Question about Samsung VP-D10 Mini DV Digital Camcorder
Camcorder not working says 'c-emg' on screen
Hi, Our camcorder suddenly stopped working - when I switch it on the tape seems to run back and forward almost like it is temporarily rewinding and Fast forwarding. Then the screen says 'eject' and 'c-emg' comes on screen, which looking at the manual says 'take to an engineer'. Any ideas as to how I could possibly save £ and fix it myself? many thanks Steve8
  • Anonymous Mar 31, 2014
    its says to eject the tape
    President:
  • 3,130 Answers
That error code is telling you hey i've got a mechanical problem because when the microprocessor tells me to move the mode switch is suppose to send signals back to the processor to let the mechanism know where its at and in this case the processors not getting the right codes or signals so it wont let you use it, and thats why it will eject if a tape is inserted. Now unless you have all the special tools ,jigs and adaptors to repair this including a service and a mechanism manual you really should take this unit in as there are really no serviceable parts inside for the consumer to replace. Sorry i couldnet be more helpfull. Good Luck
Posted on May 14, 2006
  • ez2dn
    ez2dn Apr 10, 2013
    not really because we know stuff has to be serviced but the tech was not informative enough, anybody can see that there is a problem but what is it
There is a tape stuck in my camera.
there may have been a spring that pulled on a tab in these places that will unlock the the tape , and if is not unlocking it will go back to close position
Oct 24, 2008 | Samsung VP-D10 Mini DV Digital Camcorder
Touch Screen on Sony DCR-HC32 Camcorder Does Not Work
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Mar 17, 2008 | Sony DCR-HC32E DV Digital Camcorder
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
Camcorder problems
wow this is an old post...but mine used to do that back when I had a charger for it haha...I tightened up the video tape and make sure the tape didnt have wrinkles in it too...and it seemed to alleviate the problem if not for one recording...the stop and go recording though thats when this emergency eject happened to me...but was resolved with my just turning the wheels in the tape to tighten the tention...of course it sometimes didn't work cause I didnt get it tight enough you just gotta play with it...if all else fails send it to the shop though...
Sincerely,
Rabeka Jo
Dec 24, 2007 | Samsung SC-L810 Camcorder
Samsung SC-L810 Hi-8 S-video cable
I have a problem when i try to playback any of my tapes all i get is static it was working fine then all of a sudden this happened can anyone help?
Nov 11, 2007 | Samsung SC-L810 Camcorder
Playback problems
hmmm, then u have a diry drum head. Try a head cleaner first.
Sep 11, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
Display reads R.EMG
The belts that drive the tape are most likely defective.
Apr 11, 2017 | Samsung SC-L906 Camcorder
Mechanical problem "C.EMG" from my SC-A30 camcorder
for all those who try to fix a samsung camcoder with a mechanical problem in which the message on the display is "C.EMG", thie is the solution : the problem is caused by the socket through which the axle of the cabestan motor passes through. the socket is fitted in the aluminium case of the motor. as it is known, aluminium suffers a process of seasoning/ageing and the bronze socket is no longer fitted in its original position. The socket moves towards the exterior and the cabestan, which consists of a magnet,  gets near the 6 coils of the motor, starting a retardation effect. This problem can be solved by fitting the bronze socket with a small quantity of superglue or poxipol
Apr 12, 2006 | Samsung SC-A30 Camcorder
Error messages
Any of the following Error Messages "D.EMG, C.EMG, R.EMG, L.EMG" indicate a mechanical failure in the camcorder. The following steps may resolve the issue. 1. Eject the tape 2. Set to OFF 3. Detach the battery 4. Reattach the battery
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung VP-D10 Mini DV Digital Camcorder Logo
957 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
