Question about Samsung Refrigerators
Type of compressor oil for Samsung frige
Hi, I have a Samsung Refrigerator M/N RF267AAR. It takes R134A.
Compressor # MK172D-R2U.
I need to know what type and weight oil does it take.
I screwed up and poured it all over the shop floor.
suisboy
  • 175 Answers
SOURCE: GE refrigerator profile arctica Not cooling frige or freezer PTS25LBMARBB
well if the compressor dont have power so how could it work or cool?
Posted on Jan 16, 2008
Illeagle
  • 525 Answers
SOURCE: the replacement compressor for a TECUMSEH COMPRESSOR S/NO : TP103JR007B5
This link will take you to a parts suppliers compressor page where you can look up the part number and order information. Their toll-free number is at the top of the page.
http://70.168.42.43/servall_wda.htm
If this doesn't help, post me back and I will do some more research to help resolve your issue.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 26, 2008
  • 1388 Answers
SOURCE: type of oil
Air compressor pumps can use different grades of oil depending on weather conditions and usage, however do not use engine oil. Some Ingersol Rand pumps use a synthetic oil available through WWGrainger on the web. (generally not model specific) If this pump is lightly used you can use the less expensive compressor oil sold at Lowes lumber made by Campbel Hausfeld. It sells for less than $3.00 a bottle. Generally speaking, under normal weather conditions and light duty use, do not worry about the weight of the oil; just make sure that it stays clean and at the right level. If your compressor is running hot, it may be due to other problems like the check valve, head gaskets leaking between cylinders or chambers or high usage. If, however you just want the best oil for your compressor, use the synthetic. It is usually colored blue or green. This oil is special formulation to prevent breakdown in high heat and will not allow carbon for form on parts or inside of the hoses. enjoy
Posted on Nov 29, 2008
farfield
  • 462 Answers
SOURCE: ROTARY SCREW COMPRESSOR TRIPPING
Possibly water in the air tank ? Or Ice covering the inlet or screen into the tank? DOes it have a belt? or direct drive? Remove the belt and try to turn by hand. See if its the motor or the compressor is tight. If it rolls free possible a chack valve is hung up or has a broken spring OR yuo have a bad capicator or centrifical sw going to the start capicator. Check amp draw with no pressure on the compressor. tank open. If it runs extra time its somethign while under load. If it still cuts out you need to sepperate and discover if its a mechanical or electrical problem.
HOPE THIS HELPS PLEASE RATE ME ACCORDINGLY AND GOOD LUCK
Posted on Mar 03, 2009
stephanos18
  • 144 Answers
SOURCE: neff fridge, compressor makes nasty noise,
Hey there you need to check the motor/compressor PTC start relay which is located on the side of the compressor under the plastic terminal cover, it's mounted on start and run winding pins the third pin is the incoming phase which has a overload connected to it .if this relay stays shorted or doesn't conduct to power the start winding the motor/compressor wont start. also if there's a motor start capacitor test that. tell me how you get on as i have more solutions if that doesn't help.
Please rate my advice too
cheers
steve
Posted on Mar 25, 2009
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
Freezer fine frige to cold
you must check the door seals are ok and if they are you might have a bit of compressor oil stuck in the condenser pipes somwhere this is a regular problem with alot of new fridges youll need to take it to the agents if thats the case
Mar 20, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Is it possible to change the a/c compressor on my 2003 KIA Sorento ourselves, or should we take it to a mechanic?
Hello, It is possible to replace the compressor, you will need to remove the lines from the compressor unhook the plug from the compressor, remove the belt, then remove the bolts holding the unit in. After Replacing the compressor you WILL need to recharge the system with R134A coolant and oil. DO NOT FORGET THE OIL AS THAT IS THE ONLY LUBRICATION THAT THE INNER WORKING OF THE PUMP. Most all auto stores will have 1) A recharge kit ( I recommend getting the ones that have a PSI gauge on them that will let you know when you have the correct amount in the system) And 2) The oil simply ask for both and they will know what your talking about. Oil first then the charge. The bottle will also include some helpful guidelines to correctly charge the system. Hope this helps you.
Aug 05, 2011 | 2003 Kia Sorento
My GSS20IE side by side is not cooling the refrigerator side. The freezer seems to be fine. I unplugged the frige and can hear the compressor click off. When I plug it back in the compressor clicks on but...
Condenser fan near the compressor- Check to see if your have voltage at the fan. If you do the fan need replacing. There should be voltage any time the compressor is running.
Jul 22, 2011 | GE GSS20IEP Side by Side Refrigerator
Help me my frige is going nuts
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 14, 2011 | Samsung Refrigerators
My haier beer dispenser model HBF05EBSS will not turn on. Compressor is hot and keeps clicking on and off. How can I fix
Try to change the capacitor and start relay first...then maybe if that don't work the compressor...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Refrigerator Troubleshooting Refrigerator Compressor
heatman101
Aug 31, 2010 | Haier (HBF05EAVS) Beverage Dispenser
Need a replacement compressor < 8 " high for older refrigerator
How can you have a R134a Compressor that is 32 years old. That gas was not even available then. What you are asking is impossible, unless you are asking can you change from possibly R12 to R143a. The answer is yes but it would probably be too costly. you see R12 ran with mineral oil whereas R134a runs with Polyolester oil. the system would have to be completely flushed out of old oil, and the expansion device ( capilliary tube ), would have to be changed and cut to the correct length to appropriate the correct displacement of gas.
Apr 17, 2010 | Matsushita DD73C14GAU6 1/4 HP R134...
Will there be a problem if my R12 freon was changed to 134A without changing any of the components in my airconditioning?
yes the oil will be your problem and r134a is 25% harder on condensing and you may get a bit of flood back to compressor
DO NOT PUT R134A WITH OUT OIL CHANGE
Mar 29, 2010 | Randell 20072SC R-134a Refrigerator
Automotive r134a refrigerant in refrigerator compressor?
it is the same refrigerant however the car industry and the refrigeration industries purity standards ARE NOT the same!! as a rule refrigerant manufactured under the refer standard can be used for auto but not the reverse, you can use it but be forewarned chances are you will be replacing the compressor due to an electrical burn out
Sep 17, 2009 | Refrigerators
Ge refrigerator compressor
No, Try fiiting a piece of rubber or polestyren under compresser base otherwise compressor needs replacing in any event it will fail eventually rersulting in loss of food contents. Regards Advisor
Aug 30, 2007 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
161 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
