Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster 1/2 hp fuse?
We had a Ike related power surge this morning that blew out three things at my house: two A/C transformers, and apparently, the garage door opener.
Is there fuse built into the unit, or a capacitor or something else i might be able to take car of?
thanks,
  • 1 more comment
  • Anonymous Sep 23, 2008
    same here.. light went on real bright.. then noda...
  • Anonymous Sep 25, 2008
    I too suffer from the same thing, but with two 1/3 HP LiftMaster garage door openers apparently not working from a power surge from hurricane Ike.
  • scanio Sep 25, 2008
    I too have the same problem but with a 1/3 HP lifemaster garage door opener, due to hurricane Ike.
    Champion:
  • 244 Answers
Logic board cooked, replace board or entire unit. use a surge protector. homwowners insurance covers damage.
Posted on Jan 15, 2009
My Klipsch cs 500 has no sound. Blue light is on and I have tried every combination on remote to no avail. Any ideas?
There is the panel mounted 4amp fuse, and then there is a circuit mounted 6amp inline fuse as well. Mine blew due to a power surge that blew up other things in my house as well. It’s a bear to get the circuit board screws off, and some green sealant off! Step 1) I’m ordering a panel mounted fuse holder that is the same style as the 4amp fuse holder. Step 2) drill hole in panel, and install fuse holder Step 3) no need to remove old fuse (since its blown) so I’m soldering wires from new fuse holder to the fuse ends on the circuit board
Oct 29, 2017 | Klipsch Audio Players & Recorders
I have a 47 inch sanyo. model# dp46848. A transformer blew in a lightning storm and now the tv will not power on. The power light will come on for 5-10 seconds and then shut off. The tv was on a surge...
But, was the cable/satellite feed protected? Lightning can come in from anywhere, not just the power line. The bad thing about the way cable and satellite installers ground things is, they ground to the same grounding system that the house does, which can backfeed the surge through the entire house - it shouldn't, but it can.
I would, however, contact the maker of the surge strip and attempt to file a damage claim. They all come with a liability warranty of some sort.
Jul 06, 2011 | Sanyo DP46848 LCD TV
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: There was a transformer explosion in the street, ...
There is no fuse in your opener. The logic board is very susceptible to power surges. You can pull it and check for burnt or missing traces on the printed circuit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have a Craftsman 1/2 HP auto gargae doors. Lost power during a snow storm. Once power was reconnected only thing that did not work was garage doors. Is there a reset button somwhere....can't see one.
There isn't a reset button. Check the house circuit breaker. You may have had a power surge and that can damage the logic board printed circuit. Check the logic board for missing or burnt traces especially around the small transformer.
Feb 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain GDO Model# 41A3519-1 Power surge blew .01M capacitor next to light relay. Can I successfully test 4.5VDC transformer in-circuit?
the keypad intermittently does not function. will waitt several minutes between coding and it still doesn't functioon. however, when trying to troubleshoot, the keypad functions normally. Any ideas???
stevie
Feb 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Think Power surge blew out radio. Can it be fixed?
The fix may be as simple as replacing a fuse. Location varies by model, but each has an internal fuse on one of its circuit boards. SAFETY NOTE: It may seem obvious, but be sure to disconnect power from the set before you open the case.
If the fuse is not the problem, you will need to seek professional repair. Unfortunately, Bose does not release their parts lists or schematics, effectively creating a monopoly for parts and repairs. In fact, their web site says that the Bose factory is the only option for service or repair. They used to list a flat rate repair charge on the web site, but removed it - probably because it scared too many people. Their troubleshooting guide (below) might help, but it's very simplistic.
Before you invest in expensive factory repair on one of these trouble prone sets, you might want to investigate the new HD radios -- better sound at a MUCH lower price.
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/troubleshoot/index.jsp
Feb 09, 2009 | Bose Wave Radio
Hi, I was trying to fix a contact issue with the bulb on my Liftmaster Chamberlain garage door opener when there was apparently a short circuit, something blew and the switch at my house power supply box...
There is no fuse. You damaged you logic board around $90 for the part. sounds like you have other issuses with your operator if contact issue on your bulb. You might consider replacing your operator.
Jan 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Transformer
Several things have happened. 1st have you tried plugging the monitor in the wall and not in the surge protector. 2nd does your power button or LED light uo when you power it on? You have stated the transformer is bad due to lighting strike. Have you replaced the transformer? Your monitor should be coverd under the surge protector warranty. Please answer questions and we will go from there.
Jan 03, 2008 | Computers & Internet
Power surge
maybe but more likely not if you replace these need to put surge suppressor on these line common occurrence happen alot and need to protect all electronics as well as computers
Jan 03, 2008 | RCA F32669 32" TV
RCA g36788LV TV
check fuse n power supply section
Oct 27, 2007 | RCA G36788LV 36" TV
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,460 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
