Question about Linksys Wireless-G WRT54G Router
Please Help My computer runs straight off the router. My daughter, just got her computer back from being repaired and we cannot get it back up on the internet. Can you help! Comment by Docdunit, posted on Sep 11, 2008 Do you do this on the main computer where my router is or do you do it on the computer that we are trying to get the internet hooked back up on? Still need a solution for this problem? Try our Premium Assistance plan Solution #1posted on Sep 11, 2008 mb6531 Rank: Apprentice Rating: 0%, 0 votes hold down the reset button behind the router for 10 seconds pull the power plug for another 10 seconds then plug it back in. Plug the ethernet cord directly to the computer/laptop from one of the router ports. On your internet explorer page type in 192.168.1.1 this will forward you to the router type admin on both boxes. Then check the settings on the security reset new password SORRY, but I don't know anything about computers. Please be a little more basic Please!
    President:
  • 778 Answers
How does your Daughter's computer connect? You state that yours connects directly, does here's connect via wireless connection? If so, then you'll merely need to view wireless connections with her PC and select your Linksys router and click on the connect button after which you should be prompted to enter your passkey/pass phrase to connect to your network. If you cannot remember the passkey, then do as suggested above and reset your router to default settings by pressing the reset button for 10 seconds or so while it's powered on and that should reset it to default with no security. Just make sure to enter the address 192.168.1.1 to address your router and re enable your security. I believe the default User Name is Liksys, and Password is Admin for your WRT54G Router.
Good luck.
Posted on Sep 12, 2008
I attempted to hardwire connect my xbox 360 to a Belkin router. When I tried to connect and went through tech support with router I had to change settings. After changing router setting with my computer,...
there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console...
click here to download repair guide
Dec 16, 2010 | Microsoft Xbox 360 Console
My problem is that on my daughters computer it says connected with limited access. yet on the main computer where the modum is placed the internet works fine. my daughter has claimed she did not do...
Hello
Try to reboot the router.
1 shut down all pcs connected to router.
2 Unplug all cables from router,mark them if you think you will forget.
3 Unplug power from router also.
4 In the back of the router there is a small reset button hold this in for 1 min with a pen tip or a paperclip.
5 Replug everything back into router,power up router.
6 restart your pcs.
Nov 29, 2010 | Linksys Wireless-G WRT54G Router
My daughter has a lynksys router wrt54g. it is connected to a cabe modem. The wireless works great, but wired compters won't connect to the internet.
Wired Connection
1. Check your hardware connection:
Make sure that you use a straight cable and not a cross over cable. And also make sure that the cable is not broken or loose.
2. Check your hardware devices:
If you are using a hub, modem, or router on your network, make sure that they are connected properly and switched on. Sometimes, the solution might be as simple as restarting the modem/router, then your computer. You can also try connecting the Ethernet cable to another port of the router to test.
3. Check your network adapter:
Disable and enable your Network Adapter to make sure that it is functioning.
4. Obtain IP address automatically:
If you have set static IP address on your computer previously, it could be one of the reasons of why you are unable to connect to the Internet. So, you should set your computer to obtain IP address automatically. If you are not sure how to do it, we have an article here to guide you.
Wireless Connection
1. Check your wireless key:
When you connect to the wireless connection, you will be prompted for wireless key (password). So, if you have entered an invalid key, you will not be able to connect to the Internet. Therefore, make sure that you have the correct wireless key. If you are not sure whether you have the correct key, ask the person who setup your wireless network for help. OR, click here to learn how to check the wireless settings on your router to find out your wireless key.
2. Repair your Internet connection:
If you are experiencing limited or no connectivity on wireless connection, click here to learn how to repair your Internet connection on Windows.
If any more problem encounter,post or thumbs back.
Nov 02, 2010 | Linksys Wireless-G WRT54G Router
There's no place on modem to hook router
Look for Ethernet jacks. You want to hook both your computer and your daughter's laptop to the router to out ports i.e. usually on the front side. The back side of router would hook using probably another Ethernet jack to your modem.
Jul 02, 2010 | Belkin (F5D7230-4) Router (587009)
Internet Not Responding
Sounds like your best bet is to go back to Windows update and let them run all the way through before starting any further actions. Your daughters computer was fine because it did not require the same updates.
Aug 06, 2009 | Computers & Internet
Configuring nbg334w router
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Dec 27, 2008 | Zyxel Prestige 334 Router
Cannot re-connect
Sep 11, 2008 | Linksys Wireless-G WRT54G Router
Lynksys is causing high blood pressure
Hello cyndilynn
OK, my friend, don't fret. Let's find out what the skinny is. First things first...
(01) Do you have the manual for your router?
If not, you can download it from HERE.
(02) Do I understand you correctly that you are able to connect to the Internet from one of your computers and not the other WHILE using the Linksys BEFSR41 router?
Some points to clarify:
(A) Your Linksys router (connected between your cable or DSL modem and your computer(s)) and your Linksys NIC (installed in your computer) are two different animals that serve different purposes.
(B) Your router should be connected to each of your computers via "straight through" (not "cross-over") Ethernet patch cables that run from the LAN ports at the back of your router to a NIC connection on each of your computers.
(C) The NIC and the ROUTER do not have to be made by the same manufacturer (in this case Linksys). Manufacturer's NICs and ROUTERs can be mixed and matched just fine.
I suspect the issue is w/ detection of your NIC on one of your computers. I doubt the issue has anything to do w/ your router.
If that is the case, please, provide details about the two desktop computers that you have tried the Linksys NIC in (one successfully, one unsuccessfully).
(03) What operating system is each computer running?
(04) Has the computer that you have been unsuccessfull connecting to the Internet through the Linksys router ever been successfully connected to the Internet?
For now, please, answer these 4 questions and provide any other information you can think of (the more details the better). Then we'll move on to the next step.
Thank you
BJ
Apr 04, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys Wireless-G WRT54G Router Logo
57 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
