Question about Kenmore 24902 Top Load Washer
Washer produces Hot Water Only
Our Kenmore 70 series washer model 110 is only putting out very hot water and no cold water at all.
Please advise
Jon Andrews
  • 1,028 Answers
First be sure you are getting a good flow of cold as far as the washer connection..if so ck inside washer connection for a small wire screen be sure it's not plugged if so clean and flish line to remove anything inside hose sure to put screen back in ..if still no cold suspect bad cold section of valve..replace valve..last remote possibility temp switch is bad
Posted on Sep 13, 2008
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
I have a Kenmore Heavy Duty 70 series washer older model. It will not alow cold water to fill washer. Tried warm and hot water only fills the tank. Hot water will fill fine with no problem.
shut the house water valve off,take off the cold water line on the back of the washer and stick it in the tub of the washer,have someone hold the hose and turn on the cold water valve,if water comes out then you need to change out the water valve on the washer,if no water comes out then you have a problem with the house water valve.there are screens in the valves see if you canpop out the screen and clean it out and put it back into the valve,you can try that but sediment could have went through the screen and damaged the valve,if so change it time send the model number and i can give you part numbers,let me know what you find
Sep 04, 2010 | Washing Machines
My Kenmore 110 92587210 Washer is slowly letting water in
The solenoid for the cold water valve has failed in the open position and needs to be replaced. The valve unit is for both hot and cold. It is the item that the water hoses are connected to.
Aug 26, 2009 | Kenmore 24032\24036 Top Load Washer
Washer is rinsing with hot wateer nomatter what temp. setting is used. I have tried to switch hoses twice now, no difference in rinse but now on correct wash temp.
The MAH5500 series washers have automatic temperature control functions so the washer can control water temp regardless of water heater settings and other factors. I would say either your definition of "hot" is not truly "hot" (over 110 degrees), or the washer's ability to sense has failed (which would also affect fill temp on "wash" fills also). If someone has worked on the washer recently, maybe they reversed the wiring to the water valves inside the machine? ATC temps are as follows: Cold 70-90, warm 90-110, and hot is unregulated at 110 degrees and up. These are normal temp ranges for ATC controlled machines, and are completely safe for fabrics.
Apr 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Cold water trickle hot water runs good
turn off water valves at wall, disconnect the supply hoses from the washer. where the hoses connect to the washer, there is usually a stainless steel screen/strainer inline on both the hot and cold inlet. corrosion on the cold side is pretty common. Menards, Lowes Home Depot stores sell the replacment screeens.
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Washer doesnt allow water in
likely the timer is failed if no water hot/cold comes in.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Washing Machines
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Kenmore 24902 Top Load Washer Logo
97 people viewed this question
Sal De
 Brian Main
Brian Main
