Question about RCA HD52W56 52" Rear Projection HDTV
Tv junk hey , i have an RCA HDTV it a 52 inch,, one day it just stoped working,, and the led just flashes, idk if its some kind of code or not, but it flashes 9 times than pauses than flashes 5 times,, and that is all it does,, so i just shut off the power to it,, and every now and than i will turn the power back on and it will work for about an hr or so than go off and do the same thing over agin
  • Anonymous Apr 01, 2009
    We are having the same problem. Nine flashes, a puse, and then 5 flashes. What does this mean and what should we do?
  • RCA Master
  • 5,138 Answers
You have 3 capacitors that open up on deflection board cp150 2200uf 16v if it is bubbled up on top it is bad replace all 3 caps cp150,111,114.
Posted on Oct 18, 2008
Different Kind of Convergence Problem - RCA 52 inch
The FL231 fuse is dead.There 3 retangles squares the one in the midle is dead near the right side of the FBT high voltage transformer.the big plastic block with a red wire hook a cap to ur CRT.
Sep 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
1995 rca 52 inch tv...
Please post the model number of your RCA as usually its a bad flyback and start up capacitor when you get a 3 blink error code . But I can help you better if I have the model number of your set.
Oct 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Mitsubishi 55 inch 1080 tv
Is it flashing a two digit code such as 34 as thats a common fault with the WD52525 V26 chassis for a lamp abnormality caused by two bad capacitors on the PWB PCB
Jun 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W56 52" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
