Where is the air filter on my rudd airconditioner? i have uhla r-410a
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
HEY< is this an up flow or down flow air handling unit,,,,(vents in the ceiling or in the floor?) If this is a down flow, then the filter rack is always before or above the the fan. to catch dust before it goes to the fan blades..!
Posted on Sep 13, 2008
Air conditioning clean filter daikon 410a
Instruction manual is here, but the Model number you posted is for the outside unit, not the inside unit where the filter is. Front usually lifts up and you slide the filter out and wash it.
Nov 28, 2016 | Filter Heating & Cooling
Tip
R-410A or r410a Why This Refrigerant is Better
One of the best benefits of R-410A refrigerant is its exceptionally quiet operation. Other key benefits of R-410A and the air conditioning systems that use it are higher EER (Energy Efficiency Ratio) better heat-pump performance, increased efficiency and reliability. There is also no ozone-depleting chemicals. R410A has the lowest Global Warming TEWI (Total Equivalent Warming Impact). Probably the most important benefit of R-410A is that it will still be available long after the production of R-22 units is stopped in 2010. Although contractors are still using the lower pricing of R-22 equipment as a selling point when talking to their customers, many smart ones are now also selling the environmental benefits of R-410A.They are also selling the benefits of the new technology and the improved comfort level of the new R-410A equipment.
There are many efficiency and economical benefits to R-410A. It has become very important for techs to inform their customers of the many benefits of R-410A products. Some of the benefits of R-410A are low energy consumption, increased product performance, no ozone depleting chemicals (no chlorine), and improved product reliability. The new products that use R-410A are state of the art technology, feature enhanced heat pump and air conditioning performance and meet the clean air act requirements for 2010.
For many years most air conditioners and heat pumps sold around the world used a refrigerant called R-22. Homeowners and business owners now have the ability to ask for an air conditioner or heat pump that uses the more efficient and environmentally friendlier refrigerant called R-410A. When you buy a new air conditioning or heat pump system by selecting R-410A you virtually eliminate the possibility that refrigerant leaking from your system could contribute to the hole in the ozone layer. You will also be investing in a new comfort system that will last you for many years to come. This is because R-410A (a chlorine-free refrigerant) complies with governmental legislation to phase out ozone-depleting refrigerants well ahead of the 2010 deadline. Another thing to consider is that the costs of R-22 will begin to rapidly rise when the production of R-22 units are phased out by January 1, 2010. Because of this there will be less R-22 refrigerant produced.
One of the greatest benefits of R-410A is that it will still be available for a long after the production of R-22 units ceases in 2010. If you are installing an air conditioner or heat pump in the near future, make sure that you specify that the unit uses R-410A refrigerant.
Do not allow the installation of a R-22 unit even if the pricing is much lower. The future costs of a repair to the unit will more than offset the savings now.
http://www.fixya.com/support/r3636724-r_410a_new_refrigerant_air_conditioning
on Jan 10, 2010 | Heating & Cooling
Tip
R-410A The New Refrigerant for Air Conditioning
R-410A possesses excellent cooling capacity and operates at 50% higher pressure. R-410A is a mixture (blend) of refrigerants that create properties nearly identical to R-22, but are free of ozone depleting chlorine molecules. R-410A was developed in response to an agreement between numerous countries (known as the Montreal Protocol). That stated that those countries would move toward discontinuing the use of hydrochloro-fluorocarbon (HCFC)-based refrigerants. R-410A, chemically known as an HFC (hydrofluorocarbon), contains no chlorine and will not damage the ozone layer.
R-410A is an azeotrope mixture of R-32 and R-125. R-410A cannot be used to retrofit existing R-22 a/c equipment due to significantly higher operating pressures and much higher cooling capacity as outlined in the chart below. R-410A when operating at normal operating pressures and temperatures has higher pressures. R-410A cannot be used as a "drop-in" replacement for R-22; the higher operating pressures will damage R-22 compressors and components. Therefore the old R-22 refrigerant systems needed to be buffed up some to handle the higher pressures. Because of this R-410A and R-22 equipment cannot be cross matched.
R-410A has unique performance specifications and characteristics for oil, moisture indication, thermal expansion valves, compressors, filter driers and refrigerant handling. R-410A air conditioners use newer synthetic lubricants that are usually more soluble with the R-410A than the old mineral oils are with the older R-22 refrigerants. R-410A systems use mineral oils for lubrication. R-410A systems can be more reliable than R-22 systems. R-410A air conditioners and heat pumps are today's "state of the art" systems, and utilize the most current technology available for efficient and reliable operation.
R-410A was developed to replace the ozone depleting R-22 refrigerant now used in most residential and some commercial air conditioning equipment. R-410A has no ozone depletion potential but does have a higher global warming potential.
R-410A has quickly become the refrigerant of choice for use in air conditioning applications because the refrigerant delivers higher efficiency and better Total Equivalent Warming Impact (TEWI) than other choices. Make sure that if you are installing a new air conditioning system, that you specify that the new system uses R-410A. Not only is a R-410A system more reliable, but remember that R-22 use will be discontinued in 2010. An R-410A system will give you the best and most effective service for the foreseeable future.
on Dec 14, 2009 | Heating & Cooling
I have a rudd UHLA-3617JA high achiever air handeler, works fine except the electric heater will not come fan starts normally, is this a fuse/breaker or failed electric element problem, how can i tell
It is either the element, sequencer (or contactor/relay), or power to the switching element. 5KW Elements normally Ohm out @ around 10 Ohms when they are good. Everything you need to check requires a multimeter.
Jan 21, 2015 | Heating & Cooling
Any diagrams on installing a 410A TXV on a R-22 Evap coil?
You don't install a 410A TXV on an R-22 Evaporator coil.
If converting your system to a 410A, then you must be using a 410A condenser, and an evap coil, and drier rated for 410A.........
Dec 09, 2010 | Goodman Heating & Cooling
Where is the filter located on a R-410A Split System Air Conditio
Hi!!
The filter is located on the outside unit, Near the compressor.
Don't forget to rate this post!!
Jul 17, 2010 | Cfm Daikin R410a Split System Air...
RUDD MODEL# UAMB-048JAZ AIR CONDITIONER
service once a year clean dirt and hose the coil out make sure power to outdoor unit is off also make sure you keep a new air filter change about every 2 months you should also have a tech test you pressures this could cause poor cooling also need to clean inside coil also a service tech will probaly need to do this good luck
Aug 30, 2009 | Ruud UAMB Air Conditioner
Wont Turn on at breaker or fuse box.
check the braker box, and also there shold be a togle switch by the furnace that could be turned off.it sounds like you don't have any power at all
May 29, 2009 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
