Question about Xerox Office Equipment & Supplies
Our xerox is out of black toner. we have the wrong refill drum cartridge. how can we exchange it and rapidly get the correct size?
    President:
  • 2,072 Answers
Who did you order it from? If its Xerox call 1-800-821-2797, they should be able to overnight it to you and send you a return label
Posted on Sep 13, 2008
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Xerox 3250 printer smudges with new toner cartridge
Go to the settinge. Go to maintenance a perform the cleaning steps.If that doesn't correct exchange cartridges . Remember recharged cartridges have problems. Possible you need to shake the cartridge.
Feb 25, 2013 | Xerox Phaser 3250DN printer BW laser...
We have vertical lines through the colour ink on every print job.
Hi Sandra,
There are usually a few possible causes of a line on a laser print of
the nature you mention.
One is a scratch on the drum surface. This can be caused by a piece of
grit getting into the wrong place, from paper or elsewhere. Scratched
drums tend to hold toner in that location which is then transferred to
the paper and fused to it.
The other cause is if the drum wiper black has become damaged (again can
be caused by a piece of grit). In this case, the wiper black which is
supposed to clean excess untransferred toner to a waste chamber in the
cartridge, has a slight damage in it, and the toner is moved and
redeposited on the drum where this gap is. The wiper blade is usually
made of a silicone like rubber with a sharply cut edge. On rare
occasions a piece of dirt can lodge on this wiper and temporarily deform
the blade, again allowing toner to get under it and redeposited on the drum.
If the drum and wiper is accessible, you can sometime very gently run a
business card under the blade and gently slide it down the drum to clean
any grit or paper dust that might be deforming the blade. However, on
HP cartridges most of this stuff is internal and not easy to access
without taking the cartridge apart.
If the cartridge was purchased new and is an HP brand, they may allow
you to do an exchange, since they use recycled and reused parts even in
their newly boxed cartridges. Also, if it is from a refiller which
guarantees the quality of the refill, you may be able to get a
replacement. If you had the cartridge refilled yourself using your own
cartridge, you may have less options.
Good Luck,
kc
Mar 16, 2011 | Samsung CLX-6210FX Laser Printer
WHY DOES THE PRINTER PRINT OUT BLACK PAGES
The problem is the toner cartridge. Try to replace new cartridge. The toner cartridge is damage. If you are refilling the toner cartridge, you didn't return the part correctly especially the roller drum it not correctly place making him print out prints all black page.
Dec 17, 2010 | HP LaserJet 4250tn Printer
How to refill toner or replace drum?
Most of these cartridges come as a refurbished cartridge. They cost about $109 US. Toner would be as much or more (but two fills) if you can find a supplier. A cartridge is about 30,000 pages so it is an EXCELLENT buy. I use laser for this very reason. Bought any 1000 page inkjet refills lately at $75?
Mar 20, 2010 | Office Equipment & Supplies
Can Xerox Phaser 6280 be refilled by Consumers?
The 6280 uses a specially designed toner called Emulsion Aggregation toner. This is a special type of toner made by Xerox. Sice it is so new and patents exist, I doubt that anyone can legally make the toner, even if they posessed the equipment and the expertis. Refilling with non-EA toner is asking for big trouble.
Aug 12, 2009 | Xerox Phaser 8200 Laser Printer
Print writimg ok,but very dusty black on both sides of paper
the supplier of the toner cartridge told me the drum must be cracked and he will supply me a new one.I appreciate your service and I recomment you for your assistant,thank you.
Dec 30, 2008 | Xerox Black Toner Cartridge 25000 Page...
Xerox XD130df empties toner back into cartridge overflow
that really sounds like a defective toner cartridge. Either there was no developer in the cartridge or the metering blade that limits the ammount that gets onto the roller is bad.
Has to be the toner cartridge. Unfortunatly that may have also ruined the drum and cleaner within the drum cartridge. Return them for an exchange.
The reason it is running and running is that it is trying to read a patch that is developed on the drum and add toner to make a dark enough copy. And that definatly is not happening.
If the laser was not turning on, the machine would come up with a L something code. Besides if the laser was not comming on, the paged would be blank.
You can pretty much eliminate everything but the toner cartridge.
Sep 22, 2008 | Xerox WorkCentre XD130DF Laser Printer
Refill
Hai
Well u can refill the toner,to refill the toner u should contact the nearby service station to refill.
Sep 09, 2008 | Xerox Black Toner Cartridge 25000 Page...
46 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
