Question about MSI 915G Combo-FR Motherboard
Where to connect card reader?
Hi, my cabinett has in the front card readers (or what you call them) and then there is a cable with a contact or connector - a black flta thing with the following text: Vcc, D-, D+, GND and GND. Where do I connect this on this motherboard.
    Sergeant:
  • 293 Answers
Easy, if you find where your front usb port is connected you'll see some odd ports that have 10 pins slots one of which has a missing pin, either in the lower left hand corner or in one of the center pin positions. Find the one that matches your generic (usb) card reader and plug her in. The card readers that come prebuilt in computers now are based on usb technology and fit into the same slots as the USB connectors. In fact if this is on a 915G it should plug into one of the JUSB1 or 2 slots.
Posted on Sep 12, 2008
FITTING SD CARD READER
if you are trying to install external card reader it is connected to the usb
if it is internal card reader it will get connected to the usb connector on motherbaord (front panel usb)
Apr 14, 2014 | Dell OPTIPLEX 745 PC Desktop
Where do i insert a memory card from camera to transfer pix to desktop
If you have a builtin card reader else you can use usb cable or buy a card reader which is cheap about £1.
Jul 07, 2011 | Computers & Internet
How do I load scan disk pictures onto computer
If your PC has an SD card reader you can place the microSD card into the adapter that it came with and then insert it into the slot on the PC. The SD card reader will be a small slot usually at the front of the computer. If there is no SD card reader then place the microSD card into the gadget you use it with such as your camera/phone etc and connect the device to your PC using a cable the device came with. The cable will have a USB jack at one end that will fit into the USB ports at the front/back of your computer. Once your device is connected you can follow the on-screen instructions to access your pictures.
May 23, 2011 | SanDisk 1GB microSD Memory Card
I cant rewrite any cards
There is switch on the edge of the card to lock the card from read/write. Check if it locked and unlock.
This switch prevents anyone from trying to write/erase your data in the memory card.
Hope this is helpful
Nov 03, 2010 | ID Tech IDMB-334112B Magnetic Card Reader
I cant figure out how to use the memory card reader, whenever I plug it into the computer nothing shows up. What do i do?
Make sure that the memory card is properly seated inside the card reader.
Try different cable.
Verify with the manufacturer, if this card reader is a Plug-n-Play or if you need to install a driver to the computer.
Try connecting it to different computer. Or try different types of memory cards (the cards should be supported).
If same problem occur, you need to contact the reseller, because the card reader could be defective.
Mar 15, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Pc acer aspire T650. My card reader fail so i took it out from my pc. Since then I have problem to make my pc read my external HD and the 2 usb in front don't work and since a very long time. Where can I...
hi,
Infact front USb ports are connected with the card reader it self.If you are havingthe separate connectors then you will have to connect those to motherboard to make those USBs to work.
You can get any 9 in one card reader from nearest hardware vendor and deploy it.
thanks
Jul 27, 2009 | Acer Computers & Internet
We have an Hp computer. The memory reader in the
Hi Larry,
There are a few likely scenarios that would cause your card reader not to work.
1. The cable inside the computer that connects the front-panel card reader to the motherboard has come loose. You can check inside the case to make sure the cable is tight and connected. You should do this with the computer turned off, and turn it on when you're done.
2. The card reader itself has gone bad and stopped working. If this is the case, you'll need to either contact the manufacturer for repair, or you can go out and get yourself an external USB card reader for cheap.
3. The card reader is functional, but there's something wrong in the operating system that prevents the cards from being read, because the operating system doesn't know how to address the card reader. This can usually be fixed by re-installing drivers and software for the card reader.
May 18, 2009 | HP Pavilion a705w PC Desktop
Tower will not boot or communicate with monitor
Don't throw out that computer or replace any components just yet.
After much trial-and-error, I finally figured out the solution for this common issue with certain HP Pavillion models. It turns out to be a design flaw with the front-panel memory card reader. Somehow the card reader's firmware gets scrambled, and it prevents the computer from booting. You can test this on your machine by temporarily disconnecting the card reader cable at the motherboard header. Voila - I'll bet you $1 that your computer will now boot!
The solution is buried deep inside this HP tech support document. The card reader firmware needs to be reset.
Here\'s how to fix it once and for all:
1) With the computer power unplugged (duh), open up the case & disconnect the card reader cable at the card reader itself - NOT the end that connects to the motherboard header. Make sure the cable end is not touching any metal components before proceeding to step 2 (another duh).
2) With the cable still disconnected, fire up the computer. The tech support doc says to let it boot into Windows and stay there for about 5 minutes.
3) Shut the computer down and reconnect the cable to the card reader.
4) Turn your computer back on - your memory card reader will work and, most importantly, the computer will no longer hang at POST!
I suspect that when you fire up the computer without the cable connected, the card reader is designed to reset its firmware by grounding out through the case - sort of like a CMOS Reset jumper on a motherboard.
I hope this solution is helpful to others.
best,
JohnB
Mar 29, 2009 | HP GX612AA Pavilion Media Center M8330F...
Memory card reader not Reading at all!
Hi! I had the same problem. The tech accidently pulled the cable out. Either put the cable back in or take it back to the tech...
Dec 17, 2007 | HP Media Center m7060n PC Desktop
HP pavillion a800n pc wont' boot up..I get nothing...
best,
JohnB
Oct 31, 2007 | HP Pavilion a800n (PP163AA) PC Desktop
MSI 915G Combo-FR Motherboard Logo
1,705 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
