Dvd i have a built in dvd player in my tv. i have only used it a few times and have not used it in a long time. i just tried to put a dvd in it and it will not close --- it just keeps kicking the dvd out. i tried other cds. i hope you can help.
  • 28 Answers
Sometimes the laser assy. carrieage jams. There is a lot of disassembly involved to reach it; but, if yo manage to access it, gently slide it away from the center. Do not touch the lens with your fingers, and use a clean cotton swab to clean the lense. MAKE SURE YOUR TV IS UNPLUG. THE THICK RED CABLE PROTRUDING FROM THE SIDE OF THE TV TUBE HAS SEVERAL THOUSAND VOLTS; SO, DO NOT TOUCH IT. AND DO NOT ATTEMPT TO SEE IS THE LASER IS WORKING - IT WILL CAUSE PERMANENT DAMAGE TO YOUR EYES. MOST LIKELY YOU WON'T BE ABLE TO SEE IT ANYWAY, IFTHEY ARE USING AN INFRARED LASER..
Posted on Sep 18, 2008
Tv with built-in dvd player. When a disk is inserted, sometimes it will play, at other times, the prompter will say disk loading and then in a few seconds it will say "no disk" I've tried a...
Hi carlos,
Im assuming the disc youve been trying to use is new. Most people who have that kind of problem may find that the lens need special cleaning by a trained technician who may have to open up the set. For another quick fix, try another dvd cleaner (trust me, the expensive ones are usually better), and also wipe the dvd from the interior to the exterior!
Hope this helps,
kc
Feb 21, 2011 | Apex Digital AT2702 27" TV
TruTech tv with built in DVD player not playing DVD's
the possible of dvd, its lince, its possible damage, specialy when use dvd has scrahts. try to clean useing cotton bads only, clean smothly, then try to use,
Apr 17, 2010 | TruTech PLV16190 Television
2 dvds in built-in player
I have come across this a few times, one in fact last week!! The back needs to be removed from the back and the dvd section removed, Dont be afraid this is quite easy to do. lie the tv down face first and remove the stand and all screws, then remove the DVD section, should be 5 x screws and some leads that just clip off.
Then you will need a small screwdriver or a knife to prize the second dvd out, this may scratch your dvd but its better than your dvd player being broke!
Once out place the dvd player back in the set then re-screw it plug the leads back in and turn the set on and try to eject the first dvd, this should now be ok.
Once done, turn the tv off and replace the back on.
Just take your time and Obviously make sure the tv is not plugged in when removing the DVD.
Hope this helps
Apr 05, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
DVD player not working, only used a few times AKAI lct32z4adp 32"lcd tv with built-in dvd player
Unfortunately they are a real bare to fix. Unless its a jammed disc it is probably a defective transport. If it is under warranty have it repaired otherwise get an external DVD player.
Sorry I don't know of any easy fix for the integrated units.
Cheers
Jan 06, 2010 | Akai CFTD2085V 20" TV/VCR/DVD
I have a large screen TV with a built in DVD player. How do I switch from the DVD player to TV? After using the DVD player I cannot get the TV to come on. Thanks.
Most likely there is a TV button on the remote.
Try turning it off then on.
If all else fails, try pressing Stop about 3 or 4 times.
Then it will stop the movie and the DVD player mode.
Jul 04, 2009 | Tvone 1TPC1280HD
32lg40 built in dvd player disk error
There definatley could be a firmware issue with that TV's DVD player if the model has just been released.  My suggestion would be to bring a couple of known to be working DVD's back to the store and try their floor model as well.  This will be easier than bringing back the TV for the second time.  If this is a problem with the DVD player's firmware, LG should be able to fix it under warranty so I would call them or swap out the TV for another brand instead.
Mar 24, 2009 | LG 32LG40 32 in. LCD HDTV
T.V. shuts off when I try to play a DVD in the built-in player
Try putting in a VCR tape let it load and hit stop. If the set stays on it's the VCR deck causing the problem. It will be either be bad sensors or LED or possibly the mode switch. Let me know if this helps.
Oct 15, 2008 | Philips Magnavox 27MS343S 27" TV
DVD Freezes
THE Laser lens of the built in dvd needs cleaning buy a dvd lens cleaner at walmart ,target,or walgreens then try tv after cleaning buit in dvd player laser lens
Dec 25, 2007 | Mintek DTV-373-D 37 in. LCD HDTV
Tv/dvd combo
The DVD built in, is a standard DVD player. I don't think Blu Ray or HD-DVD was standardized at the time, and if they were, were quite expensive at the time.
Dec 24, 2007 | Hitachi 46W500 46 in. TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
