Question about Panasonic DMR-E85H DVD Recorder
DVD problem I have a problem when I select DVD and insert a disk, or try dubbing to/from a disk. The machine seems to reset and goes into 'Self Test' mode for several minutes, then settles down. I can then watch a disk but if I am dubbing this occurs over and over. The material is my own i.e. not copyright. Has anyone got any suggestions for a quick fix or will I have to send it away for repair?
  • 3 Answers
I have discovered my E85 to have an inadequate power supply. I took the lid off, and used an ancient computer power supply to power the HDD. Since then I have not had a problem with it cutting out dead and self checking on startup whenever I tried to hi-speed access (including dubbing, finalizing, viewing Navigator etc on the DVD.) It does not have enough power to supply every component during peak actions, and just cuts itself out. But not now!
Posted on Feb 25, 2008
  • 513 Answers
I've had the same problem. Are you using x8 DVD-R? I had no problems with the old x4 discs, but had the (long) Self Check process and a failed dubbing occur between 1/100 and 2/100 in the dubbing process with the x8 discs. I've found two workarounds: 1) The problem doesn't seem to occur if the recordings are made with hi-speed dubbing enabled. I do this now as a default, but the loss of the ws tag is a pain . If I still get a dubbing failure with hi-speed dubbing, a quick power down/power on of the unit seems to rectify the situation. 2) If you record a "leader" in hi-speed dub mode of a minute or two, and dub it onto a x8 DVD-R first, you can then copy non-hi-speed dub recordings onto the disc. Not quite sure why this works, but it does - it's like the first minute or two being dubbed over needs to be hi-speed enabled to be written from the memory of the E-85 to the disc, but once that's done it dubs as it should. btw, another process that crashes the unit is if you try an change the thumbnails on a x8 DVD-R. Not the end of the world but again annoying on expensive equipment less than two years' old. DVD-RAMs are not affected by the problem in my experience. Apparently there's some firmware in the US that addresses the problem with x8 discs - http://www2.panasonic.com/webapp/wcs/stores/servlet/vDownloads?storeId=15001&langId=-1&page=DVDFirmware , but Panasonic UK don't distribute it. I think the E-85 is a good box but it has proven too buggy and I'm thinking of upgrading it, possibly when the new 85 is released by Panasonic in a few weeks. Good luck
Posted on May 16, 2006
What does error code e22 mean
e22--will not finalize DVD-R disk (due to dirty lens, I think)
*unplug unit and replug after 20 minutes
*restore settings if needed, and reset clock
*insert & run/play a DVD lens cleaner disk
*dub video from the HD to a NEW BLANK DVD
*finalize after dubbing is finished
THIS WORKED ON MY MAGNAVOX MDR 533H/F7
PS: make sure that the new blank DVD disk is from the same pile of disks that you were able to finalize before.
Feb 08, 2016 | Magnavox ZV427MG9 DVD Recorder/ VCR
Problem dubbing from HDD to DVD+R (LG RH7823W)
Received no proposed solution, Is this the service I can expect from fixya,com?
Jun 16, 2009 | LG DBRH197H DVD Player/HDD Recorder
JVC SR-DVM600 Dubbing from HDD to DVD Problem
Have you tried using a different brand disc. When I first purchased my DVM-600 it would not record on Memorex discs. I purchased TDK -R discs and all is fine. In the old-school analog world, all specific format tapes were computable to all machines. In other words, a VHS tape recorded in your VHS recorder will play back in my machine and every other VHS machine. Because the DVD format has so many formats and standards, compatability issues are quite common.
May 07, 2009 | JVC SR-DVM600
Dubbing from DVD to HDD
When you insert the dvd are you in dvd mode or hdd mode I think you have to be in hdd mode then go to settings insert dvd that you want to dub wait then it should become not greyed out, I had a similar problem when i tried to burn a dvd from hdd I had to be in hdd mode to dub I hope this helps let me know
Jan 23, 2009 | Philips DVDR3575H/37
Can not get dubbing to work
Samsung's solution to many problems seem to be the type of dvd. Try using a dvd-r. I am able to select dubbing with a dvd+r, but the +r discs won't play in other dvd players. Apparently, -r is the only disc to use with this box to avoid issues. The +r records the soundtrack a few seconds off of the video track.
Dec 14, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dubbing from HDD to DVD disc
I beleive you can only dub from hdd to disk,
Try formatting the disk first.
good luck
Norm
Apr 03, 2008 | LG RH177 DVD Recorder/HDD Recorder
HDD to DVD
make sure you set dubbing speed to sp ,short play,thats the default setting,then go to start up menu and finalize disk
Oct 11, 2007 | LG RH177 DVD Recorder/HDD Recorder
Problem dubbing from VHS to DVD
Try different brands of disk, most dvd-r recorder are disk sensitive, buy only one disk per brand, find the brand compatible to your recorder by just inserting the disk and wait for confirmation that it is ready for recording session. I have tried around five brands, sony and maxell as well as verbatim are good dvd-r disk.
Aug 23, 2007 | Sony RDR-VX555
Panasonic DMR-E85H DVD Recorder Logo
400 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
