Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Can't locate housing
Where is the housing for lamp replacement on the panaconic PT-50LC13 tv
There is nothing in the manual. If I get to the housing I can easily replace the bulb. The back of the TV is off. I think I know where the housing is but not sure how to take it out. Can you direct me to a schematic?
Thanks
Neil
    Novelist:
    Champion:
  • 203 Answers
The lamp comes out the front of the tv. There is a rectagle pice of plastic on the front that pops off and then there is a lamp door about 8 inches left of center with one screw in it. take that one screw off so you can get to the lamp, then take the screw out of the lamp and it slides right out.
Let me know if you need any more help!
Tim Nolan
Posted on Sep 12, 2008
PT-50LC13 reset lamp timer
Replaced the Lamp, on my PT-50LC13 pan TV. But cannot reset the timer because the screen does not light up. and the instructions say to hold down the -Vol button and the pip button. But which one? there are 3 buttons with the word PIP
Apr 02, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Says lamp problems
Without more information it is going to be hard to help you. I assume you mean the TV has a warning of lamp problems. Means you need to replace the lamp. Go to www.partstore.com and put in your sets information. You should be able to find the lamp you need. Get it. Your owners manual should tell you how to replace or at least where the lamp housing is. Open the housing, remove the old lamp, install the new lamp, close properly and you should be good to go. Let me know how it works out.
hardrocko
Jan 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Need to replace bulb in lcd panasonic
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it.
If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
Oct 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I have a Panasonic 50" LCD TV PT-50LC13 and the power botton blinks orange 2 time and there is no pic but i can here the fn runing what can i do???
if the tv keps trying to turn on three times and later the lamp led stays steady red. (see owner's manual to replace the lamp process) the lamp is damaged. ones you open the lamp door and take the lamp out you can see the lamp damaged even before to buy it.
Apr 08, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 Television Lamp Replacement
not really, just be careful about getting finger prints on the lamp as the oils from your fingers will shorten the lifespan of the lamp.
Mar 17, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
