Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Water leak THE WATER LEAKS WHERE THE HEATING ELEMENT GOES THROUGH THE BOTTOM OF THE DISHWASHER
  • Kenseth17 Sep 19, 2008
    mine is doing the same. The nut that goes on the heating element was split in half.
  • chadman1a Oct 12, 2008
    I too have a leak where the heating element goes through the tub. the water is dripping off the connnection to the wire.
TIGHTENED NUT ON UNDERSIDE OF DISHWASHER WHERE THE HEATING ELEMENT GOES THROUGH.
Posted on Sep 14, 2008
Found water in the pan under bottom of my 60 gal Rheem Marathon model CMR 75245 electric hotter tank. There is no other source of water goes in the pan. Tank is only 4 yrs old. Is the tank leaking?
Is it sitting in the pan or is it elevated over the pan? It is hard to see the leaking if it is sitting flat in the pan. Check all the connections, top and bottom. Wipe them dry and then run your hand over the connections and feel for water. Also check under the heating element covers for leaks. Good luck!
Dec 07, 2016 | Rheem Water Heaters
Maytag dishwasher dwu7400aax leaks water from lower right corner of door
Possible that the door seal is worn out , check for leak at the bottom to confirm this case. Click on : Door seal
Jan 25, 2013 | Dishwashers
Not cleaning properly and water has not drained out. yesterday there was a little water left in bottom and today there is a lot of water in the bottom of the dishwasher
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
j
Jun 30, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
I have a tricity bendix dishwasher.It is not washing properly,also the washing tablet dose not desolve.the model n.o is TDF 200
Dishes not cleaned properly....
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
Nov 23, 2008 | Dishwashers
Contents not coming out clean
Nov 19, 2008 | Dishwashers
Water leaks into bottom tray when filling
dear batties,
Such water filling problems can be generally solved by checking the following
  • Inspect the seals for the main tub, float, heating element and blower diffuser
  • Check for overfilling
  • Inspect the water and drain hoses
  • Inspect the door gaskets
  • Check the water inlet valve
  • Check the pump
Also for the mid cycle problems check the following
hope u find this useful. thank you for using fixya.have a great day.
Jul 09, 2008 | Neff Dishwashers
Whirlpool dishwasher leaks everywhere
CHECK YOUR HOSES FOR CRACKS. BE SURE THEY ARE ATTACHED SECURELY TO THE PUMP OULET.
THERE IS ALSO A BLACK HOSE FROM THE VALVE THAT GOES UP THE LEFT SIDE TO A VACUUM BREAK ON THE SIDE OF THE TUB. BE SURE THE HOSE HASN'T BEEN DAMAGED OR DISCONNECTED. IF THERE IS SUFFICIENT SUPPLY HOSE, PULL THE DISHWASHER OUT OF IT'S INSTALLATION AND TURN IT ON. WATCH FOR WATER DRIPPING ON THE FLOOR AND TRACE IT BACK TO FIND THE PROBLEM.
Mar 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire Dishwasher
This is a simple solution, the brass nut that connects the heating element to the base of the dishwasher is cracked and needs replaced. It takes just a few minutes to replace, just remove the nut after TURNING OFF THE POWER and take to your local parts store, they should have one in stock. You might have your model number with you. Appldoc
Oct 31, 2007 | Dishwashers
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
111 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
