Question about Microsoft Windows Vista Ultimate Edition
Windows Vista Start Menu
What is the location of the Windows Vista Start Menu? Like in the C:/ drive? where is the location?
  • Have you checked the default ( *.msstyles) file in the C:WINDOWSResourcesThemesaero.msstyles
  • To edit the start menu you should have Resource Hacker.exe which can be freely downloaded from http://angusj.com/resourcehacker/
  • To actually edit the file Open ResourceHacker.exe and go to File menu, Open...(option)
  • An Open file dialog box appears .
  • Navigate to the specified directoy and if the file is not shown ; select All Files(*.*) from the Files of Type dropdown Menu.
  • Now you should be able to see aero.msstyles (or whichever is the default *.msstyles file)
  • Click on that file and click on Open.
  • Unlike windows XP *.msstyles files you will not be able to see the bitmaps anywhere.
  • So all you have to do is click on Bitmaps on the left side of the tree view of ResourceHacker and select BITMAPS and go to Action menu ; Save [BITMAP] Resources and change the filename to *.bin
  • Note:save the files in a folder or there will be a large no of files in the wrong place.
  • Close Resource Hacker and Create A New Batch file(Create a text file & rename it as *.bat) in the current folder(where the *.bin files are
  • Edit the batch file and paste the following code: rename *.bin *.png
  • Save and run the batch file.
  • Instead of *.bin files you will see many *.png files
  • All these files are actually being used by windows Vista's explorer.exe
  • Among these files you have to search & find all the files which make up the Start Menu of Vista.
  • The only problem is that not only VISTA but even XP's Start Menu is made up of different images (AND not a single bitmap).So finding all the images takes time.But once you have done it, it's easy to customise the start menu.
  • If at all you want to change the images ,you have got to have a image editor and Use ResourceHacker.exe to replace the corresponding Binary files and save it as (say)aero1.msstyles.
  • To apply the theme you must find by googling, a uxtheme patcher which will let windows VISTA to use multiple themes and of-course a win Vista activator.
I hope I've tried my best to tell you all about windows Vista's Start Menu.Any questions can be mailed at:bhaskar_longhorn@yahoo.co.in
Posted on Sep 13, 2008
How do you set up an external hard drive?
Turn your computer on and plug the external hard drive into the computer.
Open "Computer Management" by clicking "Start," "Control Panel," "System and Security," "Administrative Tools" and "Computer Management."
Click "Disk Management" in the left pane under "Storage."
Locate your external drive from the list of hard drives connected or installed on your computer.
Right-click the drive and select "Format."
Select a file format from the drop-down menu. Choose "NTFS" if you will be using the external hard drive with a computer that uses Windows 7, Windows Vista or Windows XP.
If you will be using the hard drive with an older version of Windows, select "FAT32."
This is a much less common format.
Click "OK" twice and your external drive is formatted. Once the drive is formatted, it is properly set up to be used with your computer.
hope this helps
Sep 10, 2012 | Computers & Internet
How can I enable hibernation on my HP Mini 5101?
Welcome to FixYa, the world's largest product support community.
Generally all Windows OS has an option for sleep & hibernate.
Windows XP Users
  • Sleep Mode
By letting your computer idle for a period of time, i.e. not moving the mouse/touchpad, or not pressing any keys except when playing a video, the screen or desktop monitor will go dark. You can resume the computer by moving the mouse/touchpad or by pressing any key on the keyboard.
  • Hibernation or Standby mode
Click Start, click on Turn Off Computer, then click Stand By.
Windows VISTA/Windows 7 Users
To put Windows VISTA & Windows 7 in Sleep or in Hibernation, the steps basically the same. First click Start, then click the small arrow head located to the right of the Start Menu, then you click Sleep or Hibernate.
Fig. 1. Windows VISTA Start Menu. To put Windows VISTA to Sleep or Hibernate, click the small arrow head right next the Lock icon then click Sleep or Hibernate.
Fig. 2. Windows 7 Start Menu.
To put Windows 7 to Sleep or Hibernate, click the small arrow head right next the word Shut Down then click Sleep or Hibernate.
Jun 09, 2011 | HEWLETT-PACKARD HP Mini 5101 Netbook
I can't upload john deere drive green on my computer witch runs vista but it worked on the inlaws computer which is XP and the game says it should work on vista
Hello, If you have a program running programs since you've started using Vista, you may be able to fix that easily by running the program in XP mode.
Step 1
Locate the program you want to run, right click on the program's icon on the desktop, or in the start menu.
Step 2 Once you right click on the icon, click on properties at the bottom of the window that comes up.
Step 3 In properties, click on the Compatibility tab. Check "run this program in compatibility mode" and select Windows XP in the drop down menu. Also at the bottom of the compatibility tab, check "run this program as administrator".
Running as administrator will cause windows to ask if it's okay to open the program everytime you click to open the program. Nothing wrong with it, but just be aware.
Aug 02, 2010 | ValuSoft John Deere Drive Green for...
I want driver of shro am-400 for win vista plz do needfull
Well sorrsy to say but there is no win vista driver's for this model, anyway there is a way to use windows xp drivers in windows vista, follow the below steps -
1. Click the "Start" menu in the lower left-hand corner of the Windows Vista screen.
2. Select "Run" from the Start menu.
3. Type "msconfic" in the Run box. Click "OK." A window will appear that lists all of the programs scheduled to run when Windows Vista is turned on. Uncheck all unessential software programs. Be sure to leave critical programs checked, such as antivirus and firewall programs. Click "OK."
4. Click the "Start" menu and select "Restart" to reboot the computer.
5. Open "My Computer" (located in the Start menu or on the Vista desktop).
6. Double-click the "C:\\" drive. Find the installation directory for the Windows XP program or device that you wish to run in Windows Vista. The installation directory is usually given the name of the program, the program's manufacturer, or a shortened version of either of these two options.
7. Right-click the program or driver. Select the "Properties" option in the pop-up menu that appears.
8. Click the "Compatibility" tab in the window that appears. Check the box next to the heading that reads, "Run this program in compatibility mode." In the drop-down menu, select "Windows XP." Click "OK" to close the window. The program or driver will now operate in Windows Vista in Windows XP compatibility mode, allowing the driver to function as it did in Windows XP. Note that the Windows XP driver will not be able to take advantage of any of the new features in Windows Vista while it is running in compatibility mode. You can also follow the below link for more help -
http://www.softwaredriverdownload.com/try_fool_windows_vista_to_install_in_windows_xp_mode
Good Luck!!
Jun 08, 2010 | Sharp AM-400 Digital Multifunction Printer
My laptop was on hibernation. now it is not booting. please help
Hibernation is enabled by default in Windows Vista, and is one of the seven options (i.e. Hibernate) that appears on the Vista shutdown menu. Hibernate your Vista system will enable you to quickly restore to existing system state and intact workspace instead of start afresh, run programs and open your documents one by one again. If you do not use the hibernate feature in Vista, and want to delete hiberfil.sys and then recover the space occupied by the big hibernation storage file, the hibernation function can be turned off and disabled.
Unlike Windows XP, users cannot turn the hibernation on or off via Vista GUI interface anymore. Previously users can enable or disable hibernation via Power Options applet in Control Panel. This option no longer available in Windows Vista, which also enables Hibernate ability and creates hiberfil.sys by default. Instead, users have to rely on command line utility Powercf and Disk Cleanup Wizard to disable hibernation in Vista. Microsoft KB920730 provides details on how to disable and turn off hibernation on computer running Vista system. You must log on to Vista with user account in Administrators group to perform these action.
Click Start, and then type cmd in the Start Search box.
In the search results list, right-click Command Prompt or Cmd, and then click Run as Administrator on the pop up contextual menu.
If you are prompted by User Account Control for permission, click Continue.
At the command prompt, type the following command, and then press ENTER:
powercfg.exe -h off
Type exit, and then press ENTER.
Another easier workaround for those who’re not comfortable to work with command line is to disable hibernation and hybrid sleep feature in Windows Vista is by using Disk Cleanup wizard tool, the built-in Windows disk cleaner to delete hiberfil.sys file. The hibernation file must be enabled to access the hybrid sleep feature and the hibernation feature in Windows Vista.
Click Start button, then go to All Programs -> Accessories -> System Tools, and run Disk Cleanup.
Choose which files to clean up, either My files only or Files from all users on this computer is fine.
On “Drive Selection”, select the Windows Vista boot drive to clean up. Note that you must select the drive where Vista is installed, which normally is also the boot drive (C:) as hiberfil.sys file will be located on the root folder of it.
Once Disk Cleanup finishes scanning the system, Disk Cleanup for Vista window will open.
Select and tick the check box next to the Hibernation File Cleaner.
You can select or deselect other type files to clean or preserve from the available items or options in the list provided.
Click OK button when done.
Hibernation will now be removed and disabled.
It will solve your problem.
Dec 28, 2009 | HP Compaq Presario V3000T Notebook
How to fine a file once it is downloaded on the
Windows has a 'Search' facility that allows you to find a file whose name include part of the file name(s):
- In Windows XP, the ''Search" facility is available via the (Player) drive context menu (Right Mouse Click) or via 'Start' menu -> Search.
- In Vista or Windows 7, 'Open Windows Explorer' -> enter part of the file(s) to be found in the Top Right Hand 'Search ' box which will immediately start a search on ALL DRIVES under 'Computer'
- If you type .mp3 , it will locate ALL files that contains .mp3 suffix.
ps. Next time you download the a file (which by default WILL NOT BE ON YOUR PLAYER unless you change the 'options' default drive/folder of course), take note to which drive/folder you are downloading it.
Dec 23, 2009 | Rio 600 MP3 Player
When i turn on my zune it just continues to restart. it showed a code 5 error message. What is it and can i fix it
you receive the message when A Windows Digital Rights Management component is corrupt.
Things to try
  1. Reset the DRM system on the computer. Warning This procedure affects all media files on the computer that use Windows Media DRM technology. The effect of this procedure is not limited to media files that you obtained from the Zune Marketplace. If you follow this procedure, content licenses for all protected media files on the hard disk are deleted. Other providers, such as, Napster, MSN Music, and Wal-Mart, use different mechanisms for restoring licenses. If you have content from other providers, examine the appropriate license restoration policies before you continue.To reset the DRM system on the computer, follow these steps:
    1. Verify that the Show hidden files and folders option is turned on. To do this, follow these steps:
      Windows 7 or Windows Vista
      1. Start Windows Explorer. To do this, click Start, type userinit.exe in the Start Search box, and then press ENTER.
      2. Click Organize, and then click Folder and Search Options.
      3. Click the View tab.
      4. Click Advanced Settings.
      5. Under Hidden files and folders, click Show hidden files and folders, click to clear the Hide Protected Operating System files (recommended) check box, and then click OK.
      Windows XP
      1. Start Windows Explorer. To do this, click Start, click Run, type userinit.exe, and then click OK.
      2. Click Tools, and then click Folder Options.
    2. Locate the DRM folder on the computer. Typically, the DRM folder is located in the following location. Note In these paths, drive represents the drive on which Windows is installed.Windows 7 or Windows Vista
      • Windows 7 or Windows Vista x86-based versions
        drive:\ProgramData\Microsoft\Windows\DRM
      • Windows 7 or Windows Vista x64-based versions
      Windows XP
      • drive:\Documents and Settings\All Users\DRM
      Note If you have upgraded from Windows 98 or from Window ME to Windows XP, the DRM folders may be located in C:\Windows\DRM.DRM folders can be located in various locations in different versions of Windows. You can also locate the DRM data path in the registry. DRM data is located in the following section of the registry:
      • x86-based versions of Windows XP, Windows Vista, or Windows 7: HKEY_LOCAL_MACHINE\Software\Microsoft\DRM
      • x64-based versions of Windows 7 or Windows Vista: HKEY_LOCAL_MACHINE\Software\Microsoft\DRM
      To locate the DRM path in the registry, follow these steps:
      1. Start Registry Editor.
          Windows XP
          • Click Start, click Run, type Regedit, and then click OK.
          1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, type run in the Start Search box, and then click Run under Programs.
          2. Type regedit.exe in the Open box, and then click OK.
            Collapse this imageExpand this image securityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
      2. Look for the applicable folder based on the version of Windows that you are using.
    3. Rename the DRM folder to DRMbackup.
      1. Right-click the DRM folder, and then click Rename.
      2. Type DRMbackup, and then press ENTER.
      3. Close Windows Explorer.
        If you receive an “Access denied” error message when you try to rename your DRM folder, start the computer in safe mode and log in as the computer administrator. To do this, follow these steps:
        1. Restart the computer and start pressing the F8 key on your keyboard. On a computer that is configured to start multiple operating systems, press the F8 key when the Boot menu appears.
        2. Select the safe mode option when the Windows Advanced Options menu appears, and then press ENTER.
          The Boot menu appears again and the words "Safe Mode" appears in blue at the bottom of the screen.
    4. Reset the DRM security component. To do this, visit the following Microsoft Web site, and then follow the steps to upgrade the DRM security component: http://go.microsoft.com/FWLink?LinkID=34506 (http://go.microsoft.com/FWLink?LinkID=34506)
      Note When you access this site through Internet Explorer on a Windows Vista-based computer, you may receive a "user account control" popup message that requires that you enter the administrator password to continue. Note If you are running a 64-bit version of Windows 7 or Windows Vista x64 and the Upgrade button on the site listed earlier in this step appears dimmed, you will have to start Internet Explorer by using an account on the computer that has Administrative privileges in order to continue.
    5. Sign in to the Zune Marketplace. Then try to play a song to verify that the issue has been resolved.
    6. Restore the setting of the Hidden files and folders option. To do this, follow these steps:
Oct 31, 2009 | Audio Players & Recorders
No sound recorder
located in your windows\system32 directorys file is called SoundRecorder.exe no problem just please vote
Jun 29, 2009 | Microsoft Windows Vista Home Premium...
I am trying restore windows vista on my ACER Aspire 5100 but a message keep coming up saying that Windows cannot open the required file D:SourcesInstall.wim. It also says the file does not exist and to...
This error is due to....
  • The default security provider in Windows XP, or
  • the System drive letter
  • To solve dis issue.. try one of the methods
    1)Reset Windows XP Default Security Provider
    1. Open Start menu, select Run, type regedit and then press Enter.
    2. In the Registry Editor window, locate and delete the following registry keys:
      HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptograp hy\Providers
      HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptograp hy\Providers
    3. Exit the Registry Editor and restart your PC
    2)Reset The System Drive Letter
    1. Start your computer in Safe Mode-turn on the PC, and press F8 during startup. Next, when the Windows Advanced Options menu is displayed, scroll down and select Safe Mode.
    2. Open Start menu, select Run, type regedit and then press Enter.
    3. In the Registry Editor window, locate the following registry keys:
      HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
    4. Edit this key to change the value of the system drive.
    5. Exit the Registry Editor and then restart your PC
    Mar 20, 2009 | Computers & Internet
    Burning problems when running windows xp
    avoid multitasking while burning disc, since this process requires more computer resources like Hard disk space and RAM. you can also update the firmware driver of your Disc burner from the manufacturer's website to correct the problem.
    FOR HELP WITH DUAL BOOT INSTALLATION
    Choose a partitionTo add Windows Vista to a system where an existing version of Windows is already installed, first make sure that you have an available partition (or unformatted disk space) separate from the partition that contains the system files for your current Windows version.
    The target partition can be a separate partition on the same physical disk, or it can be on a different hard disk. If your system contains a single disk with a single partition used as drive C, you cannot create a multiboot system unless you add a new disk or use software tools to shrink the existing partition and create a new partition from the free space. (The Windows Vista Disk Management console, Diskmgmt.msc, includes this capability; to shrink partitions on a system running an older Windows version, you’ll need third-party software.) The new partition does not need to be empty; however, it should not contain system files for another Windows installation. Run Setup, choose the Custom (Advanced) option, and select the disk and partition you want to use for the new installation.
    The Setup program automatically handles details of adding the newly installed operating system to the Boot Configuration Data store.
    And how do you edit and configure the Boot Configuration Data store? Surprisingly, the only official tool is a command-line utility called Bcdedit. Bcdedit isn’t an interactive program; instead, you perform tasks by appending switches and parameters to the Bcdedit command line. To display the complete syntax for this tool, open an elevated Command Prompt window (using the Run as Administrator option) and enter the command Bcdedit –?
    arrow_px_up.gifTop of page Rename entries in the boot menuFor everyday use, most Bcdedit options are esoteric and unnecessary. In fact, the only option that we remember using more than once during the entire development cycle for Windows Vista was the command to change the text for each entry in the boot menu. By default, Setup adds the generic entry “Microsoft Windows Vista” for each installation. If you set up a dual-boot system using Windows Vista Home Premium and Windows Vista Business, you’ll be unable to tell which is which, because the menu text will be the same for each. To make the menu more informative, follow these steps:
    1. Start your computer and choose either entry from the boot menu. After startup completes, make a note of which installation is running.
    2. Click the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, type cmd in the Search box, and press CTRL+SHIFT+ENTER. Click Continue in the User Account Control box to open an elevated Command Prompt window.
    3. Type the following command: bcdedit /set description "Menu description goes here" (substitute your own description for the placeholder text, and be sure to include the quotation marks). Press ENTER.
    4. Restart your computer and note that the menu description you just entered now appears on the menu. Select the other menu option.
    5. Repeat steps 2 and 3, again adding a menu description to replace the generic text and distinguish this installation from the other one.
    Control which drive letter your boot volume usesWhich drive letter will your clean installation of Windows Vista use? That depends on how you install it. If you currently have a working copy of any Windows version on drive C and you install a clean copy of Windows, drive letters are assigned using the following logic:
    • If you begin the installation process by booting from the Windows Vista media and choose a partition other than the one containing your current copy of Windows, the new installation uses the drive letter C when you start up. The volume that contains the other Windows installation uses the next available drive letter. When you choose the previous Windows installation from the startup menu, it uses the drive letter C, and your new Windows Vista installation is assigned the next available drive letter. In this configuration, you can be certain that your current operating system is always on the C drive, but drive letters assigned to volumes you use for data may shift in unexpected ways.
    • If you begin the installation process by running Setup from within your current version of Windows and use the Custom (Advanced) option to perform a clean install on a partition other than the one currently in use, the new installation uses the next available drive letter. The volumes containing each installation have the same drive letters regardless of which Windows version you select at startup.
    Dec 01, 2008 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
    Microsoft Windows Vista Ultimate Edition Logo
    119 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
