Question about Amana Washing Machines
I need to know how to replace the timer-mall on my Amana washing machine model #ALW780QAC
    Genius:
  • 1,239 Answers
Hi here steps Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Posted on Sep 12, 2008
I have a Amana tandem 7300 front loader washing machine. It's stopped working nothing's happening except the display lights. Stopped in the middle of the wash cycle is there a reset button? Offbalanc
The only reset is to unplug the machine from power for about 5 min's and if that fails you may need to replace the washer timer control board.
Apr 19, 2017 | Amana Washing Machines
Amana washer stops running just before rinse cycle,sometimes if i take the dial back around it will work. is the timer shot or could it be something cheaper?!
open the timer and look for burnt contacts . if there are any replace it or buy a new machine .it replaceing take a couple photos of the wiring first so you know which goes where
Mar 15, 2015 | Amana Washing Machines
I have an amana Model ALW880QAW Top Loading Washing Machine. It sounds like a bearing is going bad when the washer is in the spin cycle. I am familiar with repairing applicances and I would like to know if...
I have an Amana top loading washing machine.. The machine recently emitted a burning odor and the machine has stopped spinning. when turned to spin cycle there are bumping sounds and it no longer spins. Does this model have a belt which might need replacing or does it have a transmission and does it sound like possibly extensive transmission work. If it is the transmission, is it likely repair costs would be greater than the value of this machine?
Jul 25, 2010 | Amana Washing Machines
Amana LWM 433 or 833. Not sure. Washer continues to wash, timer will not advance to next cycle. Sometimes stays in start position and sometimes it advances but stops. Thinking it is the timer switch.
You are spot on on your diagnosis. Have replaced plenty of timers on these machines for this exact problem.
If you are unsure of the model number, use the part number on the sticker on the timer to get your replacement part to ensure you get the right one the first time.
Let me know if you have any questions about installing the new part.
Jun 28, 2010 | Washing Machines
Amana washing machine will not spin. it agitates & the water drains out fine.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 30, 2010 | Amana ALW780QA
My Amana LWA60AW washing machine won't agitate.
Some timer dials will not turn all the time they will sit for awhile then advance . If it don't move for a long time sounds like you have a bad timer motor.
Some motors can be replaced and some you have to replace the complete timer.
Jun 10, 2009 | Washing Machines
TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washing Machines Logo
223 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
