posted by De Guyver on May 14, 2006
how do i get into the manager for the router firewall? need to unblock the messenger ports.
Thanks!
Best Solution
posted on Jul 19, 2006
Here ya go:
To use the configuration utility embedded within your Motorola WiFi Router, you need to connect to it using the HTTP protocol. Launch a web browser (Internet Explorer, Opera, Firefox, or Netscape, etc.) on your computer, type in http://192.168.10.1 (default IP address for its LAN/NIC Interface) in its URL/Location bar, and then press Enter on your keyboard.
If presented with a user authentication (login) screen, try the following:
Default Motorola Wireless Router Username: admin (lowercase)
Default Motorola Wireless Router Password: motorola (lowercase)
If you cannot login using the above, it may be so because (a) you are not typing your password correctly, (b) your CAPSLOCK key is on, (c) someone has changed password on your wireless router, and/or (d) the firmware (a set of instructions stored on an EEPROM microchip) encoded within your wireless router is corrupted. Consider resetting your router to its factory default settings if you are stuck.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Motorola WR850GP Router
Email this problem
Email this problem
This Problem Also Relates To:
Motorola SURFboard SBG900 Wireless Router (DHSBG900)
Motorola Vanguard 320 Router
Motorola 498498-001-00 Router
Motorola BR700 Router
Motorola Vanguard 6425 (65731) Router
Motorola Vanguard 340 Router
Motorola Vanguard 6520 Router
Can you Help with these Routers problems?
Repair Service
Find Router Repairman Near You:
