Dell E172FP  17 in. Flat Panel LCD Monitor
Problem for Dell E172FP (Black) 17 in. Flat Panel LCD Monitor
Blank screen
By djg123 on May 14, 2006
Screen is blank, power light is blinking green. Disconnecting the video connection makes no difference. A substitute monitor works OK, so definitely seems to be a monitor problem. Any ideas? Many thanks.
Comments:
May 16, 2006
- Thanks Frazz. I fear you are right, but am going to try a local repairer. Mine IS out of warranty!
May 20, 2006
- Thanks again Frazz. Unfortunately, the repairer decided he couldn't fix it. Dell had promised to give me a quote for a repair, but this didn't appear. So I've been shopping around for a replacement. It's tempting to go for an extended guarantee after this experience, but you can get a good replacement now for less than £150, and when the year's guarantee is up they will probably be less than £100, so I will continue to take my chances!
Same Problem
Sep 01, 2008
-   Hi all well my samsaug is not on because when I press the power button the ightblink like 3 seconds then stops and turns it self off again can some help me fix do not have money for repairs-   ukefreekill
Aug 16, 2008
-   We have the same problem...blank screen, green blinking light - Monitor will not turn on at all, even though computer is working fine. Do you have a solution? -   rflesch
Aug 11, 2008
-   Same problem encountered Blank Screen and Power LED flashing Green-Amber-Green Recycling the power supply temporarily solve the issue, but for only a few seconds.
Occasionnally the screen is displaying "Burn-In On" which is surprising
Guy
-   One Guy
Jul 22, 2008
-   Mine is a Daewoo F205 15 in. Flat Panel LCD. I bought it in '03. It also had a blank screen though the green LED was on. I took someone's hint and unplugged it. Now I've replugged it and it's been going for 15 minutes and counting... Looks like the old re-initialisation trick came to the rescue once again. -   guyca
Jul 22, 2008
-   Mine is also blank. Power LED works. Other monitor works with same computer. Owner's manual says that in this case, "Using OSD, adjust Brightness and Contrast to maximum or reset totheir default settings."
Are they kidding?? How do you adjust or reset anything if there's nothing on the screen?
-   guyca
Best Solution
posted on Dec 22, 2007
Very Helpful)
Guest
Rank: Apprentice  Computers & Networking  Expert
Rating: 0%, 0 votes
It's easy to fix. Replace the power supply board or more commonly called inverter board. I fixed mine, it's easy.
Solution #2
posted on May 16, 2006
Somewhat Helpful)
Frazz
Rank: Apprentice
Rating: 78%, 13 votes
Looks like the monitor is dead. I've just had exactly the same thing happen to mine. Phoned Dell and they're sending out a replacement. Had it two years, but luckily took out extended 3yr warranty so no charge.
Frazz
Comments:
May 16, 2006
- Bad luck - hope it is fixable for you. If so, post back and let us know just in case it happens again and this time the warranty is up :(
Frazz
May 20, 2006
- That's a pity that you couldn't get it repaired. My replacement from Dell arived the next day and we're up and running again. I must admit that I'm usually pretty sceptical about extended warranties, but the deal from Dell was far cheaper than anywhere else when we got the system (and still is). We've now got three Dell systems in the house all with extended warranties as it only adds about £60 to the cost of the systems for next day on site service and peace of mind for an extra 2 years. Dell customer service tends to get some bad press, but I've found them pretty good so far. Hope you find a good replacement.
Frazz
Was this helpful?
Yes
No
Solution #3
posted on May 20, 2006
Somewhat Helpful)
techman
Rank: Guru
Rating: 86%, 7687 votes
An extended warrantee is not a bad idea except when they try to sell you differant types of extended warrantee such as a picture tube warrantees not a bad deal as most tvs already have a 2 year warrantee so really your only getting an extra 3 years so idf if the cost is reasonable lets say like under 50 bucks then what the hay i would go for it and lets say like on a refridge or freezer where they extend the warrantee to 5 years Where really most manufacturers alreadsy give ya 5 years on the sealed system but that takes care of labor but an extended warrantee like this will cost about 200 bucks so that woukld be the labor cost if it needed a major repair. Butt some folks are givin ya a rebate now if you take out an extended warrantee and dont use it as my warrantee I got for my fridge is 159.00bucks and if I dont use it in 5 years i get back 85.00 bucks!! So it really depense on how much they charge for the warrantee like if I lived in a remote area I would get an extended warrantee on almost everything I bought. So next time your offered and you say is it worth it?? Spead those paymennts out in your head and just say to yourself thats ids less expensive to pay a little across a time frame then alot all at once!!!
Was this helpful?
Yes
No
Solution #4
posted on Dec 12, 2007
Somewhat Helpful)
Guest
Rating: 0%, 0 votes
I have had temporary success restarting windows... then I get display again--for me it typically happens during a restart.
Solution #5
posted on Nov 24, 2009
Very Helpful)
lennieseay
Rank: Apprentice
Rating: 100%, 1 votes
The problem could be the power supply as it was for my brother in law's monitor with this issue. The power supply read 12VDC when checked with a voltmeter, but when connected to the monitor. was loading down and cycling causing the flashing green power light on the monitor. You can check the power supply by connecting a 12 volt car parking light bulb to give the power supply a load, The power supply green light extinguished and failed to light the 12 volt car bulb when connected. The power supply is rated at 12 volts at 4 amps and another power supply rated 12 volts at 2 amps would power the light bulb and monitor when connected. Hope this helps and have a great day!
Comments:
Nov 24, 2009
- Solution number 5 was just to verify the original AC adapter power supply was the cause, by substituting a power supply rated at 12 volts at 2 amps. DO NOT use a power supply rated less than 12 volts at 4 amps for regular use as it will overheat. I did not want someone thinking they could buy or power the monitor with a lower rated power supply.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #6
posted on Feb 18, 2008
Very Helpful)
Toddd
Rank: Apprentice
Rating: 92%, 3 votes
replace the caps on the psu. c215, c211, c213, c214, c216, c212. they are 470uf 25v. It comes apart very easy and the caps are in a good position for removal.
Comments:
Feb 18, 2008
- This is on a ProView Toddd
Was this helpful?
Yes
No
Solution #7
posted on Dec 04, 2007
Very Helpful)
sh_solutions
Rank: Apprentice
Rating: 93%, 9 votes
This problem is very often caused by dry electrolytic capacitors on the inverter board. If you have some skill with soldering you could try to change them. When buying new ones ask for LOW-ESR capacitors for switching mode power supplies (SMPS) and 105°C, they are a little bit more expensive than normal electrolytic capacitors, but are designed for this aplications so they lasts more. Normal el. caps will also works fine so when you cannot buy LOW-ESR for SMPS use normal ones.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #8
posted on Apr 22, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
bad inverter
Solution #9
posted on Jan 31, 2008
Not Rated)
Omegared
Rank: Apprentice
Rating: 0%, 0 votes
Just a tipp.
I have also a 447XS 17" monitor. I have the same problem (the monitor works a lot and then the picture goes away, but the power led is on).
The problem is the poor soldering (broken soldering points) at the high voltage transformer legs. Just a little soldering and the monitor works great again.
Warning! Be cautious at soldering! The components contains high voltage also at deactivated state!!!
Sorry for the bad english.
Was this helpful?
Yes
No
Solution #10
posted on Jan 09, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
Hey, guys, my power surged and my monitor power button flashes green and the screen is blank. When plugged in, I listen into the back, I hear  click and a beep with every flash. I'm just saying, if you guys hear this, it's definately a problem in the monitor and not in the computer, because mine works well with an older monitor. The power source probably died inside, meh.
Popular Solutions for Dell E172FP 17 in. Flat Panel
Questions and Unsolved Problems for Dell E172FP 17 in. Flat Panel
Do you recommend Dell E172FP (Black) 17 in. Flat Panel LCD Monitor?
Answer
Answer
problem turning monitor on, have to keep trying for ages
Answer
dell 172fpb schematic diagram need screen blacks after 2 sec
Answer
it works when plugged directly into my laptop but can't be set as primary monitor only extension of... (More)
Answer
I have a delll E172fpb monitor that only displays a solid white screen is there a solution to the... (More)
18 Other Users Have The Same Problem - Continued
Comment by crowefire, posted on May 25, 2008
montor goes black
Comment by zaann, posted on Apr 14, 2008
Screen is blank, and power light wont turn on, however if you unplug the power and replug it back in, the green light flashes on and off, but if you unplug the video from the pc, the light goes off.
Comment by Guest, posted on Apr 08, 2008
Power to monitor is on, computer is on, screen goes blank. Cycling the power brings monitor back on for a few seconds, then it blanks again.
Comment by Nyabinjah, posted on Feb 16, 2008
power light is blinking blue and no image.
Comment by MG55559, posted on Feb 07, 2008
My Monitor has been slow to turn on. When I start up my computer, it seems that the computer loads up, but the screen will not come on for about 20-30 minutes. The green light comes on for about 5 seconds and then blinks off and then comes on again. It repeats this until finally it will come on and then I have no problems for the rest of the time I am using it. I have unplugged it and that does not seem to work. I was unsure if I should try to update the drivers or reinstall the whole program.
Comment by texdig, posted on Jan 19, 2008
Samsung 740 T now blank despite power light on. (When it WAS working, the screen remained partially lit and would not turn off from front button). The following site mentions noticeably blown or 'out of value' components on monitors ...which has helped me grow some balls. Will now remove cover and check 'r out. Many times, with the most complex equipment, you get lucky with something silly easy (like a fuse or noticeably blown or blackened component or connection)
http://www.e-repair.co.uk/tipsmon.htm
So don't just THROW AWAY an expensive item without even looking inside. Also, an honest technician can then take a quick look over without a dismantling charge. He'll likely throw up his hands and say it's not worth going further or say "the problem's likely to be ..." or "THERE'S the problem" !
Comment by bates6376, posted on Dec 27, 2007
I have had my monitor for a few years and all of a sudden, I get a BLANK screen. The green light is on, but no one is at home. I can see an image for about a second and then nothing. If I cut the power on and off, I see an image for a second then gone again. What is wrong with my monitor? Repair or replace??
Comment by laosboy5, posted on Dec 20, 2007
DCL 9A+, I need a Schematic (blue print) of this board that is inside, mounted on the metal plate behind the monitor it self. My problem is that two of my components has been fry off, causing my monitor not to turn on. But the monitor still has power, with the green light blinky constantly. Those two components are R88 & C65, if any knows the value (voltage) of these two componets, I can fix it myself. If anyone has any spare parts and willing to help, I'll appreciate it very much.
Comment by coorg74, posted on Dec 13, 2007
I have ViewSonic P810 21" CRT Monitor. I have a same problem what djg123 is facing. But one of the technician suggest me to replace part of the monitor is E.H.T. DOUBLE FOCUS SINGLE SCREENED. I did'nt do yet. Can I go through him? please suggest.
Mohan Mukkati
India
Comment by moonfish, posted on Dec 11, 2007
I am having the same exact issue...I just took this monitor out of the box and it blinks on for 2 secnds and then goes away...Have you found a solution?
Comment by lemayag, posted on Dec 09, 2007
When I turn the monitor on, the screen pops up momentarily (about 2 sec) & then goes completely blank. The power is still on, but there is no image. What do I do
Comment by Guest, posted on Dec 01, 2007
When I power on the monitor with or without the computer, the monitor powers up momentarily and then the screen goes dark black. The green power light stays on solid, but the screen is off. If I power cycle the monitor about10 to 15 times eventually the screen powers on. Then I get the no signal found box and when the computer is powered on the screen follows the boot up info. I have to power cycle the monitor with or without the computer turned on. It must not be the video card. But is this just the monitor wearing out? This happens with the VGA or DVI input connected.
Comment by Jagwinder, posted on Nov 10, 2007
my screen is blank but the power light is blinking what do i do
Describe your Monitors problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
