Question about Emerson EWL3706 37 in. LCD Television
My emerson tv is turning it self off
After about 2 seconds of being on my tv shuts itself off
    Problem Solver:
  • 9 Answers
A very common power supply problem these TVs made by Funai seem to have. You will need the Mfr to repair it for you. Call them at 1-800-242-7158 for assistance.
Posted on Sep 15, 2008
Tv shuts itself off with in seconds,why ?
Dear Michael
May I ask you for a little more info on your problem?
SONY uses self diagnoses in all their television products, this code is indicated by a fast steady flashing of the RED standby light followed by a distinct pause in the flashing.
I need you to count the amount of flashes between pauses, normally between 2 and 11 flashes. Tis will help me to assist in determining what your problem could be.
Good Luck!
Dec 01, 2013 | Sony KDL-55V5100 55 in. HDTV LCD TV
Why does my tv turn off by it's self after a few
Either a power board problem or something in the set is pulling the power voltages down---if under 26 inches it may not be fixable.
Mar 19, 2012 | Emerson Televison & Video
MY R.C.A. MODEL 20F420T WILL NOT STAY ON. TURN IT ON IT MAY STAY ON 3 SECONDS TURNS IT SELF OFF TRY AGAIN IT MAY STAY ON 2 SECONDS BACK OFF THANK YOU ????
The first couple of seconds of operation, most TVs are doing some self-test and if something has failed making full power on dangerous (for fire) they will shut down. Either a major component in the horizontal section has failed or the main power supply itself is defective.
Dec 05, 2010 | RCA 20F420T 20" TV
When I turn the TV on it shuts itself off in two seconds. It's model WS65909 Diamond Series
This model should have a self diagnostic feature:
Turn set on and when power light goes out----Press and hold on the front of the set both the MENU and INPUT buttons for 5 seconds and release both.
Power light should blink a two digit error code---most common is 2 blinks, a pause and 2 blinks--set will repeat the code about 10 times.
Let me know what the error code is and I will tell you what it means and what may be needed to fix it.
I am here to help people--If you have any questions or need help let me know.
Regards, SD TECH
Oct 06, 2009 | Televison & Video
Emerson EWL20D6 TV turns on and the picture goes right back off
Mine is doing the same thing. I talked with a local repair guy over the phone and he says that (obviously) something is malfunctioning in the TV and a sensor shuts it off to minimize the damage to other components. This would be ok if the TV were 20 years old (they used to last that long); however, mine is only 1 1/2 years old and Emerson couldn't give a damn that the TV is a piece of ****. Silly Mimi
Mar 25, 2009 | Emerson EWL20D6 Television
Tv turns itself off after bout ten seconds
Your over voltage circuits(hi-voltage and low voltage) are defective.When the voltage exceeds the specs it shuts off the tv.Unless your a service tech,you can't fix this.There are components on the main circuit tha t have to be changed.Sorry, no easy fix.
Jan 03, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
Tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Dec 19, 2008 | Emerson EWC1301 Combo
my tv shuts off after a few seconds what can i do to fix it
Sep 12, 2008 | Emerson EWL20D6 Television
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Emerson EWL3706 37 in. LCD Television Logo
266 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
