Question about Mitsubishi WS-65869 65" Rear Projection Television
Picture has blue,green,and red phantom lines on the screen
The 65' TV has blue, green ,and red lines that are shadows from everything it shows on TV, I can still see the picture but the shadows are big and its terrible to watch TV with them. Then once and a while the TV will get fuzzy, but you can still see the picture and the picture looks like its bending. If I turn the TV off and let it sit sometimes it will go back to normal when I turn it on.
  • dragonsla638 Oct 04, 2008
    I have model ws65905 that has the same problem,center clear and bending to the out sides giving line seperation,color seperation,what ever you want to call it.I'm out of work for 7 months and can not afford 3/500 to fix HELP.
    Novelist:
    Champion:
  • 203 Answers
Sounds like a convergence problem. Are you interested in fixing this yourself? If so you will need to know how to solder well and use a meter. I can assist you as much as you need through the process. If you post a picture of what the screen looks like we can know for sure what you have going on. If you call a repairman to fix it he will charge somewhere between $300-$500 to do the repair. Let me know if you need more help!
TIm Nolan
Posted on Sep 12, 2008
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
After having our tv in storage for aver a year, now it has a green shadow to it. What could be wrong/
Not sure I understand what you mean by green shadow. I would check the fluid in the green and blue CRTS and verify they are clear. I would do this if the green color seemed fuzzy or blotchy looking on the screen.
When looking on a blank screen, do you see any arc lines of either green, blue or red? If so, you would need to lower the screen voltage for that particular CRT.
Feb 14, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Hi, I have the ws-65907 65", it was working last
No,this problems is not the projection lamp problems.The tv now have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or look like 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like 300-350 for parts and labors.
Oct 26, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi TV Model #WS65903 - Green Shadow Lines on Screen
Something is not right here--The green is adjustable in the TECH menu--did this person adjust or try to adjust in the customer or the TECH menu?
If you confirm actual model number I can tell you how to get into the TECH menu--yes--green will not adjust in customer menu--it determines geometry and is only adjusted in the TECH menu.
Also, this set requires any convergence adjustments to be done in 480 and then in 1080--if only adjusted in one mode the other will still be bad.
Let me know if you know how to adjust in TECH menu or not--with exact model number I can tell you how to get there.
If this helps you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Apr 22, 2008 | Televison & Video
Pictue is dark as hell
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 27, 2007 | Hitachi 65F59 65" HDTV
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
233 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
