Parts Store.
Need further help, let me know please.
Posted on Sep 13, 2008
GE D52GW12 HDTV CHASSIS ITC222
The model indicated does NOT use a chip for convergence output; the convergence circuit is divided across three circuit boards.
Does the convergence option appear in the menu or NOT?
Dec 06, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Rca 52" 3 light flash not turning on
Check circuit board for bulging at the top capacitors. The board you are looking for is the one with the flyback transformer. This transformer is the one with a thick red wire going to the top of it. Replace all bulging capacitors. Capacitors are the ones that look like little cans. While you are there resolder the bottom solder points on the flyback transformer. This should work, because it worked for me.
Aug 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
THE TV WENT POP, SPARKED AND WENT OFF COULD IT BE THE BULBS AND IF SO WHAT DO THEY COST ABOUT
the flyback or CL031 are the usual causes with that chassis doing that. Usually CL031 will burn a hole through the deflection board its located about two inches in front of the Flyback transformer.
Mar 15, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
I plug it in and it arks from flyback to board no cracks in flyback this started after i clean a connection on the board because it would turn off and on when hit or walked by
Sounds like you need to resolder the connections on the flyback transformer. You also need to insulate the area of the board that it is arcing to, a piece of Insulating tape or Mylar film, will help, this is happening because an Over voltage situation is breaking down to chassis. Be careful though even though the FB looks OK, often thery are NOT it only takes a pin hole for this to happen..
Mar 14, 2010 | Hitachi 50UX58B 50" Rear Projection...
Have a Hitachi 53sdx89BA Rear Projection TV. Turn on TV and red power light illuminates. No picture, but have sound. Check PC board in back and red led is flashing and green leds are lit. It was working...
Discharged Flyback Transformer. Removed main pc board from bottom of TV and flipped over, no apparent damaged components or blown board traces were found. Noticed a lot of flux in various areas on the board that seemed unusual (maybe TV was worked on before as I bought a showroom demo at Circuit City). Used a plastic screwdriver to remove all flux between connections on ICs, Transformers, Flyback Transformer, and various other components. Cleaned all debris, dust and crud accumulation (TV is over 10 years old and there was alot around the Flyback Transformer) from both sides of board using a lightweight paint brush.
Used a magnifying glass to check all solder joints for possible cold solders and found none. Did the same for Power Supply Board. Checked various ICs and Power Transistors for opens or shorts (in machine) and they seemed fine. Reinstalled boards, said a few Hail Mary's and fired it up.
The protector Led no longer flashed under power and lo and behold I got picture and sound!
I cleaned the lens on the projectors (again 10 years of dust accumulation) did a magic focus adjustment and it works fine!
After reading other fixes, I fully expected it to die after 10 minutes so I left it on all day and against all odds it still works.
What was the fix......Dirt buildup on and around Flyback and other components,,,,,,Flux conducting electricity between contacts on Flyback and other components.....or oxidation on connectors between Power Supply and Main Board.....I don't know.... all I know is that for the moment I saved around $ 300 - 400 in repair bills by doing it myself.
Feb 01, 2010 | Hitachi 53SDX89B 53" Rear Projection...
Circuit board needs replaced
I replaced mine, it's called the Deflector board. Some people call it the flyback board after the flyback transformer that is located on it. I found one on Ebay for 25 bucks a while back, so good luck. Troll ebay or find someone that is giving their tv away on craigslist because the convergence or a bulb is bad. Don't base it just on your specific model of TV though because many of them share this common board.
Try part #271827. That was the part number of the board I won on Ebay.
May 25, 2009 | RCA R52WH73 Projection Television
36" RCA- loud whine/squeal when it is plugged in, otherwise no power.
The HOT Hortz output transistor has gone home, 99% of the time from a faulty IVHT (Flyback Transformer), very common on the ctc187cl* chassis. The factory Flyback is no longer available, I have had problems finding an aftermarket one to replace it with.
The HOT is a BUH517, but you can also use a 2SD5129. It is the transistor mounted on the siler heat sink with a metal clip rather than a screw, just in front of the flyback.....
If you replace just the HOT, most of the time you will get a rapid arc (27,000volts - BE CAREFUL!!!) from the lower (yoke) post on the flyback. If the flyback is shorted, It may also just burn out the HOT and go right back to "squealing"....
Good luck finding the flyback!!!
Oct 06, 2008 | RCA F32450 32" TV
Chassis no PTK195MT
This part is called the flyback transformer and is part # 239111 at a cost of $68.99 from tritronicsinc.com. You can replace the transformer. It sounds like it developed a short internally. There may be other parts that were effected as well. If you are not comfortable working inside hte set, expect a service call to run about $100 for parts plus hte local labor rate.
Dan
Jun 09, 2008 | RCA P60921 60" Rear Projection Television
Transformer 271996
IHVT or flyback transformer has 3 leads = high voltage to CRT,
focus and screen leads to small circuit board on end of CRT.
.................T.
May 26, 2008 | RCA 32V420T 32" TV
Flyback transformer on television
Single white line across screen mean a vertical colapse. So you will need the vertical output and maybe a cap around 100uf@50v.
Sep 13, 2007 | RCA E13320 13" TV
RCA P60921 60" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
