Question about HP PSC 1315 All-In-One InkJet Printer
Printer rejecting new refill ink cartridges
My printer will not reconize my new hp56 and hp57 refills. I pull them out and re install the old ones and there is no problem. Comes up as error.
  • n9uwe Oct 05, 2008
    I have the same printer and bought the same cartriges as you with the same results. Let me know if you find an answer as I would like to use this printer. It's a good one for Linux.
  • jaganram Oct 09, 2008
    Yeah i have the same problem , but it works fine now after i got the
    genuine catridges
    Thanks
Thanks for ur solution msmaniac . I had the same issues now it works fine after i got the new
cartridges
Posted on Oct 09, 2008
    Scholar:
  • 105 Answers
Hello spreadboss20 and n0uwe. HP's printers usually have compatibility issues with non-genuine as well as original refills. There may be several issues arising as a result of using refilled cartridges. So, better you try out for a new set of genuine cartridges.
thx
Posted on Oct 07, 2008
How do i reset ink levels on a hp deskjet 4160
HP does not support refilled cartridges
you must uninstall HP software then install driver only from windows update then it works fine.
Cheers :)
Mar 09, 2015 | HP Deskjet D4160 Printer
Hp officejet 4255 all-in-one cartridge Error - See product documentation for details how to slove this problem,,,?
GYou must be using HP56.
Have you refill your cartridge at all?
If you did, gentely wipe out the cartridge circuit part with Q-tip (with bit of alcohol).
And wipe out the circuit part in the printer where cartridge goes in as well.
And try back.
Sometimes by having some dust or bit of ink make cartridge unreadable.
If you used brand new, do same thing to cartridge circuit part.
Otherwise, there got to be some circuit shot happen in printer.
For your reference, HP4255 is not a new model however has not cause major problem.
Good practical and durability is good.
It seems like you are out of ink....especially black.
Pls refill or get brand new one.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 13, 2011 | HP OfficeJet 4255 All-In-One InkJet...
I have a HP officejet J4550 All in one and recently purchased an ink cartridge with the same number but is the xl and it prints for a while and then I get an error about being Incompatible
And try back.
For your reference, HP5510 is not a new model however has not cause major problem.
May 13, 2011 | HP Officejet 5510 All-In-One Thermal...
What is problem when a ink jet printer (hp psc 2410xi photosmart) has a red stripe in the black print?
Using HP56, 56 cartridge for your printer?
Well, when you are out of black ink, that's what it happens.
Pls refill your cartridge or replace with new one.
How you refill? very easy.
May 12, 2011 | HP Office Equipment & Supplies
How to install the ink
Open the front cover on the printer. The print cartridges should slide on a conveyor belt from one far end of the print chamber to near the center. There should be one black ink cartridge and one color cartridge.
Remove the cartridges from the printer. This should simply involve grabbing and pulling the cartridges out. There may be a flap holding the cartridges in place that you need to flip up first. Or you may need to press down on the cartridges to spring them out of place.
Decide on replacing the cartridges with a brand new ones or refilling the existing cartridges. Refilling the cartridges can cost less money in the long-term and reduce waste, while new cartridges will guarantee to work and have the most ink up front.
Refill the cartridges with fresh ink in order to reuse them. With black cartridges, you need to drill or melt a hole in the cartridge lid, while you will remove the lid to find the color cartridge's holes. Inject the correct color ink with a plastic syringe bottle. Reseal the lid on a color cartridge after refilling.
Dispose of the cartridges properly after you purchase new ones. Take the old cartridges with you to whichever store you get the new ones from. Not only will this help you find the correct replacements, but the store may also take the old cartridges for recycling.
Insert the new or refilled cartridges into your printer. New cartridges likely have protective tape over the print head that you'll need to remove. Run a test print on the computer to make sure that the cartridges properly work
Check to see if the printer still reads the cartridges as being empty (if you are reusing a refilled one). This will be due to a chip in the cartridges that the printer reads for the ink level. It doesn't change just because you refilled the cartridges. You must purchase an electronic device that will reset the chip for you.
Chris Thrash
B52Computers
Jan 21, 2011 | Canon Office Equipment & Supplies
I bought re-inked cartridge for Lexmark It didn't work
Yes, Lexmark has been making their new printers smarter to reject refilled cartridges. Most likely what is happening is your printer is turning off the electronics on the cartridge when it gets empty so you can't reuse that cartridge. I own a Cartridge World printer cartridge refilling store and I've even had customers return original Lexmark cartridges because their printers have rejected them. If you want to be able to refill your cartridges never buy a Lexmark printer. HP printers that use integrated print head cartridges can be refilled nicely.
Apr 13, 2009 | Lexmark JetPrinter 5000 InkJet
Printer ink cartridge not recognized by printer hp psc 1210
some time hp printer does not reconize refill cartridge or cartridge is damage when refilled so change cartridge
Feb 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Cradle jam after inserting ink cartridge, wont align
May-15-2008
in a HP-PSC-1210, replaced empty HP56 black-inkjet cartridge.
Afterward, printer gave error message AND unable to "dismount" the cartridge.
Finally discovered that an HP57 color-inkjet cartridge had accidentally been mounted/installed. A handyman relative was able to dismount the (wrong) cartridge.
Cradle did not actually jam, though printer would not print.
Apr 21, 2008 | HP Office Equipment & Supplies
Printer
Hi , use the genuine canon ink cartridge the printer can identified the ink cartridge. and colors.
Feb 19, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
HP PSC 1315 All-In-One InkJet Printer Logo
216 people viewed this question
Ben Johnson
