Question about GE SCA2001FSS Advantium Electric Single Oven
How to replace lower halogen light assembly, also, replacing turntable shaft
I have a G.E Advantium SCA2001 BSS 03. The lower halogen light has burned out and the turntable shaft is broken. What are the necessary steps to replace these?
  • 706 Answers
item 1474 is the turntable shaft and is GE # WB02X10624
You should be able to remove item 1476 and lift out the shaft to replace it..then reinstall item 1476 to lock it in place, Hope this helps ...
Posted on Sep 13, 2008
I've got a built in double oven, SCD302TS with no light in the lower oven. Replaced bulbs with known good but no dice. Top oven lights when lower oven is opened, so it's not the switch. Any ideas?
i just looked up your model number and when you change a halogen bulb you should buy the bulb and socket or lamp assy. part 14-38-437 and that's the part the bulb plugs into you can't get it anymore,i just was on sears and repair clinic and it's unavailable
Nov 06, 2017 | Ovens
Replace outside glass
You have an expensive Monogram microwave so you can expect the parts to be expensive also. The outer glass assembly by itself ballpark cost is about $160 and requires a complete dis-assembly of the door to replace since the screws are all inside. Then if you go by the book--- the door should be checked for microwave leakage after the repair which requires a special test meter. They also sell a complete door assembly at around $300 that comes completely assembled. You need to compare that cost against the age of your microwave and possibly a new unit which I think is still available. Either way its not a cheap fix.
Apr 11, 2015 | GE ZSC2001FSS Advantium Electric Single...
Advantium--removing lower halogen cover
you need a torx/star screwdriver
Dec 31, 2013 | GE Ovens
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
No lights no work no nothing
Make sure there's power getting to your range, oven or cook top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter. Sometimes the power cord disconnects or burns at the appliance, if this is the case, the wiring and the terminal block must be repaired or replaced.
If there is confirmed power to the unit, this will confirm board failure. have the main board replaced in this case asap.
Aug 06, 2009 | GE SCB2000F Advantium Electric Single Oven
Need to replace halogen bulb that illuminates Advantium interior
Mine is installed also, and I've had to replace the bulb twice. I wised up the second time and installed an access hole where I can pull my microwave out about 6" and access the bulb. I use a 35 watt 120v halogen bulb, with a GY 8.6 base, Lowe's part number 15797. If your's is different, the specs will be stamped on the metal beside the reflector when you remove the sheetmetal. You have to remove the microwave completely from the cabinet and remove the sheetmetal case that surrounds the entire unit. You can then access the lamp socket by looking in from the top. The first time, I took out the reflector with the socket. The bulb can be replaced by removing the two small screws adjacent to the socket on top of the reflector. My access port is a hole cut into the top. I cover the hole with a piece of sheetmetal and two sheetmetal screws. Seems to work just fine. If you do decide to cut a hole, do so with the metal enclosure off and away from the microwave to avoid getting any metal shavings into the machine!
Regards! --W/D--
Feb 17, 2009 | GE Profile Advantium SCB2001KSS Stainless...
GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
Sep 19, 2008 | Ovens
I need to replace the outer glass on my Advantium oven
contact GE; they should have replacement glass in stock.
Apr 28, 2008 | GE ZSC2001FSS Advantium Electric Single...
Turntable not turning
I fixed the problem with my microwave turntable motor without having to replace it. I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate. Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ?bumps? on the underside of the gear on top and washer on the bottom. Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place. If this worked for you please let me know ? karlet@bellsouth.net
Sep 11, 2007 | GE JTP85 Electric Double Oven
GE SCA2001FSS Advantium Electric Single Oven Logo
267 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
