Question about Canon Office Equipment & Supplies
Canon pixma mp160 shows paper jam - Canon Office Equipment & Supplies
Pushed a A4 thin sheet of plastic through paper feeder from both sides and the error message cleared itself!!!!!!!!!!!!!!!!! :-) Hacked off by then and it wasnt done gently!!!
good luck & not impressed with Canon quality
Posted on Sep 13, 2008
SOURCE: paper jamming and can't print
Check if there is a piece of paper stuck in the feeder rollers, sometimes the smallest piece makes the bigger mess.
Hope That Helps!
Posted on Dec 11, 2007
  • 29 Answers
SOURCE: Canon PIXMA MP160 showing paper jam, but none
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 02, 2008
Joed911
  • 4338 Answers
SOURCE: Shows paper jam, does not
Perform the reset for the EEproms
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 28, 2008
SOURCE: paper jam problem in pixma mp145. E3 error.
I have trying resseting and the error message does not clear. I have checked the printer througly and there is no paper jam.
Posted on Nov 29, 2008
  • 12 Answers
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Posted on Jun 13, 2009
Canon Pixma MP160 - It won't grab the paper, and then says paper jam.
Here's a manual from Canon:
http://support-ph.canon-asia.com/contents/PH/EN/8000643105.html
http://support-ph.canon-asia.com/contents/PH/EN/8000151001.html
Cheers,
Feb 12, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP160 doesn't take papers, looks like paper jam, but no paper jam in it. please how can I fix it.
take the printer and put it up side down, if you are lucky the object that bloks the paper acces will fall. if it will not fall you will have to take the printer to a tech.
Nov 13, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam
it is problem paper feed sensor its displace or broken
Sep 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP150 keeps blinking E 3 saying there is a paper jammed even though there's no paper in the printer. I found a little screw inside, could this be the problem?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-5
Aug 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer jam
hi,
toi-i-10
Jul 21, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Describe your Canon PIXMA MP160 All-i have a
hi,
pow-e-r-18
Jun 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
"Clear paper jam" error, but there is no jam!
hi,
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Mp160,error code e3
hi,
587
May 19, 2008 | Canon PIXMA MP160 All-In-One InkJet...
184 people viewed this question
old marine
old marine
